Page 791 of 2773 FirstFirst ... 29169174178178979079179279380184189112911791 ... LastLast
Results 11,851 to 11,865 of 41594
  1. #11851
    The pic is showing how I lay out the sections to fit a pipe onto a bike in CAD - the part I hate,welding and hammering comes later.
    Then the sheetmetal function in SolidWorks generates the patterns.
    The design is to try to get the fat part of the belly forward, away from the chain and swingarm, so the diameter can be way bigger - more power egor.
    Its being cut out soon, but it looks like I will be in Waikato Neurosurgery having an op on my spine to try and " fix " me,so wont get welded for a few weeks.
    I will post a pic when they and I ,are done.
  2. #11852
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    I love working with solidworks too, but wound't I need to have the coordinates of the frame, chain, swingarm, engine, etc to simulate and to fit the exhaust...!?
  3. #11853
    Looks better than building them with No.8 wire & wire donuts like I've done.
    Good luck with the op.
  4. #11854
    If you look at the pic you will see a construction geometry sketch within the assembly.
    This was measured directly off the exhaust port face, and sets where the clearance is needed under the engine, and the exit angle of the port.
    Then I did an alloy welding wire centreline with cardboard circles, measured this, and that is on the sketch as well.
    The pipe doesnt need to follow the centreline exactly, the important deal is the smooth shape, and ultimately has to clear the swingarm etc.
    In this design, due to the forward push on the header, the smaller diameter part of the rear cone is well away from the chain etc, so will bend up close to
    the footrests, getting tucked in as much as possible.
    This allowed the design to go up to 125 belly diameter, a stock TZ, even with crossovers, is struggling to fit at 110 max without dents all over the place.
  5. #11855
    Remote PJ solenoid:
    So I've got my whappin great KX carb sitting on the shelf & as I'm finally getting around to fitting my Ignitech (MB100) I'm thinking about the next steps. I've decided I need some more work before I fit the 36mm so want to retain my RGV carb for the moment. (& ideally on the 50 that has zero over-rev)
    It (RGV downdraft Mikuni) has a jet fitted PJ tube external exit out the floatbowl. It feeds into a hole at the top of the carb, but I can poke a tube into the venturi at a better position than std.
    But what would be cute would be a small external mountable solenoid to block the flow, as long as I could robustly bolt it to the side of the carb. The Keihin one doesn't really suit that adaptation.
    Any thoughts?
  6. #11856
    Remote PJ solenoid:
    Any thoughts?
Name:	Tuakau  5-6-13.jpg
    I put the plug lead on and the spark plug is for size comparison and its maybe better suited to bleeding air into the PJ valve to kill the suction than directly cutting the fuel but this little 12V 360mA item from JayCar ($32 from memory) was what I was planning on using with my IgniTec for a PJ cut off.
  7. #11857
Name:	Tuakau  5-6-13 013.jpg
ID:	283694Click image for larger version.
Name:	Tuakau  5-6-13 016.jpg
ID:	283695Click image for larger version.
Name:	Tuakau  5-6-13 017.jpg
    Three holes for the injectors and one screw to hold it all on, how hard can it be??? but it has taken me ages to get it all figured out.
    I am looking forward to getting the rest of the bits and trying the EFI system out. There is a bit of finishing to do, but hopefully I will be able to get a more or less back to back comparison on the dyno with the old carb.
Name:	Suzuki GP125.jpg
    Found this on the net, looks like there are still a few good looking original Suzuki GP's about.
  8. #11858
    Remote PJ solenoid:
    Any thoughts?
    Ten carrots
    Right i had a wee search on the net.
    The genuine kit is a little expensive, I couldn't find the Keihin but here is the Mikuni, as you know i had already posted this.$303nz.
    Maybe the Keihin kit is less expensive.
    I haven't had the chance to look through Sudco yet.
    Had a wee look at Sudco it seems the soilniod is not listed as a separate part bugger.
