Page 771 of 2776 FirstFirst ... 27167172176176977077177277378182187112711771 ... LastLast
Results 11,551 to 11,565 of 41635
  1. #11551
Name:	Pit Secrets 021.jpg
    Garry riding Speedpros 30hp MB100 in leg two looked to be the likely winner of the Dominic Howe and was laying down some super quick times until the rear shock came apart, dumping oil onto the rear tyre.
    During the day Garry smashed the previous lap record of 29.4 with a bunch of 29's then a couple of 28.8's.
Name:	Pit Secrets 075.jpg
ID:	282669   Click image for larger version.
Name:	Pit Secrets 020.jpg
ID:	282670   Click image for larger version.
Name:	Pit Secrets 024.jpg
ID:	282672   Click image for larger version.
Name:	Pit Secrets 027.jpg
  2. #11552
Name:	Pit Secrets 002.jpg
    This Honda GL145 engine in a RGV chassis would have to be the best presented bike there today.
    The field was mostly FXR150s but there were some Suzuki, Honda and Yamahas too.
Name:	Pit Secrets 059.jpg
ID:	282674   Click image for larger version.
Name:	Pit Secrets 063.jpg
ID:	282675   Click image for larger version.
Name:	Pit Secrets 067.jpg
ID:	282676   Click image for larger version.
Name:	Pit Secrets 074.jpg
ID:	282677   Click image for larger version.
Name:	Pit Secrets 044.jpg
  3. #11553
Name:	Pit Secrets 069.jpg
    This is the winner of the F4 GP at Tokoroa ridden by Nat D, 88. Today Nathanael won the first leg of the Dominic Howe but dropped it chasing Garry in the second.
Name:	Pit Secrets 018.jpg
    One of the fast boys who can peddle an FXR like there is no tomorrow.
Name:	Pit Secrets 031.jpg
    There were a few FXR's that have had 100cc Honda engines fitted for F5, they are seriously good and handle very well.
Name:	Pit Secrets 028.jpg
ID:	282683 Click image for larger version.
Name:	Pit Secrets 046.jpg
    Interesting side cars.
Name:	Pit Secrets 072.jpg
    The great thing about Buckets is that everyone pitches in and helps out. Yep that's the opposition helping their main competition get going again.
  4. #11554
    Some Pit secrets, how to mount an FXR150 into a FZR250 3LN frame. Very nicely done and the owner says it handles well and changing to wet wheels is very easy. The FZR 3LN comes std with 2.75x17 front and 3.5x17 rear wheels and 320mm front disk.
Name:	Pit Secrets 043.jpg
ID:	282686   Click image for larger version.
Name:	Pit Secrets 034.jpg
ID:	282687   Click image for larger version.
Name:	Pit Secrets 037.jpg
ID:	282688   Click image for larger version.
Name:	Pit Secrets 039.jpg
  5. #11555
    More Pit secrets, a FZR150 in a TZR frame, these specials are seriously fast.
Name:	Pit Secrets 042.jpg
ID:	282690   Click image for larger version.
Name:	Pit Secrets 033.jpg
ID:	282691   Click image for larger version.
Name:	Pit Secrets 040.jpg
ID:	282692   Click image for larger version.
Name:	Pit Secrets 041.jpg
  6. #11556
    And the one I liked most of all, a RG50 in a Honda RS frame. One of F5 Daves engines fitted by RMS engineering.
    The RG50's rear engine mount slotted straight into the RS rear mount and the front RS frame mounts used simple brackets to hold the front of the engine.
    It also used a light weight hydraulic Mountain Bike rear break with a thumb operated master cylinder on the left handle bar, very clever.
Name:	Pit Secrets 016.jpg
ID:	282694   Click image for larger version.
Name:	Pit Secrets 006.jpg
ID:	282695   Click image for larger version.
Name:	Pit Secrets 007.jpg
ID:	282696   Click image for larger version.
Name:	Pit Secrets 008.jpg
ID:	282697   Click image for larger version.
Name:	Pit Secrets 010.jpg
ID:	282698   Click image for larger version.
Name:	Pit Secrets 013.jpg
  7. #11557
    I would have thought Max was a bit young for buggered ankles
  8. #11558
    7th February 2009 - 17:47
    93 kwacker zxr750
    palmerston north
    thanks for the pic rob , looks like a good days racing
  9. #11559
    Actually the dodgy engineering to hold the engine in is Dave's or one of Dave's bum buddies. From what I understand RMS Eng employs a higher standard of engineering.
    RMS engineering did the tuning work on the engine. And quite a nice job he did. Few more things I would like to change but reliable track time is still more valuable at this stage.
  10. #11560
    21st August 2008 - 21:52
    suzuki RM125S 1975
    auckland
    RG50 motor fitting
    Hi rob i think max fitted the motor in this frame,i did some motor work fitted the pipe and made the seat sub frame,but i did fit the FXR150 motor into the FZR frame for Nick.
  11. #11561
    suzuki RM125S 1975
    auckland
    RG50 motor fitting
    Hi Max you got your reply in before me,what time did you get down to on your 50.
    chris
  12. #11562
    chris
    32.64 I think. Needs some more over rev. Or maybe just some more gear shifting. Or something. It would be good to get it on a dyno so I can see what I am starting with and where it is lacking. Even getting a tacho would be a damn good start. Could have taken elder diprose with a bit more power.
  13. #11563
    The way the motor is mounted is a very clever bit of engineering, I think better than the way we did ours ......
    It was a great day.
  14. #11564
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    Hey everybody.
    Wobbly, can you talk a bit about diffuser angles, ok, we are searching for the widest, lowest pressure around bdc, but in a pratical way...
    For example, Mota Software (even the demo) when calculating a 3 stage header/diffuser will start the second divergent section "difuser" by 37%, and easily give ultra step sharp final 11 and 12º diffuser cone angle. If they work fine? Yes, they are not bad at all. Is the most used program here in Portugal.
    For example, an exhaust calculated for Honda RS specs with 800mm of lenght will have 88 mm of mid section lenght, much more then typical Honda pipes.
    What usualy happens when playing with the mid-section lenght?
    Max pressure at the exhaust port, should arrive sharply as soon as the transfer close or more progressive until the exhaust close?
    Many many thanks
  15. #11565
    Mt Wellington Round 7 Results and David Diproses summary for the series so far.
    Attached Thumbnails Attached Thumbnails Dominic Howe Buckets Round 7.pdf   B Grade Buckets Round 7.pdf   Series To Date.pdf   F4 Buckets Round 7.pdf   F5 + C Grade Buckets Round 7.pdf
