Page 925 of 2776 FirstFirst ... 425825875915923924925926927935975102514251925 ... LastLast
Results 13,861 to 13,875 of 41632
  1. #13861
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    I see a fly in your ointment drew the MVX has a 48mm stroke...
    Maybe a Aircooled 125.........
    The extent of work in this crank, replacing the webbs with Beat items won't be the end of the world.
  2. #13862
    You might as well fuel inject it as well. You double up what Rob has. You'll need the 250 chassis to fit the wiring in. Good thing is the 250 alternator will supply the needed ergs.
    I can see it now - watercooled 100cc twin, 15000rpm, fuel injected with 2 injectors/cylinder(minimum).
  3. #13863
    6061 T6 is a good all round alloy for machining engine ( and autogyro ) parts.
    I use 6061 T6 351 to make autogyro rotorheads amongst other things, good strength, good corrosion resistance, machines very well, accepts anodising well.
    Thanks Flettner, sounds perfect. Where do you get your billets?
  4. #13864
    Exxon Valdez
    wellington
    I can't tell if you're being serious.
    I would be using the 250 chassis, it's just had a VFR750 fork conversion and is getting a CBR600 swingarm and suspension. To allow for proper sized wheels.
    I've chopped off all of the standard engine mounts unfortunately, so might have to hunt down another roller. Luckily, not too many MVXes were written off. They tended to blow up before anyone made it to the twisty roads.
    Size of the thing is my only concern really. They're a wide bit of kit!
  5. #13865
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    don't even go there , it will never get done .. i have 2 of them engines and would never do it in a million years
  6. #13866
    I have a friend that rides his MVX every day - so if you guys get bored thinking of ways to ruin one, then remember there are a few people
    out there that need the parts for a runner.
  7. #13867
    I get my alloy from Nalco, good people to deal with.
  8. #13868
    Exxon Valdez
    wellington
    My brother has a runner also. Chap over Coro way from you has about enough bits to make five of them.
  9. #13869
    20th October 2010 - 20:59
    Rg50 Fxr's150
    Try Nalco, Wakefield Metals and Special Steels. Ritchy at Trimac in Penrose has off cuts he sells.
  10. #13870
    Thanks Gigglebutton. I'm in Wellington, so has to be mail order. Nalco are assisting me with my enquiries at the mo...
  11. #13871
    For something different.
    Anne has a F4 Honda 125T she races at Mt Wellington and a girlfriend challenged her to a drag race at Meremere this weekend.
Name:	F4 Anne and her Harley.JPG
    Not sure the friend expected her to front with a 1200 Harley, but why bring a knife to a gun fight.
    A bit of time spent on the dyno sorting out which gears to use and the best one to start off in.
Name:	Beast vis  Annes Harley.JPG
    Just out of interest, a comparison of my 2T (the Beast - blue line) with the Harley.
  12. #13872
    Exxon Valdez
    wellington
    I think you had the final drive ratio entered incorrectly. It's a seriously wanked skirtster that'll pull 200k's, and sixty ponies suggests otherwise.
  13. #13873
    Hmmm yes I see what you mean, but no head wind on the dyno to hold the bike back so the Harley just keeps spinning the drum until the rev's top out, in real life it would have to fight a head wind too.
  14. #13874
    Exxon Valdez
    wellington
    I would have thught it would be bouncing off the limiter before 125mph still.
    Smooth curve though.
  15. #13875
    Its pretty good for a stationary pump, i thought they didn't get much more than mid 50s, but that was a while ago, not that progression has probably been more than glacial. Back int he Dyno-tech days Chris was doing a few, but the word got around that his dyno read low & Scooter-centre got one that read closer to the 'proper' numbers so everyone was happier. Chris also had an unfortunate habit of testing things, like removing the Gen-ewe-swine Raped Budgie(TM) parts like the Thunder jet etc that they'd just laid out money for & gaining power. Clearly didn't know what he was doing.
