Page 817 of 2773 FirstFirst ... 31771776780781581681781881982786791713171817 ... LastLast
Results 12,241 to 12,255 of 41594
  1. #12241
    24th January 2010 - 03:21
    TZ 350
    UK
    Honda faggots off their forum abusing me that the NSR wont rev if taken below 0.8mm
    Sorry - couldn't resist that - I'll not be using any H parts now or ever if I can avoid it...
    I was just trying to tease out of you what the limit might be for a TZ350 - in this case with a Hoeckle crank (pro-digital Ignition) - we're down at approx 0.75mm at the moment - and it appears to be ok - although I'm not sure if I'm brave enough to take it any further...
    The "not free" lunch was pointing in the right direction though...
    Thanks.
  2. #12242
    You dont really need the Ex timing to establish the head geometry, and yes the 6mm number seems to work with most " usual " combustion chamber geometries.
    Avgas works with anything from around 192 to 202 Ex duration at around 15.8 full stroke.
    Smaller bores or lower bmep setups can go 16.2, big bore oversquare or very high bmep like slightly less at 15.5, air cooled of course needs alot less.
    As long as you hit the lower mechanical squish depth limit, then adjust the width to hit 38M/Sec MSV you will have good squish turbulence that helps the flame speed - reducing any tendency to deto
    the end gasses.
    That MSV number is meaningless in the context of all but hitting the head when within the normal rev limits, but as a guide it works every time.
    The sharp bowl edge increases the flame speed, and a very deep angle away from that edge into the bowl is synergistic by pulling the turbulence further into the combustion space, again increasing the flame propagation speed,
    over a wider band.
    Pushing the combustion parameters this hard means a digital ignition is mandatory to balance the timing against the high peak cylinder pressure now being generated.
    More fantastic help. Thanks yet again. I have been using this ( http://www.torqsoft.net/squish-velocity.html) calculator to look at the MSV and as a design guideline.
    It does want the captive compression that I will not be able to work out until I know the timing. But might just wing it. Was looking at around 15.1. static.
    Looks like to get the shape I want without welding up the heads I will have to take around 1.5mm off the top if the head. It will be pushing it. If I feck them up then inserts will have to be made.
  3. #12243
    A TZ350 will run 16.2 with a proper toroid as its bmep is pretty low, and can run at 0.85mm spinning to 11200.
    Miss a gear and hit 12,000 and the pistons clip the head, this is with one of the good aftermarket cranks, I would stick with 1mm if using the soft Yamaha junk.
    These piston port engines love the deto free high com of a toroid, with way better mid power, and the overev comes back with the new ignition retard available from HPI etc.
    Work backwards from the trapped com cc used in the program, as you know already what 15:1 is - easy calc = engine cc/14
  4. #12244
    Rich, Heres the head Wob did for my RGV100 VJ22
    http://www.kiwibiker.co.nz/forums/sh...post1130150762
    http://www.kiwibiker.co.nz/forums/sh...post1130149522
    if he has the fixture for boring the head skull maybe it would be easier, if you cock the cc shape its only an inch of brass to fix it
  5. #12245
    13th September 2012 - 07:48
    1991 NSR300
    In a house
    Has anyone done comparison tests for different squish area ratios ? Eg 40% vs 45% vs 50% . Just curious
  6. #12246
    Yep, I did that as a job for a cylinder manufacturer in Belgium.
    All that the lower MSV does when reduced by narrowing the squish width is to reduce power and increase deto.
    You can get a little of the power back by increasing the timing ( offsetting the lower amount of squish induced turbulence ) but then of course you run into even more deto issues.
    Pulling the squish depth down to the mechanical limit then shooting for a good MSV number is the end of the story and works every time.
    I have had serious flame wars at times with people convinced that "big" engines are completely different, but they havnt even come close to the 70RWHp we used to get from a 250MX on Avgas
    in open class karts.
  7. #12247
    Eek. What sort of revs does one have to spin one out to to achieve that?
  8. #12248
    Rgv project
    What a funking lemon. Just started to strip the top ends. Only got as far as removing the barrel on the bottom cyclinder to find 3/4 of a piston and a completely shaged bore. At that point I gave up and am now having a beer thinking of how I should proceed with what is now turning into a complete engine rebuild.
  9. #12249
    What a funking lemon. Just started to strip the top ends. Only got as far as removing the barrel on the bottom cylinder to find 3/4 of a piston and a completely shagged bore. At that point I gave up and am now having a beer thinking of how I should proceed with what is now turning into a complete engine rebuild.
    The more beer you drink the less shagged it will become. Oddly the exact reverse thing happens with ugly chicks though
    Dare I say 54mm stroke crank and RG150 cylinders or maybe something a little different
  10. #12250
    Tempting. But part of the reason I like these bikes is that fact they are 250cc. If I wanted to go big I would just build 690 single 4 stroke. Still will one day.
  11. #12251
    Sorry now i am confused........Presumably the only class it will be eligible for is F3......
    F3 goes up to 400cc 2 strokes........
    Are you really really wanting to be the underdog that much?
  12. #12252
    You don't have far to go.
  13. #12253
    ....Yep....
  14. #12254
    yeah yeah i know
  15. #12255
    Peak power of the 250 kart engines was around 10600 and reved to 11600 if needed.
    Big ends didnt last long but who cares, plenty of National titles.
There are currently 215 users browsing this thread. (0 members and 215 guests)
