Page 983 of 2773 FirstFirst ... 4838839339739819829839849859931033108314831983 ... LastLast
Results 14,731 to 14,745 of 41592
  1. #14731
    rode the bike today and it pulls 1000 times better below the pipe than the last cylinder. probly because the ports arent sky high i suppose. mostly the transfers probly. before it seemed to have 1000 rpm wide powerband. below that and it couldnt recover without down shifting 1 or 2 gears. now it pulls back to the pipe alot better without down shifting ( in most situations). i left some meat on the bone so i can make more cylinder adjustments if needed. any body got ideas how to get more power without the midrange dropping out, like the last cylinder ?
    heres what i got
    honda T port exh and no powervalve
    exh 192 and about 90% width
    A trans 128 and 20* upward
    B trans 127 and 15* upward. piston dome is 15* also
    C 127 and 62* if i recall
    i did the best i could with the upward angles. honda had them backwards. 20* on the rear and 15* on the front so i did the best i could with what i had to work with. i even lifted the cylinder up slightly with thicker gasket to try and correct the floor angles.
    didnt get the spacer installed under the reed stopper yet. should be able to get that done this week and tested next weekend. i think it will help as the current 7mm lift seems really small. still might not be enough lift with the spacer but atleast ill know if im going in the right direction
  2. #14732
    204* on the ex. Don't be a pussy.
    you might need to use the clutch.
  3. #14733
    ive tried 200*. with 132 A and 130 B if i recall. worked ok. but i want to find a good compromise with lower ports. at some point i think the ports get so high you gain nothing but overrev which is useless for me. i ride in sand so there needs to be some power slightly lower in the rpm otherwise the sand can pull the rpm down too easily. maybe 8spd gearbox is the answer
  4. #14734
    Like your old 50 with the power spike...
  5. #14735
    Sorry I might have been being a bit silly. I think my grape juice might have fermented.
  6. #14736
    You only need to fill in 3 pages of EngMod to get the full benefit of the STA readout page.
    Just having the engine, Ex and transfer inputs will tell you where the ports are in relation to what you think you need.
    You , and we, are simply guessing at what is happening until you can give us the STA printout.
    Do that and we can help.
  7. #14737
    Ok a Tesla Turbine is not a 2T, but whatever happened to this great invention from a 100 years ago. Supposedly better power to weight and energy conversion than any other motor.
  8. #14738
    Ok a Tesla Turbine is not a 2T, but whatever happened to this great invention. Supposedly better power to weight and energy conversion than any other motor.
    The tesla one way valve is even cleverer
  9. #14739
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    If you've got shitloads of compressed gas handy and don't mind losing most of the HP converting all those rev's into something useful.
  10. #14740
    29th March 2013 - 14:57
    Honda NS-1 / Gas Gas EC-125
    Portugal
    If the only thing that provides torque is the viscous coupling between air flow and the polished discs, the torque values might be in the 0.0x kgm range?
    And yes, something has to provide a high flow of pressurized air/gas, that is no free power, so use a combustion engine coupled to a air compressor to drive it?
  11. #14741
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    That's a mighty inefficient way of making something spin.
    If you want big revs and few moving parts, gas turbine all the way.
  12. #14742
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    If the only thing that provides torque is the viscous coupling between air flow and the polished discs, the torque values might be in the 0.0x kgm range? And yes, something has to provide a high flow of pressurized air/gas, that is no free power, so use a combustion engine coupled to a air compressor to drive it?
    That's a mighty inefficient way of making something spin. If you want big revs and few moving parts, gas turbine all the way.
    Intuitively you would think so, and yes something has to provide a high flow of pressurized air/gas, to drive a conventional turbine to, the same thing could be used to drive a Tesla. The Tesla was conceived in the days of steam but with modern materials it might have a place in the turbo jet age too.
    The Tesla works on drag of the boundary layer so the gap between any two blades is adjusted to twice the boundary layer thickness and in this way the coupling between blade and driving medium is very closely coupled.
    http://en.wikipedia.org/wiki/Tesla_turbine ""The turbine efficiency of the gas Tesla turbine is estimated to be above 60, reaching a maximum of 95 percent. Keep in mind that turbine efficiency is different from the cycle efficiency of the engine using the turbine. Axial turbines which operate today in steam plants or jet engines have efficiencies of about 60 - 70% (Siemens Turbines Data).""
  13. #14743
    12th March 2011 - 02:31
    r6ypvs hybrid
    Turbines do not like shifting, better have a variator style tranny.The tolerances are very hard to maintain as well, having worked on them up to LM2500 25K' hp they are light and powerful but piss poor in small vehicles.
  14. #14744
    Turbine bike Y2K
    https://www.youtube.com/watch?v=BgwmiQr_t8M
    Interesting but a bit useless.
  15. #14745
    Exxon Valdez
    wellington
    Fuck it, go jet then.
    Pretty hard to quantify the engine 'size', but that's up to the protester to try and figure out.
