Keys don't hold on stuff, the taper does...... if it came off the nut was loose and or the taper was shagged. keys are only the locating device on flywheels.
lap it on, nut up tight, they stay there....... I learnt that lesson after I lost my flywheel a couple of times![]()
I have a question about boost porting (picture on the bottom of post). Does this type of boost port grinded in liner in depth around 5 or 6mm is worth doing ? I tried this one back few years ago but I was more in style "do a shitload of ports in cylinder " didn't even know that something like STA is existing![]()
And I'm attaching a photo of a piston which was used around 150km, would this help to get the black spots off the piston? Boost port cannot be any wider because ring pins are 2mm from it. Ducts are "crappy ones" not much to be done with them. Thanks in advance.
So Sic won 6 races in 2008 and took the 250 title, by your way of explanation Drew then he was a genius that year.
Trouble is he won 6 races in 2009 and lost the title, as so many of the other points were shared out between Aoyama and the Aprilia satellite teams with so called no names on board.
One race has shit all to do with it - explain then the 2006 Moto year where there were 8 race winners, Hayden won 2 and took the title.
Were all those riders only average then - tell Rossi that.
I still come back to the later results, short lived as they may have been, where Sic was on the Moto pace instantly, Aoyama was and still is nowhere, his accident hurting his back badly made no difference before or after.
The auxiliary ports fed thru the piston do " work " in that they are better than none at all if aimed correctly but the flow is very compromised
having to get thru the hole and into a slot.
Can you give us a picture of the cylinder base - is it possible to cut B ports with ducts all the way down to the case.
These would exit directly across the piston, as opposed to working like auxiliary boost ports aimed upwards next to the main boost.
I have used Loctite bearing mount on the taper of a rough corroded crank. Bit of a bastard to get apart but never came off by itself.
I've seen GSX1100 generator rotors win the race to the end of Pukekohe's front straight.
The first Rotax tandemtwin engines (I received the first two in December 1980) had long tapers on the crankshafts and in the large primary coupling gears. In addition Rotax seemed to have used the strongest Loctite available on those tapers. In trying to get the gears off their tapers I broke two pulley pullers, without joy. I had to heat the gears to such an extent that I had to bin the oil seals afterwards.
One of the many mistakes in those first tandemtwins was that the oil seals ran not on the crankshafts, but on bushes on the gears. This allowed air to leak through the key slots in the tapers, causing all kinds of nasties.
Lessons learned: never use Loctite on tapers if you ever plan to take them apart again; just grind them with abrasive valve paste if they are not a perfect fit. And look for air leaks in even the most improbable places.
There are currently 117 users browsing this thread. (1 members and 116 guests)