    Here is one from the UK Mikuni person no prices.
    http://www.allensperformance.co.uk/p... jet kits.html
    I also found this with the dimensions of a lot of inlet manifolds etc
    http://www.allensperformance.co.uk/p...manifolds.html
    TZ's keihin copy carbs i believe have a Powerjet the obvious way to me for a budget conscious bucket racer would be to modify this for electric use with a car solenoid.
    There is another option but i am not posting that until i have got one myself.
    Nice explantion on powerjets
    here no that theres anything wrong with wobs.
    http://superkartaus.com/Forums/index...opic=77.0;wap2
    Adjustable powerjet it looks like it would be easy to make as well addthis with an electric controll or just adjust the pulse to your needs as Wob said would be very6 Sexy but prob a bit OTT.
    http://www.twostrokeracelab.com/sear...ble%20Powerjet
    The rest of the site is well worth a look as well.
    Here is a 12volt solenoid that looks capable assuming there isn't a car wrecker part to suit around.
    I have priced the Genuine Mikuni kit a $200 US so it is a tad expensive.
    Remember though what ever the set up it has to be so if it fails it will not lean out the mixture.For obvious reasons
    Tubular 12V Solenoid
    Compact size, Push type.- Coil resistance 25.6- 20 watt @ 25% duty cycle.- Pushing force 220 - 940g (25% duty cycle).- Stroke 1.0 - 6.0mm (25% duty cycle).- Total weight 23g.- Full data supplied with unit.
    QTY
    1+ $41.90
    5+ $37.90
    10+ $33.40
    http://www.jaycar.co.nz/productResul...3&keyform=CAT2
    Of course if stepper motors are more your deal there is this.
    [IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/IMG]
    12VDC 48 Step / 7.5° Stepper Motor
    • Standard 48 step / 7.5° design.
    • Flange mount 3.0mm hardened steel shaft.
    Specifications:
    • Rated voltage: 12VDC
    • Rated current: 1.1A/phase
    • Phases: 4
    • Steps per revolution: 48
    • Stepping angle: 7.5°
    • Drive method: Unipolar chopper drive
    • Resistance per winding: 20 ohms
    • Starting frequency: 600pps (max)
    • Holding torque: 700g/cm
    QTY
    1+ $23.90
    5+ $21.30
    10+ $18.90
    http://www.jaycar.co.nz/productView....r&form=KEYWORD
    With todays technology the bar can now be raised to around 40 crank Hp without too much drama involved, and thus achieving around 35 RWHp.
    The alloy inserts for the TZ350 was the customers choice - once its all proven, and we get a handle on what the engine likes, then I will do some bronze ones.
  9. #11859
    Nice bike but hard to imagine as a fire breathing monster, these little old Suzukies are a real wolf in sheeps clothing.
    30+hp then EFI, this would have to be a World first for a commuter bike from the 80's.
    I hear there is another radical mod or two coming, but what could be even more radical than this ....
  10. #11860
    27th January 2011 - 11:30
    asdasd
    AKL
    Haha that really cracked me up. That's my old man Simon having a crack around the driveway before it all came apart as the donor for my RS-GP125. It definitely looked in better condition in the photos than in real life
  11. #11861
    Haha that really cracked me up. That's my old man ...
    Yep I thought it was pretty good too, seeing him on the net....
  12. #11862
    Thanks for ideas gen kit looks good but too spendy for me. Pretty tall too. Air bleed not right for gas . OThers require a seal on end and machined seat.
  13. #11863
    dads been talking about 2 stroke fuel injection (thinking he was the first)
  14. #11864
    ETec is insanely superb patented technology, the dickheads in the other video gave up as they couldn't get it to " work " even though they were touted as the next best thing to sliced bread on track.
    Mixed wotnots and sarcasm fully intended.
  15. #11865
    That PV blade directly opening the auxiliaries is quite cute.
    Lozza often says the Gas Gas (i think it was the gas gas or maybe tm?) system is the ducks guts (Just like the mad max interceptor)
    how does that one differ?... two stage blades? Never seen one Must google it........
    is it a cross between the Kawa kips on the KR1 and the Blade PV?
