Page 895 of 2776 FirstFirst ... 39579584588589389489589689790594599513951895 ... LastLast
Results 13,411 to 13,425 of 41630
  1. #13411
    Found this handy little site:- http://users.erols.com/srweiss/tableifc.htm
Name:	Stan Weiss' - Electronic Fuel Injector (EFI) Flow Data Table.pdf
    Fuel injector Data
Name:	Stan Weiss.JPG
    From the table, at 80% duty cycle my IWP023 injector can support 23 crank hp and the IWP043 48hp.
    More Numbers:-
    13,000rpm
    = 217 rps or rp1000ms
    217 x 1.5ms latency = 325ms
    80% duty cycle = 800ms
    800ms-325ms=475ms
    475ms/217rpms
    = 2.18ms of fully open injection time per revolution
    and
    If the maximum opening + closing speed of an injector is 1.5ms, then 1.5ms = 666 Hz or 40,000 rpm. So my injectors should be able to easily open and close fast enough for 13,000rpm.
  2. #13412
    It's that "jolly" ECU ! Abandon it and use a Link. I've got a spare one here for you to use. You will just need a new wiring loom.
  3. #13413
    just go simple, 1 injector at the body good fuel mixing, well thats what i would do
    Dosen't work, too indirect to the cylinder. You will get inconsistant fuel mixtures up to the cylinder, remember the fuel is being deposited as small pockets in the main air streem. How do you know that small pocket will end up in the cylinder accurately every cycle. There is a pumping crank case in the way ( not 100% pumping efficent at below 1/3 throttle ), some fuel stays behind, some fuel goes through to the cylinder. This is where most twostroke EFI setups are comming unstuck.
    In fact thats what happens, combustion chamber "sees" rich / lean every few cycles.
    Stick to your guns Rob, I'm just not too sure I trust that ECU.
  4. #13414
    Something is wrong, it just should not be this hard to get sorted.
  5. #13415
    Your welcome to borrow my Link ECU, it's not in use at the moment.
    Actually I've also got an Ignijet ECU as well, although I don't know anything about it yet, you could try it if you like.
  6. #13416
    Thanks, but I am a glutton for punishment and want to try and conquer this thing.
  7. #13417
    The offer is there, any time.
  8. #13418
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    just going of a book i read in around 2000 with a kart engine with direct injection just had 1 injector on the head , seen it had no gearbox it would have to run good in its hole rev range, but maybe direct injection works diffient ...dont know
  9. #13419
    Thanks, the offer is much appreciated.
    ... kart engine with direct injection just had 1 injector on the head , seen it had no gearbox it would have to run good in its hole rev range, but maybe direct injection works diffient ...
    Slightly different process, compressed air is also used, possibly a peak and hold injector to, for fast opening. But like you say, it makes you think, why can't port injection be done with only one injector too. I will have a go.
  10. #13420
    GPR150
    palmertson north
    Slightly different process, compressed air is also used. But like you say, it makes you think, why can't port injection be done with only one injector too. I will have a go.
    think anything is worth a try , if it does not work .no lose and no gain as they say . have a good xmas
  11. #13421
    Thanks .... have a good Christmas too, if your off to Wanganui, have a great time and please post something about the racing and how Guy got on.
  12. #13422
    It was good. He got about 5ths and mostly stayed on.
  13. #13423
    Thanks, it will be interesting to hear more about peoples adventures when they get back, and more of Guys exploits.
  14. #13424
    Moto guzzi was using fuel injection with compressed air in the 50's
    if i trip over it i will post it.
  15. #13425
    GPR150
    palmertson north
    yip around 5ths guy got , one race he pulled in half way through the race ,my mate went over to see him and he was moaning about his airbox been wrong lol . nasty one with sloan frost and nick cole going under him in the (Esis)can't spell ) anyway sloan crashed and went under the airbag..took i think 4-5 mins before anyone pulled them up and got him out .. the spectators jump the fence in the end and lifted the bags of him lol ..looked nasty though
There are currently 159 users browsing this thread. (1 members and 158 guests)
  1. JanBros
