Woobly, to make a pipe fitment in this case If I remember it was said earlier in this topic that each cone intersection robs power without all the work to make it clean inside and round, so a hydroformed header instead of a lot of cones would perform better right?
I was looking at this photo of this header, don't remeber where it was from.
This is made with two flat sheet's pressed agaisnt a mold and then welded together right?
Thanks
No,No,NO.
The hydroforming method works very well in headers where normally there are sharp radii and may cut sections.
But as soon as the angle deltas increase dramatically, getting into the diffuser section, the smoothing and smearing effect of the continuous progressive angle change looses power.
This is most dramatic when changing angle each side of the belly section.
The best combination of methods is hydroforming the front section followed by individual cones.
The pipe in the pic has no sharp angle changes - thus likely is a blown up type.
Honda has used the die formed method for years, with two halves pressed in a CNC machined form tool.
This also gives good sharp angle changes, but with no weld finishing needed.
I spent - wasted - months of time at JL building pipes for 250 Superkarts learning how to do really beautiful formed shapes.
But even with the mid section clamped in a ring,to at least keep that parallel, we lost around 2 Hp per pipe against the best hand built section method.
KTM did a nice job of this, but sadly they were stuck in a Bartol time warp with the actual design elements.
Looks more like a 750 SOHC Honda sketch...the Manx would have an oil leak designed-in! (from the cambox).
meh I was just looking at the pinstriping on the tank, but yes there are some extra pipes shown than a single requires. Silly bloody things, - look where the carbs are mounted. Ridiculous!
I need to replace my petals. The original ones are fiberglass and 0.5 mm thick. What is the best Carbon fiber ones to replace these with. They have 0.3 0.35 and 0.4.
The reed block has two sets of reeds. One for low flow and a bigger one sandwiched between it and the block for high flow. Can to run Carbon to Carbon petals or must one be fiberglass ?
Well done Team.
That's a great result.
Looks like there is still something holding it back (possibly transfer duration or is it the 28mm restriction & intake design?) in the top end (26-27 looks very possible).
It would be very interesting to compare porting to a old RM125 cylinder (late 70's vintage).
The North Island series is going to be interesting this year.
Eh? You know what boysen reeds are huh? Google it. Either way for road race just plain single reeds will be the go, none of this sandwich ports in the reeds stuff. Or has someone piggybacked some?
Maico 250 1982 for road race.
Ahh, dirty ol' Boysens. Throw them. There is often a bit of testing to get best performance to suit a reedblock on a certain engine with certain carb size etc. Cut some & try, if they flutter like buggery try stiffer. 0.3 is a common thickness. I have some old software to estimate but just found trying it easier & more accurate. No doubt engmod2T will know for sure, but I don't have that,
Use the softest carbons you can.
Make a " rev plate " from the old reed 0.5mm material ie a strip say 6mm wide, this sits on top of the carbon under the screws.
Then take the original thin fibre reeds, cut them to 1/2 length then cut them to make 3 pointed hats,these are backups that sit on top of the 0.5mm spacer.
Next take the old radius plate and cut it to 1/3 its original length,this sits on top of the backups with the screws going thru all 4 elements.
Best reed setup known to man.
Pointed hats? Maybe I should be wearing one. Still trying to picture exactly what you mean by that.
Do you think single reed will ever work as well as individual fingers? I've had reasonable success with that setup, but really limited testing.
