Page 853 of 2773 FirstFirst ... 35375380384385185285385485586390395313531853 ... LastLast
Results 12,781 to 12,795 of 41593
  1. #12781
    Quote Originally Posted by Forgi View Post
    Hi Teezee! In Hungary there is Simson Cup or Championship, so there are a lot of tuning simsons as well.Now I have found this link, which leads to a video of a street race, but if you are interested I can search for others, as we have races on small and huge rings.
    http://www.sportmotor.hu/motoros_vid...1-futam-107529
    Originally simson enginees are piston port valve enginees(inlet port), but there are some with reed valve and some rotary disc valve simsons as well. All of them are modified individually, so there aren't two which would be the same.
    Here you can see some pics (membrane valve and rotary disc valve):
    http://70per13.chiefyeager.fotoalbum.hu/?pageid=0
    http://kepfeltoltes.hu/view/130929/1...toltes.hu_.jpg
    http://kepfeltoltes.hu/view/130929/D...toltes.hu_.jpg
    And there is some others from www.sportmotor.hu:
    http://www.sportmotor.hu/motoros_vid...imson-80-87233
    http://www.sportmotor.hu/motoros_kepek/simson/?dr=67398
    http://www.sportmotor.hu/motoros_kep.../?dr=63946&p=1
    http://www.sportmotor.hu/motoros_kep.../?dr=68551&p=1
    ... if we have the chance we weld to get bigger and more appropriate B transfer passages, as it is clear that unfortunately in the original Simson cylinder there is no place for the B passage.
    Forgi although some would not connect, I have enjoyed those Simpson photos and video that I could see.
    If you have more I would love to see them as the work they do is what we would like to do with our Buckets.
  2. #12782
    Seen this. and i don't really understand?
  3. #12783
    What is there not to understand, Husa? Some tuners do not use flexible grinders; they use trained aluminium-eating rats. Seems like the rats that did the above job were not yet very well trained .
  4. #12784
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    A while ago someone posted(think it was Husaberg) a link to a Swedish site with a simple program wich calculates a sample of 'FOS' pipe for free.
    I´ve been in contact with the developer and he asked me what i would like to upgrade the program with.
    I said, angels would be nice and if it wasn´t to much work a drawing of the different pieces to copy so one easy could cut out the different parts from the ironsheet.
    Well,, he did it and then some..
    link again:
    http://underdogsracing.com/fospipe/
    rgds
    Patrick
    Is everything ok with those calculations? I had write there my specs of 250 single and it tells me that belly should have ID 168mm kinda too big I think... What do you think guys about this http://www.dragonfly75.com/motorbike/ECtheory.html looks interesting to me.
  5. #12785
    KTM's back when they were also Pentons used a very similar Z shaped additional transfer pair above the inlet. Executed a little better though....
    Frits answer is undoubtedly correct also. It's why you should always get the head back on quickly so as to keep the rats out.
  6. #12786
    Yamaha did something similar in the TA125 and HH did many cylinders with the same idea.
    All its trying to do is get some more transfer area and boost port scavenging for the loop
    up the rear wall,where there is no actual room around the piston inlet port.
    I could do with some semi trained mice here, specially if they can be taught to use a Tig on 0.8mm cold rolled.
  7. #12787
    Well I got the dyno back together (though now the ancient PC is trying to fight me) but it goes Hoorah.
    Got some runs in getting an ign curve with some benefits, needs more time. Didn't get to try the new carb arrangement. Foiled by a stuck float pivot pin (I have to swap bits over from one carb to the other body) & didn't have the tools to remove it. Got home & got it all sorted (with a tool I did eventually find in the gear I took with me).
    Either way I had made a silly mistake with the PJ wiring, forgetting again that the power out grounds the power, not feeds it, so I'll swap some earth for volts and we'll be in action, hopefully for another run sunday which is close to leaving for Chch as I dare leave it. Blowing through the PJ feed & activating solenoid really clamps it off.
    Knock gauge feedback was once plugged in last night; doesn't affect the power curve but does calm down the occasional orange flashing. Seems like a good safetynet, but obviously don't want to rely on it in case it broke.
  8. #12788
    Actually i don´t know.
    On my 132cc engine it´s seems really ok.
    On a friends 90cc engine it also seems ok.
    And on a other friends 66cc Zündapp it seems ok.
    I haven´t checked it on any bigger displacemant engines than mine 132cc.
    People in Sweden with snowmobiles use this program every now and then, and they say it seems to work.
    I´ve got 130mm belly on my engine for example as i were a bit chicken on third stage diffuser.
    The program says i should have 134mm,,(exhaustcalculator program that one can dowload)
    this program also says 134mm.
    If you got time and money, give it a go, it might just be a success,, and ofcourse,, it could be a disaster.
    Frits that is very very competent here in the forum might give us a clue wether it works or not?
    Rgds
    Patrick
  9. #12789
    I have been waiting for 6 months to get a shipment from Ignitech, they wont reply to my emails and I have 5K worth paid for and pissed of customers. I rang Jim Lomas in Czech to get him to talk to them, but no luck - yet. Anyone know someone that speaks Czech.
    Seems that the only way to get chzech spark boxes is to go get them yourself, Wob. Greetings from Czech Republic.
  10. #12790
    Just a 30min drive from your place Frits?
  11. #12791
    Hells teeth Frits, it looks like a Warsaw Pact tank bunker - oh thats right the Czechs were in the Warsaw Pact.
    Did they shout you lunch of dry bread and water.
    Sure doesnt inspire much confidence as the worlds leading edge ECU manufacturers when they work in that sort of environment.
    If thats the front door, whats it like out back ?
    Reminds me of most of what I saw of China's manufacturing base - shitty rat holes with exposed 3Ph wiring all over the place - dead scary.
    I did finally get my big shipment of ignitions after a 5 month wait, heres hoping the latest order is handled better.
  12. #12792
    2nd April 2012 - 00:54
    Hey Wob, as we're talking Ignitec, how would YOU go about offsetting the ignition timing of the rear cylinder on a inline twin, I would like to be able to adjust at a finer value than the 1* values of the Ignitec or is there something I'm missing ?
    Nice pic Frits
  13. #12793
    Yeah, if I average 1736 km/h. Which is not so simple on Czech roads...
  14. #12794
    Ignitech put in the individual channel "correction " years ago, specifically for me when I got sick of spending hours correctly retarding
    the rear cylinder on Rotaxs by grinding the keys.
    I have since asked if they would reduce the amounts of correction to 0.5* increments but had no joy with that request.
    You can fool the motor into receiving the correct timing on each cylinder by increasing the base advance on the stator ( thus retarding the actual timing )
    and then advancing the front cylinder in its correction box.
    By playing with each of the 3 variables - base timing and each cylinders correction - you can get precise actual firing of any amount in each cylinder.
    I did this another way the other day on a TD3 that had 3 lobes on the plate and a single trigger.
    The 1* increment of retard on one cylinder was too much, so I physically retarded the stator by 1/2* then advanced the other cylinder by 1* in software - this
    gave perfect timing of both on the strobe.
  15. #12795
    20th June 2012 - 00:17
    yamaha
    Im kinda shocked by the building that ignitech work out of. Oh well as long as they keep making good ignitions its all good
