Page 903 of 2774 FirstFirst ... 403803853893901902903904905913953100314031903 ... LastLast
Results 13,531 to 13,545 of 41608
  1. #13531
    The water spray idea is good, the other three are obviously facetious.
    Tyrell used water spray cooled brakes in F1 years ago (although the real reason was weight. Cars were allowed to be refilled with fluids prior to post-race weighing. Dumping a lot of water during the race gave them a weight advantage)
    But - what defines water cooling? If water spray is illegal then can an air-cooled bike race in the rain?
    i know of at least one "production" class rally car which had a windscreen washer diverted to spray the intercooler....worth quite a bit of HP I was told.
    I still think an oil cooler on the gearbox is worthwhile - and legal - particularly for the longer big circuit races.
  2. #13532
    I diverted my windscreen washer to the carb through a jet on the 2.3L turbo I had in my Mitsi L200. Ran 10psi with no probs with the water and rattled a bit at 5psi without.
    A wet aircooled bucket was quite useful at Taupo a few years ago. Made the same power the whole race.
  3. #13533
    Yep, watch this space ....
  4. #13534
    Attachment 291888
    Himmmmm .... now how could I get a huge amount more crankcase volume??? nope nothing obvious there.
    I bet those not so obvious crankcase volume enhancing parts would be an excellent return path from that oil cooler, right?
  5. #13535
  6. #13536
    i'm looking forward with a great deal of interest to see how you manage it with a belt CVT........
  7. #13537
Name:	Crank Case Volume.JPG
    Hmmmm I see your point......
  8. #13538
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Back to the cooling spray, etc. All engines are air cooled, they just vary in the medium that gets the heat from inside the engine to the atmosphere. Aluminium, water or oil, are all just a method of heat transfer and dissipation
    (PostalDave on ADVrider)
  9. #13539
    Yeah, but we all know what the rules mean, imagine reading, or writing a rulebook that had to cover technical semantics to that point...
    I'd rather build a bike and race it.
    TZ, Kel and many others on here are capable of building winning bike without trying to get in to tricky shit.
    Kel already has actually, that thing is a rocket.
  10. #13540
    Considering that the road race commissioner considered water injection to be water cooling , I think there may be a problem with external watercooling.
  11. #13541
    Yeah well said.
  12. #13542
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    4t - 2t .......
    OK so you were just curious and wanted to try the 4T thing.
Name:	4T - 2T Cross Dressing.jpg
    But if getting around town with a 4T is really just not your thing.
Name:	4T - 2T CVT.jpg
    Then get real and make that 4T into a H2O 100cc 2T
Name:	4T - 2T cases.jpg
    RG400 cylinder fits ok
Name:	4T - 2T Cylinder and Case.jpg
    Block the lower crankcase off and still have plenty of crankcase volume.
Name:	4T - 2T Case Volume.jpg
  13. #13543
    Norton Manx
    Over the Rainbow
    2t - 4t ......
Name:	4T - 2T RG400 Cylinder.jpg
    Remodel the cam chain tunnel and timing chest for the transfer ducts.
Name:	4T - 2T Reed Valve 1.jpg
    Reed valve inlet at the side on the bottom.
Name:	4T - 2T Reed Valve 2.jpg
    Plenty of case volume.
Name:	4T - 2T Reed Valve 3.jpg
    Or you could use a pumper carb and run the reed inlet in through the top.
    Because real men don't need 4 Strokes to get the job done.
  14. #13544
    Never mind what the rules mean. All that matters is what the rules state. Writing a clear, simple rulebook is no rocket science but just a matter of using your brain and a little logic. If the rules are unclear or ambiguous, take advantage of them.
  15. #13545
    http://www.vemssupport.com/forum/ind...opic,97.0.html
    Before calibrating an engine, it is first useful to have some concept of what you are trying to control. The following is a fairly brief overview of the internal combustion engine, which will hopefully give you a basic understanding of some fundamental principles and terminology, so that when you change a number in a box on your laptop, you have some idea of the effect it is having on the engine.
    ""Fuelling Theory
    ... Lets start with the theory then. We are concerned with spark ignition gasoline engines here. I am only going to cover gasoline, since Diesel is for trucks and diggers, and alcohol is for drinking and drag racing.""
    http://195.159.109.134/vemsuk/forum/...opic,97.0.html
