Page 800 of 2773 FirstFirst ... 30070075079079879980080180281085090013001800 ... LastLast
Results 11,986 to 12,000 of 41590
  1. #11986
    Wow that 350 is impressive.
    The last graph is not valid though, can't compare things with different gearing. Have to get ign trace going on both to make sense of it.
  2. #11987
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    Cool
    Attachment 284277Attachment 284278
    EFI YZ250, (the graph is in mph because I could not easily get an ignition timing signal for rpm, next time).
    Attachment 284276Attachment 284279
    EFI Kawasaki F86M 350 Big Horn from the 70's.
    Attachment 284275
    Yamaha blue line, Kawasaki red.
    That kawa should be a monster to ride 8)
  3. #11988
    Leiria, Portugal
    Wob, I need your help.
    I have a 9.7cc Honda RS head that I am not using, and now I have got some VHM domes, I am thinking in milling the 9.7cc head and fit the domes.
    What tolerance should I use between the head and the outer diameter of the domes?
    Thanks
  4. #11989
    Page 800 ...
    Where I have got to with the EFI fuel injection system. You will have to click through to the original posts to see the attached pictures.
    TeeZee if your getting into fuel injection there is a whole new language and concepts to learn.
    Like “Speed Density” and “Alpha-N”, VE Volumetric Efficiency Table, AEM’s, IAT’s, TPS, VTA and how to use Excel spread sheets for smoothing 3D plots in CSV format.
    Something below I scraped of the net to give you the idea……
    Speed Density. So after much thinking about how to explain what true Speed Density is vs what we do here for instance, how AEM's are often setup, etc. I came up with the following idea, just explain what everything is and remove doubt.
    MAF - if you dont know this one its a volume sensor. Thats it. Ours have IAT and a baro comp to make it more accurate but it simply measures volume entering the engine. If there are boost leaks its inaccurate, doesnt like VTA (letting metered air leave without pulling fuel), all the stuff we know.
    Alpha-N - TPS x RPM. That is all that is with no VE compensation (i.e. boost). If I tell it that at 100% throttle and 6000 rpm it does it at all boost levels independent of air volume.
    Speed density - estimates air mass by pressure vs temp. Then applies this to a 3D map. The "3D" we already have, its Load (pressure or volume) x RPM with a set value in each cell. Every point can be fine tuned so this is really Alpha N with compensation. Any VE changes needs a retune, doesnt matter the system. It only knows pressure and rpm not what the true mass of the air is (it has a trim table and most get ignored above certain levels).
    I use the fuel temp sensor to mimic an IAT since its already in the car. The IAT reads gross temp not average. It can heat soak, be subject to a meth jet to close, all sorts of little issues. The actual trim table in the Evo ECU really isnt setup for IAT trim anyway. It has an algorithm that allows for minor alterations to fueling since its set for a MAF, and then trims timing vs air temp.
    Fuel temp is more or less constant. The fuel heatsoaks going thru the rail hits the tank and then is sent forward again. It takes 15 minutes to get full heat into the fuel system (ask anyone with an A1000). It is a rough average of engine bay temp which is what the MAF does factory. I have done exhaustive testing and see no more than 5-6* variation from fuel temp as a source to what the MAF would read in the corner of the engine bay.
    Now for the term everyone has been waiting for, Boost Comp. This is what MAFs do, most SD setups (AEM, Motec, Autronic, Vipec, etc.) do for fueling. It assumes VE is more or less constant until you hit backpressure in the turbine housing, head flow, cam size, and VE starts to drop off again.
    I set the fueling at 16psi and in our maps this is 180% load or so. The values are constant out to 38psi. Hyper Boost Compensation is the proper name. Retuning is as easy as altering either the max boost portion of the MAPVE table to allow more or less fuel vs pressure, and in some cases the tip in portion of the MAPVE (121kpa column).
