Page 813 of 2776 FirstFirst ... 31371376380381181281381481582386391313131813 ... LastLast
Results 12,181 to 12,195 of 41630
  1. #12181
    I guess i missed the original reasoning or i can't find it but is the dam about minimizing reversion like the stepped headers?
    couldn't you incorporate the bulge in the beginning with your latest cylinder with a simple raising of the cylinder?
    Or was it just to test it's effectiveness.
  2. #12182
    On the GP the bottom edges of the ports are 1.75mm below the piston top edge, so I can't raise the cylinder enough to form an exhaust port dam without badly screwing up the transfer timing.
    Initially the floor plate was because I had mucked about with the cylinder so much the piston skirt at TDC was not sealing at the bottom of the exhaust port and the dam was only going to be level with the piston at BDC.
    Then I remembered that Jan and Frits had talked about experiments where raising the exhaust port floor made more power by reducing short circuiting.
Name:	Ex Port Floor Glue 003.jpg
    This is the business side and I assume it is what they meant, but I have no idea really or any idea how high it could be.
Name:	Ex Port Floor Glue 005.jpg
    This side of the dam is the un intended consequence and I think it really needs to come right out to the flange face. I will try that next time.
    The idea worked well enough for me to think I will give it another go when I make the next triple port cylinder.
  3. #12183
    And by reducing the exhaust duct volume and to help guide the washed-through mixture back over the piston edge into the cylinder.
    Lenghten it up to the flange face and make a smooth transition, like Wobbly advised.
  4. #12184
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    I think you are very high already, or just at max. As frits said here or elsewere, the area of exhaust port under the transfer opening is useless. Sorry frits if I said it by my words or something....
  5. #12185
    Chopping pipes
    Hi Guys
    I have what look like old Sugaya pipes for my RGV. They don't quite fit the later double brace swing arm on my bike. I need to run the hack saw through them twice to get them on. Both cuts would be on the final cone before the skinny pipe to the muffler. I can tig them up nice after cutting but don't want to wreck them. Any advice welcome. Cheers.
  6. #12186
    Hi Guys
    I wager you will need to make more than 2 cuts. They always look easier to fit before you start.
  7. #12187
    So you are intending to cut & rotate, cut & rotate? Think Jason is right, do small angles & a few cuts.
    The P model SW is stiffer & much lighter than the Banana so think of that as a bonus.
  8. #12188
    Yep yep thats the plan. I was wondering if it was lighter. Good to know.
  9. #12189
    If you are cutting the rear cone then take the stinger off.
    Cut as straight as you can, rotate, mark them and use a 7" diameter disc to get both surfaces dead flat.
    Tac in several places around, then you can shove a bar up inside with a rad ground on the end to tap the join dead flat.
    Then run around and weld.
    Rehammer the joints on the mandrel bar clamped in a vise again after welding to stress relieve and flatten the joints.
  10. #12190
    Thanks for that will do. It has been repaired badly at the front as well so I will cut it and fix it up there as well.
    The other pipe has a stinger length that is very long in compassion. Is it ok to shorten it a little?Click image for larger version.
ID:	285382Click image for larger version.
  11. #12191
    Hi Guys
    Sugaya's tend to be very peaky you'll need a ignitech/Zeeltronic to cover the mid range hole, they tend to work with the old 'kit' set up.
  12. #12192
    22nd September 2012 - 16:31
    1995 kx 125
    I just raised one up 5mm from bdc, welded and replated. After adjusting timing and the power valve I was getting some where. Was also a smooth transition. Had great over rev . Then my dyno box broke when I was making some progress. To say it was a flawed test is a understaement. I did not see any bad side effects and was making good power.
  13. #12193
    Yes I think after reading a lot in the last few days an ignitech is in order no matter what.
    The old 'kit' setup? Do you mean the 1.4mm base gasket and some compression. Seams lots of people talk about that being a good idea. And the 22d10 box?
  14. #12194
    http://www.aircooled-rd.com/default....ge=longrod.htm
    Worth a bit of a look.
    Attached Thumbnails Attached Thumbnails Yamaha Aircooled RD Long Rods.pdf   Yamaha Aircooled RD 1.pdf   Yamaha Aircooled RD 2.pdf   Yamaha Aircooled RD 3.pdf   Yamaha Aircooled RD Carb Boring.pdf   Yamaha Aircooled RD Lectrons.pdf
  15. #12195
    http://imageshack.us/scaled/landing/81/48301117th7.jpg
    http://imageshack.us/scaled/landing/135/47867690ji4.jpg
    http://imageshack.us/scaled/landing/81/21667591zu0.jpg
    http://imageshack.us/scaled/landing/86/99514991ws5.jpg
There are currently 185 users browsing this thread. (0 members and 185 guests)
