Page 904 of 2776 FirstFirst ... 404804854894902903904905906914954100414041904 ... LastLast
Results 13,546 to 13,560 of 41630
  1. #13546
Name:	Auto Tuning 001.jpg
    Ok, making progress, that's if you can call getting it wrong progress.
Name:	Auto Tuning 005.jpg
    Ecotrons has a very clever self tuning feature where you tell the map what Lambda you want at what RPM and the ECU will read the ALM O2 sensor and adjust the mixture for you.
Name:	Auto Tuning 002.jpg
    The green squares on the map are where the ECU has completed the tuning process and delivered the Lambda asked for.
    But you do have to ask for the right Lambda value for the engine. And this is where I went wrong tonight, I made the lower end to rich and eventually after a lot of auto tuning work the motor could not pull the skin of a rice pudding and drag itself into the power band.
    On a rolling road dyno you can only do this auto tuning at low RPM and light loads because the Auto Tuning function needs the throttle and rpm to be held steady for 10 seconds or so to work.
    The auto tuning feature works better and you can cover more of the map if you can ride on the road and use the head wind as a load or better yet, use a dyno with a brake to hold the engine steady.
Name:	Auto Tuning 003.jpg
    My mistake was asking for to rich a Lambda at low throttle settings, and having the bike struggling to pickup on the dyno. I had made the map 0.85 Lambda everywhere, I should have stuck with the default map that had Lambda 1 at low RPM and dropping to Lambda 0.85 - 0.82 at max power.
    But being able to make planned mistakes is a step better than just making ignorant mistakes and not knowing why.
    So .... its progress ...
  2. #13547
    Do you mean low throttle settings or full throttle low rpm? Regarding the latter, you should be able to run Lambda 0,85 (and richer) without 4-stroking from about 3000 rpm to top rpm if ignition timing is in the right ballpark. Also, a properly designed combustion chamber (high msv type) should make tuning the EFI easier for you as it's less sensitive to 4-stroking.
  3. #13548
    Getting it wrong and realizing it will teach you more than just getting it right the first time. So yes, you can definitely call it progress.
    I know it and you know it, but I can't repeat it often enough: lambda does not tell you rich or lean; it only tells you how much oxygen it sees in the exhaust gases.
    At low throttle settings the engine will occasionally miss a combustion cycle, which sends all inhaled oxygen straight into the exhaust.
    If you try to adjust the resulting lambda readout by jetting richer, you will smother the engine wit a very rich mixture (and cause even more misfiring).
  4. #13549
    Thanks Haufen and Frits, good points. Thanks for the Heads-Up, I am looking forward to having another go, hopefully tonight.
  5. #13550
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    old school adjustable chamber
Name:	manual trombone-esque.jpg
  6. #13551
    4t - 2t .......
    OK so you were just curious and wanted to try the 4T thing.
    Attachment 292131
    But if getting around town with a 4T is really just not your thing.
    Attachment 292132
    Then get real and make that 4T into a H2O 100cc 2T
    Not sure I would go this way
    Interestingly Chambers is actively building a CVT hybrid.
    He is grafting his old GP100 engine onto a set of 4 stroke GY6 CVT cases to power his side car.
    The last time the 100 ran it was 22hp hopefully we can increase that a bit.
  7. #13552
Name:	Lambda Spike.JPG
    Getting some where now. Just before the courser is a spike in the Lambda line, this could be an example of what Frits has talked about where a miss fire dumps a whole lot of oxygen into the chamber.
Name:	Octane Improver.jpg
    Anyway the good old lead free 96 detonates real bad as the engine rpm approaches the torque peak so its an ideal time to try some Octane improver.
  8. #13553
    I used to like the Idea of Fuel Injection.
    I'm over that now.
  9. #13554
    I'm over that now.
    Me too just about.
  10. #13555
    Me too just about.
    Your in balls deep though.
    Glad I'm not.
    It's still prob worth persevering with given the investment in time an energy so far.
    If you do get it going good it might well be the shiz.
    I'll still stick with shuffling brass though!
  11. #13556
Name:	EFI Dyno 20 to 100% TPS.jpg
    Did a bunch of runs from 20% to 100% TPS tonight.
Name:	EFI Dyno 80% TPS.jpg
    80% TPS
    Interestingly the runs improved up to 80% TPS then got worse out to WOT.
    Also the Octane booster at 10cc per liter of 96 did noticeably improve things but not 100% as there was still some deto but no where near as bad as before.
    Tomorrow night, I will try 98 + octane boost.
  12. #13557
    Getting some where now. Just before the courser is a spike in the Lambda line, this could be an example of what Frits is talked about where a miss fire dumps a whole lot of oxygen into the chamber.
    Remember what I said, with injection ( injection timing control up the transfer ) the spill out the exhaust may well be just air this will tell the oxygen sensor it's too lean. BUT the combustion mixture is just right.
    You need to measure the mixture trapped in the combustion chamber. A bit tricky.
    I wouldn't bother with an oxygen sensor, it might be a bit like my cat and tell you lies.
  13. #13558
    What like she hasn't been fed? Mine does that too.
  14. #13559
    27th January 2011 - 11:30
    asdasd
    AKL
  15. #13560
    It seems to be magnetized to the fridge!
There are currently 199 users browsing this thread. (0 members and 199 guests)
