Page 891 of 2774 FirstFirst ... 39179184188188989089189289390194199113911891 ... LastLast
Results 13,351 to 13,365 of 41606
  1. #13351
    Ultimatly they are all air cooled. What cools the radiator? The liquid is only a heat transfer system.
  2. #13352
    Attachment 291294 Chapter 24 Miniature RR (Buckets)
    F4 2 stroke engines over 104cc are restricted to carburation equivalent to a single 24mm carburetor.
    Attachment 291295 Appendix D Championship Classes, Solo motorcycles shall have :-
    F4
    2 stroke 55 -100cc.
    2 stroke 55 - 125cc air cooled.
    4 stroke 55 -150cc.
    So you have to look in at least two places to read the rules covering 125cc F4 2T's. And liquid cooled is not mentioned, only the term "air cooled" is used, and does air cooled mean you can't use a drop of oil to thermally connect a heat source to its cooling element?
    This interests me as I intend using a lot of copper wire and copper dust wetted with oil for themal contact, to transport heat from its source to the heat sinks.
    Bit if you are using a drop of oil to thermally connect a heat source to its cooling element then is it now not air cooled?
  3. #13353
    What if air is cold enough to be liquid?
  4. #13354
    detail of aircooled rg150 barrel
  5. #13355
    Air is 80% Nitrogen Neil.........boils -196 degrees or so..........
    Oxygen boils at -182c
    CO2 -56c
    I would be very interesting in seeing a how an Air cooled head is copy cast and how to make a tool for a air cooled cylinder to say go around one of these.
  6. #13356
    The head is easy, all my 350 heads have been cast at Thames. The cylinder? I've never cast an air cooled one, I've got the beginnings of patterns here to cast a 350 cylinder ( air cooled ) with modern porting inside but have never gone any further. Too busy dicking around with sleeves etc. I'm sure it would be not a big deal. The mould to make the sand mould ( outside ) would need to be steel I think and the core baked in shell sand. Or in this case lost wax system, maybe? A die is still needed to make the wax original anyway.
    Surely a proper ( modern ) constructed 100 cc water cooled would be the go? Perhaps making it a two cylinder with vairable rotary valves.
    If E85 were legal, then air cooled would be less of a problem. Internal liquid / vapor cooling.
    Having the original core boxes for that cylinder ( you show in the picture ) would be a big help.
  7. #13357
    The object would no longer be direct cooled, it can still be air cooled.
    I'm with Neil on this one.
  8. #13358
    Thats is very clever.
    The head is easy, all my 350 heads have been cast at Thames. The cylinder? I've never cast an air cooled one. Having the original core boxes for that cylinder ( you show in the picture ) would be a big help.
    I would love an air cooled cylinder with deep fining and a modern port layout.
    I am an air cooled sort of guy.
  9. #13359
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    the foundery here have a rotating platform when poring air cooled cylinders to fling out the aluminum, seems to work a treat
  10. #13360
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    Nah, just print it. There's even a dirt cheap kit to make one... :http://www.theshedmag.co.nz/online/c...&category_id=1
  11. #13361
    KTM 1290 SAR
    Wgtn
    Most SG iron liners are centrifugally cast, makes for less porosity.
  12. #13362
    My mistake, I afraid I'm still a little old school. I hate those 3D printers but perhaps there is a use for them in printing wax? Can they print wax? Perhaps I could CNC 3D machine a pattern direct, out of wax? No, just better off machining a steel die for shell sand. No, perhaps better off machining a male in carbon and spark eroding into steel. Cover the steel mould in ceramic paint and you have a die cast setup, pour straight in the steel die with hard sand cores locked inside, that way we could make lots and lots of them real quick!
    In reality I'm sure it could be done with a wood mould making CO2 sand outer. Split the fins and make each one separate and glue together, layer ( fin ) after layer ( to make the wood mould ) paying great attention to surface finish and enough taper to make the mould slide appart with out sticking.
    Actualy just get one of those 3D metal printers Frits has.
  13. #13363
    KTM 1290 SAR
    Wgtn
    My school's older than yours.
    And yeah, you can print wax, jewellery industry has been doing it for a while. Amazing resolution too.
    Don't know what toys Frits has. But quite a while ago I got involved on the outskirts of the development of printing metal powders. It was just market-ready then, with a limited range of tool steels and Ti. The one major advantage, of course is the ability to make hollow shapes impossible for any other process. I believe Volvo make pump impellors using the system, but I'd be surprised if they've ironed the wrinkles so far yet as to allow printing 7000 series aluminium.
    Hideously expensive, of course. But then, so was printing ink when I were a nipper...
  14. #13364
    I agree i was more meaning for Robs
    You have the pics in your email somewhere...........
  15. #13365
    I have only seen a couple of pics of aircooled cylinder males one for a Devimead A65 jumbo and another for a Older excelsior V twin.
    My little musing was to cut open an old MX cylinder and use that to make one and add filler where necessary. using the Sprilia like sand core.
    this thread i was following on Pit lane was impressive on its use of technology.
    http://www.pit-lane.biz/t3187-50cc-s...light=50cc+ktm
There are currently 334 users browsing this thread. (0 members and 334 guests)
