Page 897 of 2776 FirstFirst ... 39779784788789589689789889990794799713971897 ... LastLast
Results 13,441 to 13,455 of 41632
  1. #13441
    And if I set the system up to run only one injector it will run well past the troublesome cross over point for two injectors so I think the map and pickup are not the problem.
    What type of trigger wheel are you using?
    It isn't just running so damn rough that it is kicking the RPM signal around is it? I have seen it before.
  2. #13442
    Single pulse trigger, not a multi tooth with gap type trigger wheel.
    I am using the stator plate and pickup (no charging coil) and the flywheel from a KX80
    Good thought, I will put the scope on it tommorow,
  3. #13443
    Can your scope give you an FFT of the pickup? (http://en.wikipedia.org/wiki/Fast_Fourier_transform)
    That way you can see a single peak at the current RPM and if it moves the single peak will move up or down the X axis, but if it is randomly missing revolutions you will get several peaks.
    Hmmmm. Depending on how much crank inertia you have that can prove problematic. If your tune is spot on then it can run very happily. But if it isn't any sudden accelerations and decelerations can't be accounted for, which can put your spark and injection timing way on the piss, which just makes it all worse.
  4. #13444
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
  5. #13445
    24th February 2009 - 05:24
    honda cub90
    Ireland
    ECU's
    surly the only thing two stoke about the ecotrons is the low ampage fuel pump? swap it for a microsquirt/megasquirt
    on the other hand i can understand the urge to not lose to the bastarding thing, work damn you!
    1200 for the link!
  6. #13446
    ECU's
    1200 for the link!
    The link is pretty flash bit of Kit, A much earlier version wasi what the Britten Ran Shhhhhhhhhhhh (forget i said that)
    Few people would seen or heard of this i had just seen the odd reference.
    I could have posted this in ESE or the chassis thread (might anyway).
    Tell you the truth i wouldn't mind building a replica anyone got a Crescent 500 3 engine (lying about, they want to give away like)
    This last pic i think is another version maybe?
Name:	Monark story.jpg
ID:	291528   Click image for larger version.
Name:	Monark story 2.jpg
ID:	291529   Click image for larger version.
Name:	cresent 500cc engine.JPG
ID:	291540   Click image for larger version.
Name:	Cresent 500 2 engine.JPG
ID:	291541   Click image for larger version.
ID:	291542   Click image for larger version.
  7. #13447
    Some more Crescent engine pics 500cc 2 stroke 3.
ID:	291544   Click image for larger version.
  8. #13448
    We now have a CVT project, watch this space later in the year.
  9. #13449
  10. #13450
Name:	Injected Suzuki 750.jpg
    Fuel Injected Suzuki 750
    A very interesting collection of links to all sorts:- http://teamheronsuzuki.blogspot.nl/2...tam-rg500.html
  11. #13451
    What about just using the smallest injector possible that will supply the fuel at max, only. At start and low throttle openings it will be rich even at minimum pulse width. Opening the throttle will admit more air but you don't have to programme increased fuel until conditions require it. I don't know when those conditions would be, it would depend on the injector and the engine. Typically carbs are set rich at the very bottom of the range and they work OK. The way I see it if you had to have more than 15% throttle to admit enough air to correct the mixture even at minimum pulse width it should be rideable. How often is a race motor used below say 50% of max revs with less than 15% throttle? I reckon it would "blip" fine and be raceable. We aren't talking about a road bike here where it must be sweet from idle to max.
  12. #13452
    At start and low throttle openings it will be rich drown even at minimum pulse width.
    Fixed that for ye.
    A carb 'set rich' doesn't necessarily mean a rich mixture. This is a fundamental difference between a carb and EFI.
    Rideability is less critical on a race bike? You haven't done much drifting lately, have you?
  13. #13453
    Yes, worth a try.
    If all else fails I can try it on the Bemer I am customizing. Chambers and I have both got K100 basket cases that we are going to make into bober chopper cruisers complete with extended forks, low rider sprung seats, tassels, peanut tanks and fat rear tiers. The bikes will be striped down and all about the engine.
    Probably offend the Euro Fundamentalists and State Side compressor riders all in one go ......
Name:	K100 Engine.jpg
    Not my bike, but don't you just love that engine.
    Maybe I could have done a 2T like this high powered BSA Bantam with an RG500 based engine.
ID:	291591 http://teamheronsuzuki.blogspot.nl/2013/12/bsa-bantam-rg500.html
    With the Bemer I am aiming for something that's OK to ride slow so I do not loose my license (again) and great for cruising the cafes.
  14. #13454
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    could allways use a carb until the end of the needle then inject the rest
  15. #13455
    More progress, Matt has been in contact and asked for my latest recorded runs and photos of the scope traces for analysis. He expects to be able to get back to me Wednesday. In the mean time I will have a look at the quality of the trigger signal from the ignition pickup.