    There is no such thing as true speed density. I havent seen any AEM ever do this or any other standalone. GM is the closest to True SD and its because tada they use a MAF as well to judge volume vs pressure.
    There is also Alpha-N with Boost Comp. This is more or less what we do EXCEPT IT HAS NO TEMP input. It is solely rpm x TPS x pressure. Since we aren't doing fueling by TPS vs RPM at any point other than accel enrichment it is not accurate to call the SD we normally do on Evos Alpha N or N-Alpha or Alpha-Omega or whatever. Alpha N is different and is normally something reserved for ITB cars or quads (single cylinders) that have really non specific fueling and just need fuel vs tps x rpm.
    Often we deal with the question, "Which is better speed density (SD) or mass air flow (MAF)". As with most things in life there are advantages and disadvantages for both. Its better to understand each strategy so as to make the most informed decision.
    Mass Air Flow
    Mass air flow sensor equipped cars fuel either directly from or by a blended model of both mass air flow and speed density calculations. The MAF sensor is located somewhere in the intake stream typically away from sharp bends and typically at least 8-10 inches away from the throttle body however these rules are not always followed. There are several different types of MAF sensors but for most GM applications it is a frequency biased "cold-wire" sensor that generates a signal between 0 and 15k Hz. MAF sensors read not just airspeed but the relative mass of the air which eliminates pressure and temperature as variables. They are usually positioned to sample from the middle of the intake tubing which should give the best average reading.
    Since the MAF sensor samples from a specific spot in the inlet tubing changing the airflow in or around the sensor requires recalibration of the MAF sensor. Changing the airflow around a MAF sensor can be caused by a change in size of the intake plumbing, bends before or after the MAF sensor, and changes to the MAF housing.
    Several applications that use MAF biased strategies also use Speed Density as a backup or for a blended fuel calculation. They also use Speed Density as a sanity check for MAF readings.
    Advantages
    Typically more forgiving and easier to tune
    If the MAF sensor has been calibrated typically fueling remains consistent as modifications change. It can be said that the MAF equipped cars are a little more forgiving to new modifications
    Since the MAF sensor measures air mass directly it can be said that a MAF equipped car might stay in calibration as the engine wears or in extreme environment changes (however this is not normally a concern for well tuned speed density applications).
    Disadvantages
    Sensitive to changes to the intake plumbing
    Can be fouled by becoming dirty. Once fouled MAF calibration is skewed
    Sensitive to cam reversion on large cammed cars. The MAF sensor isn't directional so air pulsing back and forth can affect repeatability and reliability.
    Limits on performance. Most systems can not read at higher horsepower levels.
    Speed Density
    Speed density systems calculate the density of the air first by measuring the temperature of the inlet air and manifold pressure. With the density of air known the engine controller then looks up how much air it expects to be moving at a specific engine speed and manifold pressure. This is done in the Volumetric Efficiency table or VE table. Traditionally the VE table is 3D and has two axes Engine Speed (RPM) and Manifold Pressure or % Load. A engine that is 100% efficient moves exactly its displacement every two rotations in 4-cycle engines.
    Advantages
    Less restriction in the intake tract
    More freedom in the intake tract
    Able to measure air consumption on very high horsepower builds where a MAF sensor might be limited.
    Able to read boost if equipped with a greater than 1 Bar map sensor
    Free from errors encountered in MAF fouling.
    Works better with large cams where reversion affects reliability.
    Disadvantages
    Is a little more difficult to tune
    Relies on a well tuned Volumetric Efficiency Table
    Less forgiving to new modifications to the engine
    Might have errors in large weather changes however a proper tune makes this minimal if any error.
    There are several vehicles that come with MAF sensors from the factory and there are several vehicles that come speed density from the factory. Really which fueling strategy you should go with on a aftermarket application is up to your modifications goals and expectations. If you are not the one to be tuning your setup please consult with your tuner for what he or she recommends.
