Page 725 of 2774 FirstFirst ... 22562567571572372472572672773577582512251725 ... LastLast
Results 10,861 to 10,875 of 41608
  1. #10861
    Someone not born in the 60's would be an excellent starting point.
    Does that mean born in the 50's would be OK ....
  2. #10862
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    Kenneth Leroy Roberts born December 31, 1951, he might go ok?
  3. #10863
    What is Wayne Gardner doing these days?
    He was born in the '50's too...
  4. #10864
    Give Garry McCoy a run, he's a young dude !
  5. #10865
    27th January 2011 - 11:30
    asdasd
    AKL
  6. #10866
Name:	Stan Stephans P1.pdf
ID:	279355Click image for larger version.
Name:	Stan Stephans P2.pdf
    A bit of wisdom from Stan Stephens.
  7. #10867
    I was just thinking I needed a new backdrop on my desktop - thanks. Slightly higher res would have been nice.
  8. #10868
    Darkside project
  9. #10869
    8HP from "flowing" (grrr I hate that term) alone ?
  10. #10870
    asdasd
    AKL
    This is as big as it gets I'm sorry:
    960x789 pixels
  11. #10871
    That's good enough to be used, thanks again.
  12. #10872
Name:	Something New 003.jpg
    With a bit of cut and shut and general lowering this could be a dark-side, chair.
  13. #10873
    Chambers is looking to use a pumper carb on the 50 he is prepairing for NedKelly. Plenty of clearance all round and a direct shot into the crank case.
Name:	Something New 008.jpg
ID:	279377   Click image for larger version.
Name:	Something New 005.jpg
ID:	279378   Click image for larger version.
Name:	Something New 007.jpg
  14. #10874
    Just a thought, maybe a nicer radius on the outside of the Bell-mouth in those pics?
    Maybe a pumper will help with my RS fitment woes...
  15. #10875
    Just a thought, maybe a nicer radius on the outside of the Bell-mouth in those pics?...
    Thats a standard gocart bellmouth and is shaped like that to go with a regulation cart airbox, I am not sure what Chambers is going to do but he has been talking about making an airbox to suit the RS frame.
    The Tillitson HL360A is 24mm (0.945") and is sure easy to fit into tight spaces. No rubber mount is required, you can bolt them hard up against the case, although a heat insulating manifold block could be helpful.
    I am a bit of a fan of these carbs, I got mine from here:- http://www.out2win.com/catalog/tillotson.html
Name:	Tillitson HL360A.jpg
    I ran the pumper like this, without any bellmouth and made 28+ hp
    It ran very well at the Taupo GP on the old track but I took it off when I started to knock on the door of 31+hp as the carb seemed unable to flow enough fuel. I have since obtained a bigger diaphragm needle jet and parts to make it into a double pumper, so look forward to trying it again.
