Page 770 of 2776 FirstFirst ... 27067072076076876977077177278082087012701770 ... LastLast
Results 11,536 to 11,550 of 41630
  1. #11536
    Quote Originally Posted by NSR143 View Post
    Sorry it's been a while... hope this provides interesting info for all.
    301 -Regan Griffiths
    266 -Richard Ford
    195 -Scott Griffiths
    138 -Richard Ban
    129 -Brian Steffensen
    123 -Henk Zeeven
    118 -Ken Douglas
    93 --Mike Kyle
    71 --Gary Cunningham
    71 --Malcolm Nabbs
    60 --Nathanael Diprose
    58 --Grant Nicolson
    56 --Leigh Tidman
    52 --Finn Keogh
    50 --Adrian Mitchell
    49 --Gavin Veltmeyer
    48 --Dave Manuell
    38 --Kieren O'Neill
    34 --Cory Peck
    29 --Steve Booth
    29 --Tyler lincoln
    26 --Kamil Chodor
    26 --Tyler Firn
    25 --Warrick Head
    23 --Tim Coopey
    23 --Shaun Parker
    20 --Cameron Page
    19 --Dave Trustrum
    18 --Chris Cain
    17 --Dean Miller
    15 --Aaron Hassan
    15 --John Steer
    15 --Luke Johnston
    15 --No5 Kaitoke
    11 --Glen Skatchill
    10 --Neil Robertson
    10 --Clive Banks
    8 ---Gareth Pywell
    7 ---Adrian Lee
    5 ---Joshua Head
    North Island Series 2012-13 Final Results .......
  2. #11537
  3. #11538
    19th September 2012 - 12:26
    simson
    Budapest
    Wobbly!
    We have talked over how important the blowdown and it's size are, but what about the blowdown's intensity? If the aux exhaust ports are opening later as the main exhaust port, the peak of the pression is smaller, meanwhile the blowdown lasts longer. Of course the STA is always the same. Here is an example 'One Half'
    In case of almost every race cylinder the aux exhaust ports are opening later, and this can be observed in systems with or whitout a power valve. In case of a T port the top edge radius is not 0, but pretty much bigger.
    Is it important? Why don't we open the ports the widest possible? That way the ports could be positioned lower what would be optimal.
  4. #11539
    http://www.trademe.co.nz/motors/used...-590730737.htm
    Have i got an idear for you TZ350
  5. #11540
    A class at Buckets called Formula Simca perhaps...
  6. #11541
    Talking with my old man about the programmable ign it is hard work out what's happening with the engine all the time with the curves and powerjet and what nots in relation to the power curve.
    So we wondered if we made a graph starting with a dyno HP curve and then overlaying it with ign advance curve and powerjet off and on times and other things the programmable ign is doing using the revs as the common baseline.
    Attachment 282546
    I have not actually done what your trying to do with the graph before myself, but because my ignition advance on WOT covers pretty much the same range as the hp, ie 0 to 30 on the Y axis I mocked up this EngMod2T dyno graph to see what it might look like.
    Yellow for ignition advance and blue for power jet on/off.
Name:	Ignition vis Power.JPG
    Yesterday I received an email from Neels, the author of the EngMod2T simulation software to tell me that EngMod can graph what Diesel Pig was looking for and how to do it. EngMod2T is a very well supported package.
  7. #11542
    There are two factors in play with the tripple port setup.
    You have drawn them correctly with 68% main port width, as this allows greater blowdown area to be gained via the aux ports.
    Out at 72% that has proven to be approx the reliable max width, you loose some blowdown, and gain total area. ( not relevant at all ).
    The problem is that even at 68% you cannot run a flat port roof with 8mm corner radi, as the ring life will be zero.
    Secondly is that it has been proven in many dyno sessions that having all 3 ports open together looses power.
    I can only explain this as a function of the fact that the effective duct length from the outer corners of the Aux is alot longer than that from the main port
    mid point to the header.
    Thus you get a smearing of the initial wave amplitude ( wider but lower intensity ) as it exits the cylinder into the duct during blowdown.
    This reduces the effectiveness of the expansion phase, creating less depression around BDC, and less plugging efficiency as the piston closes the port.
    It would appear that having a 68% main port opening first gives a good, high amplitude wave action in the pipe, then the Aux STA gets the blowdown pressure dropped as much as is possible prior to the Trans opening.
    A few pages back was a drawing I did years ago of a T port with the outer edges higher than the mid point, thinking that this would ameliorate the duct length issue, but later
    testing proved it didnt work well at all.
    So by inferrence even lifting the Aux higher than the main wont fix this issue either in a 3 port.
  8. #11543
    3rd December 2011 - 23:33
    2005 aprilia rs50
    UK
    Thanks, being a fellow air cooled traveler and all, in my heart I would like them to succeed.
    So it looks like they have half a chance, if the challenges F5Dave mentioned dont catch them out.
    If your following their progress please keep us informed as I think its realy interesting.
    Mag has just come out, 21.4 bhp after a few runs on the dyno... .
    On Facebook if anyone is interested, here:
    https://www.facebook.com/groups/prac...5170764195858/
    Dave
  9. #11544
    I have ridden the future today! YZ250 twostroke EFI round the back yard. Video was taken, I'll post a link when it's on line. It's a little more civilized than the Bighorn. Nice and clean power spread. No dyno run yet, just seat of the pants. We have only had about an hours worth of tuning so far.
  10. #11545
    carbon / carbon
    Who knows what about carbon / carbon pistons? Wobb?
  11. #11546
    About zero thermal expansion; good dry friction; because of the lower specific mechanical strength wall thickness needs to be so much higher that any weight advantage is lost. The biggest problem: because of the lower thermal conductivity the crown cannot git rid of its heat, which provokes detonation.
  12. #11547
    7th February 2009 - 17:47
    93 kwacker zxr750
    palmerston north
    l have this book somwhere about a japanese guy making pistons for 500 gp bikes . wish l could find the wright up. 1500 dollars each around 15+ years ago. also made conrods
  13. #11548
    Thankyou, Frits, crazy man, thought as much. I tried ceramic coated pistons some years ago and that's what they did , get hot and help detonation. I wonder about these modern metal sintering ( laser welding metal layer by layer ) apparently you can change the metal as the component is built up. A piston could start off aluminium alloy and end up with say a copper finish layer on top, flash chrome over that. Perhaps?
  14. #11549
    Along these lines
    Nice Yamaha twins site also has the race kit info for the RZ500
  15. #11550
    Today was the Dominic Howe, 20 laps one way then 20 laps in the opposite direction.
Name:	Pit Secrets 047.jpg
    Glen riding Gigglebuttons, from the "Dark Side" Team ESE RS-FZR150 took the honors.
Name:	Pit Secrets 061.jpg
ID:	282663   Click image for larger version.
Name:	Pit Secrets 049.jpg
ID:	282665   Click image for larger version.
Name:	Pit Secrets 050.jpg
ID:	282666   Click image for larger version.
Name:	Pit Secrets 052.jpg
ID:	282667   Click image for larger version.
Name:	Pit Secrets 056.jpg
There are currently 182 users browsing this thread. (0 members and 182 guests)