    Speed-Density is a method of estimating airflow into an engine in order to supply an appropriate amount of fuel and adequate spark timing. First, vocabulary:
    ECM, ECU, Engine computer : used interchangeably to mean the computer operating the fuel injectors and running the engine
    RPM : Revolutions Per Minute – how fast the motor is spinning
    MAP : Manifold Absolute Pressure – (usually) the pressure of air entering the motor
    ECT : Engine Coolant Temperature sensor – sensor used to measure the temperature of coolant circulating through a motor. Sometimes called different things by different manufacturers. I will use ECT here
    IAT : Intake Air Temperature sensor – sensor used to measure the temperature of air entering the motor. Sometimes called different things by different manufacturers. I will use IAT here.
    Displacement : the volume swept by a piston descending from the top to the bottom of the cylinder bore. More here.
    AFR : Air Fuel Ratio – the ratio of air to fuel present in a combustible mixture. Usually stated as a ratio, i.e. 14.7:1 for the stoichiometric AFR for gasoline. Stoichiometric AFR varies from fuel to fuel.
    Lambda : similar to AFR, except usually expressed as a number where 1.0 represents a stoichiometric mixture for all fuels. Lambda and AFR are the same concept expressed in different units.
    Stoichiometric : a mixture containing the precise amount of oxidants required for complete combustion of all fuel present. See here or here for more information on chemistry involved.
    Ideal Gas Law : PV= nRT (Pressure times Volume equals moles of gas times ideal gas constant times temperature) More to be read about this here.
    Moles : a measure of how many atoms are present. See here.
    Induction stoke : the part of a 4-stroke engine’s cycle in which air is drawn into the cylinder by the piston. See here for more information if you are not familiar with a 4 stroke engine’s operation.
    Basic Goals and Method
    The goal of Speed-Density is to accurately predict the amount of air ingested by an engine during the induction stroke. This information is then used to calculate how much fuel needs to be provided and may also be used for determining an appropriate amount of ignition advance.
    The theoretical basis for this is the Ideal Gaw Law (more here.) rearranged to solve for “n” (the number of moles of gas present :
    n = PV / RT
    In order to use n = PV / RT to calculate the amount of air a motor ingests during the induction stroke we would need:
    P is pressure in the cylinder immediately after the intake valves close.
    V is volume, which we know from engine displacement.
    R we know (it’s the Ideal Gas Constant see here for more)
    T is the temperature of the gas in the cylinder immediately after the intake valves close.
    Many of the things required to calculate the amount of air the engine ingests using the ideal gas law are missing, unavailable or at least incomplete. Some notable points where reality is less than ideal:
    Our MAP sensor measures the pressure differential caused by the downward stroke of the piston in the intake manifold, not pressure in the cylinder as the intake valves initially close.
    We are assuming that there is no residual exhaust left in the chamber to contribute to “poisoning” of the intake charge.
    Camshaft overlap (i.e. when both intake an exhaust valve are open simultaneously – see here) makes fluid flow modeling considerably more complicated.
    T that we need is the temperature of the gas in the cylinder. This is not usually MEASURED – instead it is ESTIMATED from the temperature of air in the manifold (IAT), the temperature of the cylinder heads (ECT) and other factors. “RT” is often referred to as the “density correction term” as it tries to account for how air density varies with temperature. Density correction is arguably one of the biggest problems with speed-density. (more on this later)
    Speed-Density introduces the concept of Volumetric Efficiency (VE) to account for the differences between what it can observe and what is really going on. (mostly problems 1-3 above) Roughly speaking, VE is the ratio between the amount of air actually present in the cylinder and the amount of air we predict would be in the cylinder using MANIFOLD pressure (MAP) instead of cylinder pressure for our “P” Pressure term, REVOLUTIONS Per Minute (RPM) times Displacement (Volume / REVOLUTION) for our “V” term and an air temperature value estimated from some combination of ECT and IAT for our “T” term.
