Page 917 of 2776 FirstFirst ... 417817867907915916917918919927967101714171917 ... LastLast
Results 13,741 to 13,755 of 41630
  1. #13741
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Attachment 294489
    Ok ... I am all geared up for the F5 GP at Tokoroa and I am Looking forward to a hard fought battle for last place.
    Attachment 294490
    Interesting that the torqe curve peaks at max rpm, whats that about....
    you had to bet me by .2 ha ha
  2. #13742
    you had to beat me by .2 ha ha
    The determined dyno racer that I am, I sweated blood to get that extra 0.2
  3. #13743
    GPR150
    palmertson north
    just back mine of a tad for pactice , put a det counter on it to keep i eye on it
  4. #13744
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    Interesting that the torqe curve peaks at max rpm, whats that about, could I squeese some more rpm out of it ....
    Do you always run a slick on the dyno?
    The figures would read higher with road tyres, as I understnad it.
    I do realise it's an arbitrary number, used for tuning purposes only....but bragging rights is bragging rights man!
  5. #13745
    Do you always run a slick on the dyno? The figures would read higher with road tyres, as I understnad it.
    Yes. but only because that is what is on the bike.
    I know that pumping the tyre up hard makes a little more power. Well actually looses less power climbing the hill. Road Tyre = more power, how does that work? less sticktion and/or deflection on the drum? any ideas.
  6. #13746
    Exxon Valdez
    wellington
    Yes. but only because that is what is on the bike. Road Tyre = more power, how does that work? less sticktion on the drum? any ideas.
    Just less drag I think.
    I was told about Chris Ozbourne (I think it was Chris, my memory sucks) tuning a supersport/F2 bike some time ago. It had been track ridden with a slick, or the rear rim had one already, but he fucked around for ages trying to get power he had previously gotten from similar bikes. Only changed the hoop because it got canvas showing from the number of runs he'd done, and BOOM, numbers stacked up.
    Atleast, something similar to those events....I've made memory disclaimers many times.
  7. #13747
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    recall reading way back about AMA roadracing in the 70's, Gene Romero qualified fastest at Daytona by having two front tyres on his Triumph. The reduction in rolling resistance/drag was enough to make the difference. Racing was of course done with proper tyres front and rear
    (PostalDave on ADVrider)
  8. #13748
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    aah
    Attachment 294489
    Attachment 294490
    How come everyone's 50's
    have horsepowers in double figures
  9. #13749
    That's pretty solid, there'll be a bunch of fast 50s this year. Just put mine back together bar final adding water, fettling foot pegs etc. new ring, can see some light down the side so it won't be pulling the 14.3hp it has done in the past . (I can spot a pattern). Well 10 years ago in 2004. It's only had rings, the odd piston and a bunch of wear since then. Oh and 10 GPs, a hand full of BoBs and a million club miles.
  10. #13750
    You have had good value, mine is a borrowed bike so I hope I don't break it.
  11. #13751
    GPR150
    palmertson north
    Wink
    was told by Chris Ozbourne that he has seen 600s losing up to 3 hp with wets .. think its the stick of he tire when releasing from the tire . i did run my 50 up on a wet but some how dont think it heated the tire up .....but .3 hp bugger have i time
  12. #13752
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    That's pretty solid, there'll be a bunch of fast 50s this year. .
    I'm still way behind with what's happening and of course I don't know just when the Tokoroa race day is.(this weekend?)
    Seems that there is 50cc racing on there, - wouldn't mind seeing that! - I have never seen 50cc racing here in NZ, maybe I'll be able to make it there, with a bit of luck.
    Thanks,
    Will.
  13. #13753
    4th February 2005 - 07:32
    Rattlecan blue
    Wil
    Tokoroa is on this weekend. Sidecar GP Saturday, F4, F5 and Tokoroa cup on Sunday.
    Stock is best
  14. #13754
    Tokoroa Air Field and Go Kart club, last side road on the left, off the main road going south, its just on the southern edge of the industrial part of town.
  15. #13755
    Rattlecan blue
    Aim feild road. Turn right at the end and then follow the gravel to the end.
    Stock is best
