Page 945 of 2774 FirstFirst ... 445845895935943944945946947955995104514451945 ... LastLast
Results 14,161 to 14,175 of 41606
  1. #14161
Name:	RGV250 Air Cooled Cylinder -1.JPG
    The head is off with Flettner to have the combustion chamber machined.
Name:	Air Cooled RGV cylinder 1.jpg
    In the meantime I have been using EngMod to explore what needs doing to get the required STA's.
Name:	Air Cooled RGV STA's.jpg
    The blowdown STA is the critical one as that pretty much defines what is possible followed by the transfers. Wobs advice is to go a little higher on the transfer STA to make up for any short comings in their real life flow characteristics.
Name:	Air Cooled + Methanol and 15% Nitro.jpg
ID:	297326 Methanol+15%NitroClick image for larger version.
    I think that next year I will try for a rule change allowing model aeroplane fuel. Fuel for kids toys, cant be any harm in that, and we need to get more kids into Buckets, MX85's and all that, right.
    Seriously I hear there is another TF100 project happening, Flettner is building it and if it comes off we will get to test it on the dyno and take it out to the track...
  2. #14162
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    SO the ring shape about 4mm larger than the crankpin is only witness marks.... from the rollers....
    Think so. Also, look at all of the other marks on the inside surfaces, either someone's ground the pin in situ, (unlikely) or the rod's a) had an almost full width beam and b) has floated so far sideways that it's begun to do a similar job...
  3. #14163
    KTM 1290 SAR
    Wgtn
    Doubt that the marks on the bronze would be the rollers, as for sure they would be encapsulated by the cage - unless that crank has had a cage failure.
    Perhaps the cage made the marks? Or the side of the rod journal. Either way, from the cracks and surface colour it looks like the bronze has worn far more rapidly than normal, there's been violence committed inside that unit.
  4. #14164
Name:	RGV PV 001.jpg
    I have just managed to get a set of three stage power valves.
Name:	RGV PV 003.jpg
    It looks like the RGV250 three stage timings are:-
    104 atdc
    90 atdc
    84 atdc
    I am not sure how much these can be changed but I would like to have fully open at 80 atdc.
  5. #14165
    31st July 2005 - 11:15
    a shed full of crazy shit
    104 atdc
    90 atdc
    84 atdc
    Looking forward to seeing this unfold Rob.
    Having seen Mike's one and Scotty rocket many years ago; I'd always wanted to build one (even had all the parts for it)....
  6. #14166
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    How far the blades are from piston? Could You take for me a foto looking from outside of ex port?
  7. #14167
    I wont be back in the shed for a day or two to take a photo but from what I could determine the gap was very close 0.5mm or so.
  8. #14168
    There is a tiny bit of gold buried in here, can you find it Rob...
ID:	297355   Click image for larger version.
ID:	297356   Click image for larger version.
ID:	297357   Click image for larger version.
ID:	297358   Click image for larger version.
ID:	297359   Click image for larger version.
  9. #14169
    27th January 2011 - 11:30
    asdasd
    AKL
    Interesting read, thanks for posting Husa. How old is that article out of interest
  10. #14170
    This one i did not scan, but stole from the 2SMX site but i'd say 76-78 as it was a M model.....
    Guessing the physics have not changed though.........
    below nice pic of atac.
  11. #14171
    Ha Ha, amazing - guess who just got the job to do the solid modelling for CNC machining new replica head chamber shapes made on the Webco dies.
  12. #14172
    Those webco heads were much better than some OE for finning area...Are they wanting OE replica shapes or are you sneaking in improvements ? Ask if they'll list unmachined heads too if you would please...
  13. #14173
    Did you see the "gold" buried in there Wayne?
    show us a piccy......
ID:	297369   Click image for larger version.
ID:	297370   Click image for larger version.
ID:	297367   Click image for larger version.
ID:	297366   Click image for larger version.
  14. #14174
    Honda solid copper head ?
    All I have at this stage is the CNC shape to do the first head for a 250 twin.
    But will keep you lot informed as the project advances.
  15. #14175
    12 pounds of it they must have thought it was worth it
There are currently 60 users browsing this thread. (0 members and 60 guests)
