I may have to try it one of these days. It'd be a neat and tidy solution if it works.
Here you go Rob. An update on the NSR300. At the end of the lap the other 300 comes into view.
Disclaimer. The EGT is reading wrong. Its earthing out on the mount and reading hi. And the rev counter not working so just don't look at that.
What rpm are you gearchanging the 300 at Rich ?
Great work guys.
There was a lot of talk around the paddock about these Speedjunkie/fortyfive racing NSR300s.
You guys should be proud of the time and effort you have put into them. Clearly the best presented bikes on track and boy do they go....
Do you have the full video of the last "carb class" race? Missed it dealing with the juniors...
Sounding nice Rich, and looking like its haulin.
I'd be interested to hear opinions good or bad on any of the racing plug electrode configurations (hopefully) attached.
http://www.kiwibiker.co.nz/forums/at...&thumb=1&stc=1
I use the flat type, third one back on my Kawasaki, on ethanol fuel and heavy oil mix. Never fouled it yet. Ignitec fires it through both channels at once.
You need serious spark voltage for the surface gap plugs. Obviously you do have...I'm impressed.
As an aside you can get preignition - or autoignition - with surface gap plugs. They're plated on the large ring electrode, i've had the plating flake giving sharp, hot edges...Just machine a tad off.
The middle one is the type developed by NGK for Honda RS125/250.
Been there done the dyno work - those special tip type plugs make more power - end of story.
They were originally a short body type, and cost a fortune, including the special short cap as well.
The R7376 has a normal body with that electrode configuration, Platinum fine wire earth, and Iridium fine wire centre.
Kicks arse with the Denso equivalent and the B10EGV type simply isnt in the same league.
There are currently 178 users browsing this thread. (0 members and 178 guests)