    A motor said to be operating with 100% VE has the same amount of air actually in the cylinder as predicted by n = PV / RT. Most engines operate at considerably less than 100% VE in most operating conditions. The difference between actual airflow and theoretical maximum airflow is termed “pumping loss.” Some engines (most notably Honda engines ) can achieve slightly greater than 100% VE in certain conditions. Most engines operating under forced induction can be thought of to have a VE greater than 100% in some conditions.
    Speed Density ECMs generally have one or more VOLUMETRIC EFFICIENCY (VE) tables that are a critical item to be adjusted. These tables allow predicted airflow values to be more closely adjusted to observed reality.
    Strengths of Speed-Density
    Speed-Density has many things going for it:
    Pressure sensors do not pose any restriction to the flow of air into the engine, unlike a MAF sensor.
    MAP sensors respond to changing conditions very quickly, enabling it to have fairly good transient response especially compared to Mass-Air-Flow
    Compared to a carburetor, it allows much more control over the mixture at different engine loads
    Simplicity: all the sensors required are extremely reliable.
    Weaknesses of Speed-Density
    Speed-Density is known for having several notable issues:
    Density correction, density correction, density correction. You might not think that temperature is that big of a deal, but trust me it is! Seasonal changes can wreak havoc on speed-density systems. Superchargers or turbochargers that compress air and raise its temperature from adiabatic heating cause significant changes in density that must be accounted for. Altitude can also be really problematic. Many systems incorporate Barometric Pressure sensors to try to address this, but it’s an imperfect correction.
    Large camshafts with extremely low vacuum due to high overlap close to idle. Camshafts that have low or pulsing vacuum close to idle present a challenge for Speed-Density. MAP sensor averaging can help. Alpha-N blending can help. It is still very tricky to use speed density to predict airflow with a pressure sensor with camshafts that do not build an appreciable amount of vacuum.
    Volumetric Efficiency tables can be very time consuming to tune.
    Engine modifications generally produce volumetric efficiency changes requiring re-tuning.
    Quite a lot of math is required to do Speed-Density “by the book.” Because of this, most manufacturers implement something kind of like theoretical speed-density and cut corners or combine math operations in order to allow faster execution on puny computing hardware. (Remember, most ECUs made prior to 2000 have a slower processor than the average inexpensive cellphone circa 2010)
    Sanity Checking a Speed-Density Tune
    There are a few rules that transcend particular manufacturer implementations:
    Volumetric efficiency rarely changes suddenly. VE tables should almost always have very gradual changes.
    VE usually DECREASES as pressure DECREASES (i.e. more vacuum = less VE)
    VE usually maxes out at an RPM close to peak engine torque at maximum observed load, which is usually where peak cylinder filling occurs.
    Remember that VE tables are not the only thing that controls fueling. Temperature correction tables (ECT, IAT) are often implemented as multiplier/divider tables. Don’t forget about injector battery tables either! (see the separate article on Injector Tuning for more on this)
    Alpha-N
    An Alpha/N table allows the ECU to calculate some sort of output based on any combination of how much the throttle is open (Alpha), and how fast the engine is spinning (N). The Alpha term can range from 0% (closed throttle) to 100% (wide open throttle). The term "N" corresponds to engine RPM.
    The two main Alpha/N tables are used to determine ignition advance and fuel injector pulse width. An Alpha/N ignition table would use throttle position and RPM to calculate what spark advance it should be using. Similarly, an Alpha/N fuel table would use throttle position and RPM to decide how long the fuel injectors should stay open.
