Page 923 of 2776 FirstFirst ... 423823873913921922923924925933973102314231923 ... LastLast
Results 13,831 to 13,845 of 41626
  1. #13831
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    It's probably an investment casting, but the cam tracks will possibly be finish machined, too fuzzy to see.
    However, producing the wax pattern itself would be quite a challenge!
    Then again, I could be wrong.
    I think you're right, there looks to be no draught on the webs. Looks a bit delicate but obviously worked.
    A decade ago I would have got the wax 3d printed, nowadays I guess you'd 3d print shells directly.
  2. #13832
    19th September 2012 - 12:26
    simson
    Budapest
    Hello Wob!
    I'd have a question if you don't mind!
    What do you think why haven't become common the use of kart carburetors (tillotson, ibea, JHC etc.) among the gear class karts or scooters?
    Rarely I can see a few attempts (http://www.tuningmatters.com/article...-tuning-guide/).
    In the '90's we tired to use it in ICC class, and it worked very well, although we had to make notable modifications to make the carburetor able to carry enough gasoline.
    Although in case of certain scooters (24mm and 50-90 cc) it would be enough, but they are not used.
    These kart carburetors are quick and easy to set, but still everyone uses the ordinary carburetors. What is your opinion or experince?
  3. #13833
    Best i can do.............
    When you think about it normal shift drums are heavy.......
    I seem to remember the 50 i posted having a different set up i had a gif on how it worked and i think (the Sachs) of the 70's had something different.
    The brits used a camplate.......
    Unless they've used something trick as material, I'd doubt if that's much lighter than the "normal" shift drum. Any gain would come from the lower rotational inertia as the main masses are closer to the centerline. IMO just another example of Honda doing something "just because we can"....
  4. #13834
    IMO Honda shift drums are generally bloody heavy, The MB one esp hefty, the NSR one pictured is very abbreviated it also is hollow ie light. The rotational inerta might help it change gear faster but i think it was a overall lightness exercise,Yes Honda often does stuff as a form of corporate Masturbation.
  5. #13835
    The really good kart carbs with flat slides and 3 jets are very expensive, that is the main reason they are not used.
    Only issue I have heard about ( not my experience though ) is that some have complained the pumper carbs must be backed off the throttle
    too much to make the gearbox change gears.
    I brought back from the World Kart Champs in Vegas a new Tillotson carb that was designed to be used as a replacement for the 34mm Dellorto used on Rotax Max.
    It made better power everywhere, and was super easy to tune - but as I understand it Rotax said no to changing it - that carb was sold to me "cheap " by the chief engineer
    from Tillotson in Ireland, it cost 500USD cash.
    Thats going onto a lucky 100cc bucket engine soon.
  6. #13836
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Unless they've used something trick as material, I'd doubt if that's much lighter than the "normal" shift drum. ....
    In calling it "cast" I'm sure most of us are meaning good quality cast steel here, (as opposed to cast iron) - right?
  7. #13837
    yes - and unlike husa apparently, I'm accustomed to seeing shift drums which are (a) hollow and (b) only solid where they have to be..
    late jap road stuff is pretty good for minimum material use. Even the post classic stuff I see is at least as light as that Honda drum.
    It would be possible to use something like hard anodised 7075 alloy on short use stuff. Ti doesn't like rubbing so rule that out. That leaves good old steel....
  8. #13838
    Aye that remark resembles me.
    I remember the story of TR750 with the mag and ti bits gearbox bits.
    I did find this though while having a fosik.
    Inside an AMA Superbike Suzuki engine.
    http://www.mototuneusa.com/the_factory_superbike.htm
    Honda F1 Car Shift drum should be the last pic
    Honda RA106 Formula 1 Gear Selector Barrel
ID:	295276   Click image for larger version.
ID:	295278   Click image for larger version.
ID:	295279   Click image for larger version.
  9. #13839
    simson
    Budapest
    Thanks Wob! Well, I hoped you would say that!
    You're right, unfortunately they are expensive, but I'm lucky to say that I have 1 or 2 good ones from the '90's.
    Once we have tested on simsons, but I think we're gonna do it again.
  10. #13840
    So ive got some questions about Engmod2T... When modelling a reed cage that has an internal divider or stuffer before the reed petals, do you subtract the area of the divider from the area of entrance to the reed cage when calculating the 'diameter of the rubber block' (entered in the Inlet Port window)?
    From an old thread in another forum but good info on modeling reed inlets in EngMod2T, link posted here so we don't loose track of some valuable reply's and info posted by Wobbly.
  11. #13841
    7th November 2013 - 19:37
    gpr150
    palmerston north
    tweak
  12. #13842
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Quote Originally Posted by steamroller View Post
    tweak
    and I thought Seymour was billotlot maching a rs125 copy engine with a air cooled barrel
  13. #13843
    9th June 2012 - 18:32
    Bucket Sidecar
    palmerston north
    Who said I was only machining one?
  14. #13844
    GPR150
    palmertson north
    Thumbs up
    ok 3 then ha ha
  15. #13845
    why dont you just fit a red power band ?
    http://www.planetash.net/gos/powerbands.html
