Page 812 of 2776 FirstFirst ... 31271276280281081181281381482286291213121812 ... LastLast
Results 12,166 to 12,180 of 41630
  1. #12166
    Hooked
    Well I just spent the afternoon riding a couple of RGVs around at Manfield. So totally hooked on the things now. The handling was a bit poo, but when on the pipe I just wanted the fun to never end.
    How many ponies do you {you being the people that know ie not me} could squeeze form an RGV250? I think one had a good 65 maybe and the other maybe low 50"s
    So much fun. I see why you are all so mental now.
    You can get 65hp with just bolt on bits and an ignition. However, you will run into the problem of the shit RGV piston which at 65hp is at their limit. The pin boss will disintergrate and take out the cylinder on the right that or the tang between the arch will break off.
    A YZ125 piston is better to use, cranks are easily rebuildable and you use a DT or LC 125 rod for big improvement over standard. We change them to bottom guided thrusts good to 12,500 now.
    Free hp available in keeping coolant temp under control which run over 70deg.
    Been using Nitron rear shocks which tick all the boxes.
  2. #12167
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    http://www.nzsuperbike.com/2013/07/a...aign=bp_recent
Name:	Av 3rd Italy.jpg
    Av takes 3rd in Italy,
Name:	Av Mum and the Team.jpg
    Av with her Mum and The Team.
  3. #12168
    You can get 65hp with just bolt on bits and an ignition. However, you will run into the problem of the shit RGV piston which at 65hp is at their limit. The pin boss will disintegrate and take out the cylinder on the right that or the tang between the arch will break off.
    A YZ125 piston is better to use, cranks are easily rebuild able and you use a DT or LC 125 rod for big improvement over standard. We change them to bottom guided thrusts good to 12,500 now.Free hp available in keeping coolant temp under control which run over 70deg.
    Hi Rich
    We have been using original RGV rods centered in the piston boss and regularly rev them to 13k plus. I recall hearing somewhere that if the rod has to much side play it can vibrate and eventually break.
    2T thanks, its interesting to hear that the 5mm longer LC rods are OK to use.
    We also use early 56mm Wiseco YZ pistons.
Name:	YZ125 Pistons 004.jpg
ID:	285257Click image for larger version.
Name:	YZ125 Pistons 002.jpg
    The YZ Piston Crown Height as measured from the centre of the pin to the top edge of the piston is 0.4mm shorter on the Flat Top 1993 YZ piston (629M) than the RGV and the Domed 86-88 YZ piston (559M) is 0.6 (aprox) taller than the RGV.
  4. #12169
    Have you ever tried the super-short Cagiva Mito pistons, TZ ?
    http://www.mitaka.co.uk/CATALOGUE/VERTEX.htm
  5. #12170
    Yes they are a great piston miles better than th RGV shitters.
    Rob I don't use RZ or LC 250/350 rods but I found a 125 either DT/ LC/RD that was available in a 105mm. I much rather the air cooled RD rod in 110mm.
    For the RGV with a 105mm rod the TZ 4DP piston is best. The YZ runs the ring end gap on the bridge between the B and C ports and I don't like that for several reasons.
  6. #12171
    Hi Rich
    So you are using WC pistons in an Air cooled engine? Thought the idea was the AC pistons had more taper to cope with more heat expansion. No issues there?
  7. #12172
    Sorry, yea I know now the 22 has cartriges,but what I was trying to point out was that even with trick shit SP forks revalved with Ohlins stacks etc
    all that would be a waste of time unless the chassis geometry was corrected to something like decent numbers we all know about.
    And the fact it costs virtually nothing to get those numbers, easily, why would anyone go ahead and spend up on the suspension before fixing the chassis for free.
    Yep. Thats is why I am going to fix the chassis first. Thats what I have been on about from the start. I am usually misunderstood.
  8. #12173
    Cheers For the info. The bikes I have ridden so far had stock temp gauges and I was wondering what the actual temp was the whole to I was riding. Another easy fix. I am going to use wossner pistons coz I know a guy who knows a guy.