    Throttle Angle
    The throttle angle term was tougher to figure out. While the RPM rows were spread out evenly across the operating range, the throttle angle columns were not. There is a good reason though. If you think about it for a minute, a difference in throttle angle is not a simple linear change like RPM. For example, changing the throttle angle from 1% open to 2% open is a huge difference (100%, in fact). Compare that to changing the throttle angle from 90% open to 91% open, which is only about a 1.1% difference. What this really means is that the effects of throttle changes are concentrated mostly in the range of small throttle openings. In contrast, at large throttle angles, the same small changes are almost meaningless. Therefore, the throttle angle, or 'Alpha' part of the table is strongly stacked towards providing lots of information at the end of the scale where the throttle is barely open, and has much less information about situations where the throttle is open fairly wide. This also makes sense when you consider that much of what a rider considers as 'driveability' issues occur when cruising down the road with the throttle barely open. Giving the ECU extra information about part-throttle situations makes for better driveability.
    Alpha-N uses the throttle position (alpha) and RPM (N) to calculate the amount of fuel to inject as opposed to using the manifold absolute pressure (MAP) and RPM to calculate the amount of fuel to inject. Alpha-N is useful for long duration cams where the resolution of manifold air pressure (map) would be small.
    Manifold Absolute Pressure, then, is just what it says: The absolute pressure which exists in the inlet manifold, usually measured in the plenum (if one exists). The MAP in an engine which is not running is equal to atmospheric pressure. If, on a "standard day", an engine is idling at a measured manifold "vacuum" of 14 inches,, the MAP is actually 15.92 "HG (29.92 - 14 = 15.92).
    1 atmosphere = 760 mmHg = 29.92 inHg = 14.7 lb/in2 = 101.3 KPa
    I think you would be pretty game to try anything other than an 'Alpha-N' setup. Pulsing on a single cylinder will make the engine hunt and low rpm. And MAF will restrict your inlet and is heavy as balls.
    And download matlab instead of excel. Much better at dealing with large matrices.
    Thanks Bucket and Mooools
    To get started, most of the info for VE, Speed Density and Alpha-N maps can be gleaned from the EngMod2T simulations.
    Because of the pulsing in the inlet tract that Mooools talked about and which is particularly bad in a 2-Stroke, the Fuel injection system we are getting has a Speed Density map for low RPM and uses Alpha-N for the high RPM end.
    I have been told that as an optional add on, it can also have a mixture adjustment with exhaust temperature option. I am not sure how that works but hopefully it means we can give it a target ET and it will maintain it just like Wobbly has talked about for maintaining optimum AFR with changes in conditions during the day.
    I am not sure how the injection timing works but the system triggers from the existing ignition pickup. Because I want to inject into the transfers while the are open and flowing, I guess it will be easy enough to fit a dedicated trigger at some other point to get the injection timing right.
    Anyway hopefully Chambers and I will have our kits by the end of the week.
    Chambers and my EFI stuff turned up today, only 4 days delivery time and it was Easter, how good is that! real good!
    All the bits.
    RF Shielded CPU
    We checked and yes, the light you can see through the throttle body is equivalent to a 24mm carb.
    Here are all the bits connected up on the wiring loom, real simple, real easy.
    As an optional extra we got a wide band O2 kit to help with tuning on the dyno.
    Some more lovely odds and ends that are in the kit.
    This is where I have got to with my simulations for the EFI map data.
    These start at 500rpm but I have not displayed the bit below 5,000 rpm because its pretty much all the same and a bit boring. And who would have thought that the engine would rev further on smaller throttle openings.
    Because the gaps are getting bigger, when I have finished this series I will have to go back and do some in between ones for the lower throttle settings.
    Power Curves
    Which data will you take from the sims to feed the ecu with?
    RPM, TPS VE and Fuel ...
    Here is Fuel vis RPM and TPS.
    There is a lot of good information to be gleened from the EngMod2T simulations that will be usefull in prepairing the initial Maps for the EFI.
    http://www.freepatentsonline.com/6691649.html
    Free Patents Online is a bit of a gold mine of ideas, its worth a look at the Two Stroke stuff.
    Fuel injection runs again, The YZ 250 EFI port injection lives.
    Congratulations ... that makes it two, home brew, competition 2-Strokes running EFI that you have put together.
