Page 872 of 2773 FirstFirst ... 37277282286287087187287387488292297213721872 ... LastLast
Results 13,066 to 13,080 of 41593
  1. #13066
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    I can't quite picture it yet but I am enjoying seeing this pattern coming together, thanks.
    i would say its the transfer port right around the cylinder witch will be made of core materal and removed to make the ports
  2. #13067
    This pattern making has really got me interested, guess whats next after I have conquered EFI.
  3. #13068
    A sit down with a nice cup of tea & a book?
  4. #13069
    Nah some liver with some fava beans, and a nice Chianti
    ps Dave i thought the same re the Penton.till i went looking for the pic.
  5. #13070
    Right, water core is done.
    And poured a cylinder resin core copy
    copies of the transfer port
    Next I will be building the actual pattern, with these parts inside. Core prints will stick out of the final pattern ( thats all the tapered bits you can see on the ends of everything. It will become clear.
    And all together
  6. #13071
    That is very very clever.
  7. #13072
    If it's not the continuously variable transmission, then these pictures may be of some use to you:
Name:	RSA sand cores 01.jpg
ID:	290112   Click image for larger version.
Name:	RSA sand cores 02.jpg
ID:	290113   Click image for larger version.
Name:	RSA sand cores 03.jpg
ID:	290114   Click image for larger version.
Name:	RSA sand cores 04.jpg
ID:	290115   Click image for larger version.
Name:	RSA sand cores 05.jpg
  8. #13073
    By using this framework of cores, made in the same boxes that will be producing the sand cores for the moulding, you will get the cores within the mould in the right place. Cores are held in place, in the sand mould, by core prints ( the tapered bits ) seen here on an earlier pattern. The next step is to add " thickness " to the core copies and build the pattern up. I'm not sure I'm explaining the process well, you will see in the next step. You start from the inside first, make the cores, then core boxes, then copies of the cores from these boxes, ( all my original cores are on the shelf now, never used again unless there is a major catastrophe), glues all the cores in place, relative to each other, then add " thickness" to the outside. All these white bits will eventully be hard sand, where you don't want aluminium you need sand.
  9. #13074
    Thanks for the pictures of the cores.
Name:	Sidecar and CVT.jpg
    Looks like the first Team ESE adventure with CVT is going to be Chambers center steer sidecar.
  10. #13075
    Centre steer? Is that where you have a slightly bigger wheel in the middle of the rig & turn that? Radical!
  11. #13076
    Looks light it will weigh a ton or two.
  12. #13077
    Starting to build the outside shape, beads and bondi fill. Beads are stuck on with a hot glue gun, real pattern makers don't use a hot glue gun, apparently. Or for that matter, plastic beads.
  13. #13078
    Well not at work they probably don't. but at home when making an above the knee, slash front, summer dress they probably do.
  14. #13079
    2nd April 2012 - 00:54
    Frits are those casting core pictures the RSA or Francis Pyarts FPE ?
  15. #13080
    Good question, RAW. The pictures stem from Francis Payart who produces exact copies of the RSA parts. The only difference is that the small cooling channels inside the inner curvatures of the RSA's transfer ducts are absent in the FPE cylinders. Understandably so, because they are not easy to cast.
    PS: the picture below is from a FOS cylinder; I didn't fancy cutting an RSA cylinder in half. But you'll get the idea.
Name:	transfer cooling.jpg
