I apologise for thread dredging here but it's amusing what is said on the internet then proven wrong. Then it's followed by some old bloke from down sound playing a very small violin only to come second in the 2013 Tokoroa GP
It was clever, i liked the Allan Moffit in your face rule flouting, it cost him points, but it got the rules changed. From memory he also did the same with dry sumps till they made them legal as well.
Yes butRound four - Sandown; Allan won the race on Sunday but was eventually disqualified. Both Moffat Ford Dealer cars and most of the other Falcon teams were using illegal roller rockers.
30HP/85kg=.353kg/hp
34hp/95kg=.357kg/hp
If you were to pursue this path wouldn't a long thin intake give you a greater surface area for potential cooling like a RSW intake for instance.
The NASCAR guys would have a fire extinguisher filled with nitros oxide, they would release the extinguisher contents about the radiator support panel at a specified time when qualifying, this would be ingested through the appropriately jetted carburetor and wellar, pole position here we come
Some pro stock drag race guys had fitted nitros systems within the dry sump swirl pot, nitro lines would be inserted within the oil lines of the dry sump system to conceal them, once at the valley cover / under the intake manifold seperater plumbing and nozzles were hidden to feed each intake runner, this all came to the light when a system exploded, most likely a oil Vs pressure problem, shame these ideas men didn't understand how a diesel works
In my book there is no such animal as moral infringement. There are good readers and there are badly written rulebooks. Either something is laid down in writing, or it isn't.....the Entrants Association imposed a $5000 fine on Brock for a moral infringement of the rules.
Whenever someone mentions"'the intention of the rules" you can be sure that the rules are rubbish.
You may, Husa. The picture below may give a first impression, and you'll find the whole story here: http://www.tonyfoale.com/Articles/EngineBalance/EngineBalance.pdf
There are currently 200 users browsing this thread. (0 members and 200 guests)
