Those barrels look damaged. I wouldn't buy those Husi. I don't think they are supposed to come apart like that.
Fair enough
Here is a Yamaha to keep you quiet then.
plus this kitset version is on Trademe at the moment
http://www.trademe.co.nz/motors/moto...-774174269.htm
Yes hense the lol looks like a Honda, still not 100% sure it is NSR500 though, in the advert it did say NSR500 (but gave a TZ125 part number) i had never seen a Bartol cylinder but i suspect you and Wobbly have, and wondered if it was one of those?, I understand they were copied directly off a Honda.
After years of humiliation by Honda power - Yamaha finally caved in and went long stroke and even used a T port for a while, but corporate pride was
involved I suspect and they never used the HRC dropping gate power valve to my knowledge.
A single blade in the centre and then finally their own bees knees and went back to the rotating spool, so a Yamaha with a dropping gate - dont think even Harold would
have got away with that.
I have exactly the same HRC cylinder cut up like that in a box here you can have for nothing.
So the bike has done plenty of hours now in various states of tune. After looking at the numbers again comp is sitting at 15.9:1.
Its time to update the cylinder head shape to the steeper bath tub profile. I can't see any sign of det anywhere. There is a ring in the squish band but that looks like its touching on some of the carbon build up on the piston. If anyone can see any major problems in the pics sing out.
Cheers Rich
VHM head Rich?
Ive just measured a 90° angle on my desk with a paperclip
there is no way to get 90° because of spring back
do you have a source of specially annealed clips?
but your methology must be bend it to the angle you think it is and see if it fits the fit nicely?
- I like the idea but will use softer galvanised garden wire
to measure the roof you wont ever need to bend the clip to a full 90* because every transfer port roof ive even seen had atleast some upward angle. just bend the clip on the table corner then put it in the port and see how well it fits. bend it alittle more or use a new clip and bend alittle less, until it fits well then measure the angle. only takes a few minutes
for the floors just bend the clip to the full 90* on the table corner (or as close to 90* as you can), then set it on the table top and bend alittle more past 90*. its rather easy
perhaps theres a better simpler way to measure the port angles but the paper clip was always simple and easy for me
you may have good luck with wire or even solder.
There are currently 49 users browsing this thread. (1 members and 48 guests)
