Page 75 of 2776 FirstFirst ... 25657374757677851251755751075 ... LastLast
Results 1,111 to 1,125 of 41630
  1. #1111
    but it is good to know it can be done easily and i ...
    Yeah that is real easy. I was looking at a similar problem and decided on the whole chassis, suspension, and wheels. Much much easier.
  2. #1112
    14th June 2009 - 15:13
    suzuki
    europe
    When I was around at the team ESE workshop yesterday I had the great fortune of meeting Thomas. We got talking about small 2-Strokes and drive-ability.
    He showed me a RGV250 cylinder and pointed out the black oily gunk in the transfer ports. This gunk was high up in the port where the port exits into the cylinder. It was obvious that at some point in the rev-range there was blowback happening when the transfers opened.
    Thomas pointed out that if this blowback could be stopped it would greatly widen the power band of the motor. He then drew some pictures of how it might be done using Fluid Diodes and told me that a Scroll Diode would probably be more effective in the transfers on a 2-Stroke than a Vortex Diode.
    He said that in steady flow conditions the Vortex Diode looks like it would work better in the inlet but in a 2-Strokes unsteady flow the Scroll Diode has proven best. And that at high RPM the Scroll Diode is more effective than a reed valve. Looking at the pictures it all made sense.
    The Team graciously gave me the OK to post these ideas and said they are looking into using it themselves and Fluid Diodes have been run experimentally in 2-Strokes. Where they showed no extra power but no loss of power either and a lot of real promise for widening the existing power band.
    So here's a first for Buckets, to my knowledge anyway, the idea of using Fluid Diodes in the transfers and inlet to reduce blowback and thereby broaden the power band.
    some research carried out in Israel.
    http://www.sae.org/technical/papers/830092
  3. #1113
    20th November 2002 - 11:00
    Wellington, New Zealand,
    1971 paper on Scroll diodes in two stroke engines...
    Attached Thumbnails Attached Thumbnails Scroll diodes.pdf
  4. #1114
    Some Pic's of how scroll diodes work and how they could be used in a 2-stroke.
    Pic-1 shows the key dimensions. The 30 inlet angle is important as is the r=2h.
    Pic-2 shows how they work and where they could be fitted to a 2-stroke engine.
    Abstract: from Sonic-v link
    The typical convex torque of a simple two-stroke engine having a port-controlled piston is attributed to the backflow through the scavenge ports. It is proposed here to suppress the backflow by installing scroll diodes at the scavenge ports. Experimental observations on a fired engine demonstrate the remarkable improvement achieved with the diodes installed.
Name:	Transfer Scroll Characteristics.jpg
ID:	133069   Click image for larger version.
Name:	Transfer Scroll Diode.jpg
  5. #1115
    That is interesting but anecdotaly that would have to have some effect on the flow in the same way that suzuki's old 1/2 case reed induction did on intake.
    The difference between fluid & gas is that fluid is largely incompressible & gas is easily compressed. It would stand to reason that this would affect the std model as might the expected pressures designed for.
    However an open mind, always experiment. know some crowd experimenting with rifled transfers. Didn't become the next big thing as far as I'm aware.
  6. #1116
    Fluid Mechanics/Dynamics deals with the flow of liquids and gases.
    The way a Fluidic Diode works is that in the forward direction the Fluid (gas) flows directly in a laminar manner from the inlet to the outlet but in the reverse direction Fluid enters the outlet and flows directly into a area of larger volume. A larger volume means reduced pressure and gas at a reduced pressure has more resistance to flowing back around the bend. Its no longer laminar and breaks up choking the entrance to the inlet. Like the sonic waves in the exhaust this can all happen at very high speed.
  7. #1117
    The experiments with a two stroke are in the paper I put a link to. Page two has a graph of torque curves. I could get at the paper sonic_v linked to; got to pay a fee?
  8. #1118
    I think you will find SS90 was going to mention the fluid diodes in post 820
  9. #1119
    Hi Skunk I could not open you're PDF document, something about Acrobat being unable to decript??
  10. #1120
    Try this one.
  11. #1121
    Try this one.
    No... it dos'nt work for me either. Does it for you??? could my reader be the problem??
  12. #1122
    16th November 2005 - 07:48
    I just lost count
    The District of Waipa
    Worked fine for me
    Pumba is a wise man.
  13. #1123
    Worked fine for me
    Ok.....problem my end then....thats not unusual......just ask the missus..
  14. #1124
    3rd May 2005 - 07:22
    2005 Custom Moped
    where the sun sets
    worrks fine on Ubuntu haaad tto click on view and then zoom in twice for my old eyes to reaad it
  15. #1125
    2005 Custom Moped
    where the sun sets
    hey TZ my bought new from the warehouse 6years ago Dell cant open that file of skunks.
    Ubuntu on the other hand is free and dual booting with XP is not a good ideA in the long run
    Intels seem easier to manage with Ubuntu onboard sound is less problems.
    I am different than a lot of linux freaks as its best to have a windows machine too
    Trying to rux windows programs on ubuntu is a waste of time
There are currently 95 users browsing this thread. (2 members and 93 guests)
  1. jonny quest,
  2. wobbly
