Page 776 of 2773 FirstFirst ... 27667672676677477577677777878682687612761776 ... LastLast
Results 11,626 to 11,640 of 41590
  1. #11626
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    Attachment 282983Attachment 282984Attachment 282985Attachment 282986
    Using EngMod2T I simulated up some of the numbers Bucket came up with when he measured the GP's crankcase volume.
    Attachment 282982
    Blue line is 1.3 primary compression ratio and Red is 1.4 to 1, no other changes.
    1.4 is a crankcase volume including transfer ducts of 517cc using a 105mm rod, 1.3 is 621cc with a 110mm rod.
    I remember Frits suggesting using the crankcase as a plenum and Speedpro talking about the crankcase as a place to store air/fuel untill its needed. I guess I will be looking to add some more crankcase volume to the Beasts engine.
    That is pretty interesting, before we change con rod lenght we should measure case comp, just to be sure it will not go too low.
    being 1.3 the optimun or a baseline for reed induction race engines like was said before.
    Regards
  2. #11627
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    Just heard, its true, TeeZee brought this Dark Side thing of Trademe.
  3. #11628
    I wanted to see if it can be cut down into a side car platform and "now" your going to be the swinger, so
  4. #11629
    we should measure case comp, just to be sure it will not go too low. being 1.3 the optimun or a baseline for reed induction race engines like was said before.Regards
    Better make sure your crankcase volume is not too small. I have seen lots of cases with too little volume, but none with too much yet. The optimum primary compression ratio is probably less than 1.3. And in case you really want to start messing with oil and measuring jugs, you will need this special tool, provided by the engine itself:
Name:	$$$ crankcase volume checktool.jpg
  5. #11630
    In my testing I have found no more power going to a bigger than 1.3 case on a reed engine.
    This is a function I believe of the efficiency of the rotary valve intake system being able to better fill the case at high rpm,using the 1.24 as Frits has described , but having said that
    I have only just crept over 50 Hp with a 125 reed, and the Aprilia RV made alot more than that, so maybe a huge case simply isnt needed at the lower bmep.
  6. #11631
    Leiria, Portugal
    I Never had burned a hole in a piston...
    That is a really low volume crank, the piston is just saying, measure the sh** you have done
  7. #11632
    25th March 2009 - 23:55
    Honda Cub
    Mars
    RS125 Frames available
    All,
    I might be onto a coupole of bare RS125 frames (with swinging arms) available overseas. I have no imemdiate need (though I wish I did), and could probably get them to NZ with minimal fuss (I get a VERY good deal with FedEx - guessing, but maybe for $120-ish for shipping). What would they be worth to someone? There's no suspension or tanks.
    FB
  8. #11633
    Quote Originally Posted by fatbastd View Post
    All,
    FB
    Def be into getting a NX4 frame...........
  9. #11634
    Made it through to the 2013 proposed changes, so maybe it might fly.
    http://www.mnz.co.nz/docs/default-so...e.pdf?sfvrsn=2
    Bert was talking about single event Licenses but amongst the proposed rule changes is this one that appears to allow unleaded pump fuel with 10% ethanol like Gull 10 (http://www.gull.co.nz/fuel-products/gull-force-10/) and 18% other Oxygenates whatever they are.
  10. #11635
    http://toxics.usgs.gov/definitions/fuel_oxygenates.html
    Fuel Oxygenates
    Definitions
    Fuel Oxygenates - "Oxygenates, when added to gasoline, are designed to add oxygen to the gasoline, thereby decreasing vehicular carbon monoxide emissions and oxone levels in the atmosphere." - U.S. Geological Survey, 2006
    Fuel Oxygenates - "Fuel oxygenates are a group of chemicals that raise the oxygen content of gasoline. The presence of oxygen optimizes oxidation during fuel combustion, resulting in a more complete burn and a reduction of harmful tailpipe emissions of partially oxidized gasoline components from motor vehicles." - U.S. Environmental Protection Agency, 2009
    Gasoline Oxygenates - "Gasoline oxygenates have been used in gasoline primarily to improve octane, reduce vehicular emissions and comply with the oxygen requirements of the 1990 Clean Air Act Amendments. While there are many different gasoline oxygenates the ones most commonly used in US gasolines are methyl tert-butyl ether (MTBE) and ethanol (EtOH). Tert-butyl alcohol (TBA) is both a trace component found in fuel grade MTBE, and is also a metabolite of MTBE biodegradation." - American Petroleum Institute, 2008
    Gasoline Oxygenates - "Oxygenates are man-made chemicals that are added to gasoline to make it burn more efficiently. Adding oxygenates to gasoline increases the gasoline's octane level, and reduces pollutants (particularly carbon monoxide) emitted from motor vehicles ... Most oxygenates are either alcohols or ethers, which are readily soluble in water. Two commonly used oxygenates are ethanol and MTBE (methyl tert-butyl ether)." - New York State Department of Health, 2006.
    Ok found this on Oxygenates, good old Google ....... 10% Ethanol plus 18% other Oxygenates, nothing in the rules that say I can't add my own Oxygenates only that there can't be more than 10% Ethanol and 18% of other Oxygenates ...
    Hmmm I like this, a high octane fuel that is much cheaper than Av gas and I can run my fuel injection O2 sensor with it, watch this space.
  11. #11636
    10.1.3
    At all times the onus is on all competitors to ensure their machinery has enough fuel onboard
    to complete any race
    they start in, including allowance for any restarts that may occur, penalty for running out of fuel during any race, first
    offence will be an instant fine of not less than $400.00
    Reason: New rule
    That's a bit of a interesting rule..............
    Whats the point............
  12. #11637
    Nope.
    24-2-5 Fuel: See 10-17-1
    Alcohol based fuel or fuel additives are prohibited.
    Stupid rule. Why not change it to "only commercially available pump fuels may be used for this class". Would keep the cost down and the lead out!
  13. #11638
    31st July 2005 - 11:15
    a shed full of crazy shit
    10.1.3
    Reason: New rule
    Having been in the control box at minefield (with others on this forum). It was the lowest point (most sickening) in my involvement with motorcycle racing; while not the first time this one had the most impact on my views... This is a good control measure by MNZ to attempt to reduce the possible occurrence of this happening again.
    Have a read in the racing section.
    Quote Originally Posted by Billy View Post
    Yip,But,That was the coroners recommendation following the deaths of Derek Hill and Phillip Harrison at Puke in 08,No action was taken following that recomendation and since then we've had a similar situation at Manfeild which resulted in another death,Not a good look,Its an easy fix,Just deal with it.
  14. #11639
    In my testing I have found no more power going to a bigger than 1.3 case on a reed engine. This is a function I believe of the efficiency of the rotary valve intake system being able to better fill the case at high rpm,using the 1.24 as Frits has described.
Name:	1-24 Primary CR.JPG
    Ok with my EngMod2T rotary valve simulations, 1.24 is better than 1.30 but interestingly 1.29 and 1.28 were worse than 1.30.
  15. #11640
    Don't worry Romeu, you're still young; you'll get your chance yet. BTW, it wasn't my piston; just a picture I picked up from the internet.
There are currently 40 users browsing this thread. (1 members and 39 guests)
  1. Sketchy_Racer
