While we're talking heads & leaking; I have an aircooled head I've converted to LC. I've porpoisely avoided welding in the chamber (or anywhere if I've been able to avoid it). Sadly there are a couple of pinholes exposed in the original casting once its been skimmed & reshaped. They lead through to the water chamber & pressurising the head in a bucket of water shows some tiny bubbles. Just on the edge of squish & just in the chamber.
Do you think they will block with carbon? I can't see much volume escaping through such a tiny passage, but the pressure is considerably more than my testing pressure. That said, ring gap is vast by comparison.
Sodium silicate "Water glass" is used to make sand casting cores solid, available cheap from pottery suppliers about $7:50 for 500mm $20 for 2 liters (also used to preserve eggs i think) add co2 and sets like concrete, baking in a dirty oven i understand does the same, don't know about the process of sealing heads though .......
http://www.youtube.com/watch?v=hCBRf...ailpage#t=127s
2m:11s for the impatient.
You can use other catalysts to set it off FERROSILICON etc
Edit i think they also use sodium silicate to render engines totally useless at recycling.
reading this i guess that is what a lot of the commercial sealers are made fromOften called liquid glass, sodium-silicate solution has been better known for being used to save motors rather than killing them: It is used to stop leaks in the gaskets that seal cylinder heads to engine blocks.
At dealerships across America, mechanics accustomed to fixing engines are battling for the chance to ruin them. "Everybody wants to go first, so I'm probably going to have to make them draw straws," says Jim Burton of Randy Curnow Buick Pontiac GMC in Kansas City, Kan. As service manager, however, he might reserve that thrill for himself. "I can't wait," he says.
Over the weekend, half a dozen mechanics gathered around three clunkers marked for death at Jim Clark Motors in Lawrence, Kan. As Loris Brubeck Jr., the dealership's president, held a stopwatch, the sodium-silicate solution took two minutes flat to kill a 2002 Ford Windstar, and just a few seconds more to kill a 1999 Jeep. But a 1988 Dodge van lasted more than six minutes.
"Sometimes those old engines, they're the hardest to kill," says Mr. Brubeck.
Last edited by husaberg; 16th July 2013 at 15:57. Reason: added the engine killing article
Actually I have some block sealer left over I used to treat my 496 as a precaution (as my original CPI block leaked), I heated it up in some water on the stove with solution inside & pressurised it with a hand pump.
I do wonder if a pinhole would leak at all? But might do this as a matter of course. Thanks for the ideas guys.
Dave - you shouldn't be overly worried about a pressure leak outward from the cylinder...Though it will blow all the water out....You should be bloody worried about finding the cylinder full of water after leaving it standing for a week. If it's still accessible from outside you could tap and fit a brass screw.
It's only a matter of time before a bucket racer here in NZ makes a complete devcon barrel. This obsession with avoiding welding is a mystery to me.
I am no engineer, but isn't that 24.1mm lol..................
Not that it matters, i hope she works well as expected.
I just noticed the GP125 makes 30 hp vs the yz250's 47hp ish.
I read the other day that Herman Meiers Ariel 250 that i posted ages ago used lab crank seals supposedly they were worth a couple of HP on a 20 ish hp bike then he borrowed the idea from DKW. i will see if i can find the pic.
There are currently 200 users browsing this thread. (0 members and 200 guests)