    Injector Sizing and Locater page
    http://www.nitrostreet.com/injectors.htm
    A place to go to, to calculate the size of injectors needed.
    Because it is a 4-Stroke site and assumes a full 100% duty cycle of 720 degrees as apposed to a 2-Strokes 360 degrees I had to halve my required duty cycle to get a 2-Stroke result.
    Ie., my designed maximum duty cycle is 120 degrees or 33% then instead of 0.33 I had to enter 0.16 in the Duty Cycle field.
    It was pleasing to see the numbers came out to be the same size as I had previously calculated from the simulated EngMod2T fuel demand curves.
    DIY EFI ... might be worth a look. http://www.diy-efi.org/
    EFI links list here. http://www.nitrostreet.com/efi.html#...20for%20PC%27s
    Things I am learning about EFI ..... edited scrapes below.
    Speed Density
    There are several different ways to control the air/fuel ratio. Speed density requires just two main inputs to establish a base fuel map: engine rpm and load. Speed density assumes that a certain amount of air will enter the engine at any particular combination of rpm and load.
    This works as long as the engine remains unchanged. Modifications to the engine to increase airflow (and therefore power) at any point would tend to make the engine run lean, since the engine would inhale more air at that rpm and load point than it did when it was stock.
    If you take in more air, a proportional amount of additional fuel must also be delivered to maintain the same air/fuel ratio. Speed-density systems cannot perform this function without reprogramming.
    Mass Airflow
    Systems outfitted with a mass airflow (MAF) sensors. This sensor measures the amount of air entering the engine, giving more precise control over the air/fuel ratio. MAF systems are more accurate.
    Alpha-N
    There is one other EFI control system that is generally used only in racing called an Alpha-N system.
    This control system’s major inputs are throttle position and rpm. This system was developed because race engines often operate at idle and part-throttle with very little manifold vacuum.
    This makes using a MAP sensor difficult. This system is less precise than speed density or MAF and is therefore generally only found in racing or on heavily modified street engines with big camshafts. A MAP sensor can still be used with Alpha-N, but it is generally employed as a barometric pressure sensor to detect altitude changes.
    16 x 12 Input Tables or Maps for my EFI unit.
    All the variables RPM, MAP, TPS, Load, VE and Lambda values can be adjusted.
    Speed Density Map
    Alpha-N Map
    Desired Lambda Map
    I am trying to get my head around these and figure out how much info from the EngMod2T graphs I can use here.
    This could be a useful place for those contemplating fuel injection
    http://www.efihardware.com/index.php
    http://www.ecotrons.com/2_Stroke_Small_Engine_EFI_kit.html
    I have been trying to figure out how to go about the initial mapping of my 2-Strokes EFI as I want something that is at least close to the ball park, to kick the whole EFI tuning process of with.
    First up I need to build the Speed Density map which plots VE (volumetric efficiency) against RPM and MAP (manifold absolute pressure). The big problem is, VE data is not all that easy to get.
    But they say you can determine VE from dyno data which is handy because I have a virtual dyno, EngMod2T.
    Not to sure about what I am doing, so rightly or wrongly, this is how I have gone about it.
    At the moment EngMod2T does not give a VE (volumetric efficiency) vis MAP graph but it does plot DR (delivery ratio) which is basically VE at atmospheric pressure. So I simulated a whole lot of runs at various atmospheric pressures to simulate changes in MAP to see if the engines VE (DR) changed with changes in pressure.
    It didn't much, which is no surprise really as the DR or VE is just a ratio between whats theoretically possible at that pressure and what happens in reality. As the pressure changed the proportion of inside air to outside air remained much the same.
    But of course the Power dropped of with decreasing atmospheric pressure (simulated MAP).
    Because the Speed Density map is more about the lower RPM range I broke the standard atmospheric pressure DR graph into two parts and maximized the scales so I could see them better.
    I made up a spread sheet using the DR values at Standard Pressure (1013) and proportioned them across the pressure range from 300 to 1050.