  9. #12174
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Quote Originally Posted by Kendog View Post
    FXR's are awesome, no doubt.
    But don't be too discouraged, the fastest rider in Wellington is on a 2 stroker. If he makes it to Taupo for buckets that would be real interesting.
    So like you say, it's not so much 2 vs 4 or how much HP, it's the quality of the rider, and Wellington has the best riders.
    no no the palmy boys
  10. #12175
    19th September 2012 - 12:26
    simson
    Budapest
    The glued and screwed in port floor dam held up OK and the dyno results were better.
    Attachment 285043Attachment 285044Attachment 285045
    Raised port floor Blue line.
    Attachment 285042
    But I wouldn't read to much into it as this triple exhaust port cylinder made much better power before I "improved" it.
    Attachment 285046
    All I did was tidy up around the inside of the main exhaust port area where the side ports converge and after I had finished that I found that some of the horses had bolted.
    What was a stable of 29 became less than 20 ??????? ...
    Originally the the exhaust timing was 203 degrees duration, lowering the cylinder to 200 exposed the bottom of the exhaust port, the floor dam fixed that.
    I was also going to try a power valve like piece in the top of the port but in the end a glued solution was not going to be satisfactory in the long run.
    Messing with this has held me up so I have switched to working on fuel injecting a known good single exhaust port cylinder. I will try making another triple exhaust later.
    Ok Wob, I got it, I've just thought that maybe...
    Teezee! It's a pity that you haven't tested the port floor dam held up before the improvement when the engine was stably 29 ps.
    If you have any further result I'm interested!
  11. #12176
    GPR150
    palmertson north
    Got my cases back today, they have been bored for the RGV cylinder.
    Attachment 232931
    Cylinder fits Ok
    Attachment 232930
    The position of the reed block.
    Attachment 232928
    Speedpro told me there is a nice little curved ledge inside the cases that is just right for the reed assembly.
    Attachment 232929
    So the reed should fit Ok
    Attachment 232927
    Now I have to make up a spacer plate and reed block assembly, how hard can that be???.....
    did you ever finsh this engine rob ?
  12. #12177
    Quote Originally Posted by Forgi View Post
    Teezee! It's a pity that you haven't tested the port floor dam before the improvement when the engine was stably 29 ps. If you have any further result I'm interested!
    Yes, I didn't realy think about it then, but when I get the new triple port cylinder done, a floor dam will be something I will try.
    No the 100cc H2O project got shelved when I hit 30hp with the aircooled.
    Sure a 100cc H2O might be better and maybe races can be won on low 20's hp, Nat D has done it, but personally I would need miraculous assistance myself.
    For now, it interests me to try and push the 125 aircooled with its class 24mm carb restriction out to a reliable 36rwhp.
    And I have ideas about how I can do that, but it all takes time.
  13. #12178
    16th December 2011 - 14:14
    Benelli 250 2C
    If you knew TZ350 you wouldn't ask this question !!!!
  14. #12179
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    Me too.
    Teezee I understand you screwed in a piece to raise the port floor, but glued? What you mean? You used some kind of epoxy? Have had used high temp epoxy for two times in the exhaust port, but the epoxy burned out of shape after half an hour of riding
  15. #12180
    Me too.
    Yes, high temp epoxy to seal the plate. I fastened the plate in with screws, the epoxy was mostly for sealing around the sides and under the plate.
    I did not expect the epoxy to last long, but hopefully long enough to get some meaningful dyno runs. I did about half an hour, 10-12 runs and it held up ok. The last two pictures were taken after the dyno session.
Name:	Ex Port Floor 006.jpg
ID:	285357Click image for larger version.
Name:	Ex Port Floor Glue 005.jpg
ID:	285356Click image for larger version.
Name:	3ex Floor Dam 5.jpg
ID:	285354Click image for larger version.
Name:	3ex Floor Dam 2.jpg
    If I go there again I will take more care making the plate a better fit and not needing so much sealant.
    The glued and screwed in port floor dam held up OK and the dyno results were better. Raised port floor Blue line.
    The dyno results were posted here.
There are currently 200 users browsing this thread. (0 members and 200 guests)