    This is the Formula I formulated. (Actual Pressure / Standard Pressure) * Delivery Ratio ... for each RPM/MAP point.
    And entered the values into the EFI's 16 x 12 Speed Density map.
    Nice picture, I have no idea what the colors mean. But if you look along the blue edge you can see it pretty much mimics the DR (VE) EngMod2T graph. Hopefully that means I have got something right.
    Only Lambda, Load, and Alpha-N maps to go.
    Alpha-N EFI Map
    Finally got the Alpha-N Load map, mapped against TPS and RPM.
    Another colorful map. You can see the effect of the pipe going in and out of resonance as the RPM goes up.
    Delivery Ratio Graph of multiple runs done in EngMod2T at different TPS (throttle) positions. The colorful Alpha-N map pretty much follows the EngMod simulations.
    To get the resolution required I used the EngMod graphing options to expand selected sections of the graphs.
    I have been trying to figure out where to place the injectors. My EFI setup calls for two injectors, one small and one big so its a bit of a puzzle to figure out where best to put them.
    I needed a fuel rail and got this Honda Civic (D16Y8 engine) rail with 240cc saturated high impedance injectors and fuel regulator off Trademe. All sorts of injectors will fit this rail and it can be shortened up to suit my engine.
    A bit of info on injectors and spray patterns.
  5. #11990
Name:	EFI YZ250 vis EFI F86M.jpg
    the graph is not valid though, can't compare things with different gearing. Have to get ign trace going on both to make sense of it.
    True and not so true, depends on what your looking for.
    From this graph, what you can say is, if they are both riding the same trail, the Kawa is able to hold a gear for longer than the Yam.
  6. #11991
    Exhaust bridge oiling holes
    So say you fitted a piston from a cylinder designed for a bridged exhaust (like a rm125) to a single port barrel like a h100, and didnt bother to glue the oiling holes closed, what is the downside ? how much would be lost, would it even run? Any theories or experience?
  7. #11992
    Not sure if Team ESE have actually tried that but TeeZee is having lots of problems with his cylinder and its looking like an imperfect seal between the piston skirt and exhaust port and crankcase is causing the problem.
    Anyway its so easy to glue the piston to seal the bridge oiling holes with devcon F, why wouldn't you do it. TeeZee has shown it lasts OK too.
  8. #11993
    I ran a rm piston but didn't block the hole. Never got around to before and after, didn't expect Devon to last back in the day. Hope it's an air cooled RM piston Mike.
  9. #11994
    OK thanks, heres the rest of the story, a young guy at work bought a H100 to ride to uni but the barrel was a bit rooted, I bored it to 54mm for a rs125 piston but went a bit oversize Brendan had a rM125 watercooled piston so that saved my arse when it measured 54.25mm but it had bridge oiling holes , well so did the rs piston I guess I was just in denial about plugging them. So long as the bike goes like a stock h100 all will be well, he may just need to re ring it from time to time
  10. #11995
  11. #11996
    The H100 liner is bloody thin at 54mm Mike...cracks WILL appear....
  12. #11997
    I didnt really check , I just assumed it was as thick as the spigot
    he can always bring it back, Ill send him down to KGs to buy another one !!
  13. #11998
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    That is awesome, i'm still impressed by the old 350, that thing would had some punch!
    I noticed that it *seems* like it really brick walls at the top end of the rev range, is this just the sound of the video making it sound flat or does it not have a lot of over-rev?
  14. #11999
    It's hitting the rev limiter and the last fueling square is a bit rich I think.
    Yes the Kawasaki is a lot of fun to ride, certainly some modern bike riders don't expect to see this old bike accelerate like it does although as soon as it cuts up rough, I'm out.
  15. #12000
    Suspension is easy fixed, emulators in the front and a pair of YSS at the rear
There are currently 46 users browsing this thread. (1 members and 45 guests)
  1. koenich
