Page 994 of 2776 FirstFirst ... 49489494498499299399499599610041044109414941994 ... LastLast
Results 14,896 to 14,910 of 41626
  1. #14896
    free blowys
    Yes it is a generous offer and I intend living a long time, but seriously I am very grateful to Wob for his help and tuning advice.
    Hopefully we can get a bit of reliable hp and a decent power spread from the air cooled RGV project.
    RGV250 dyno run, 60+ rwhp, I am looking to do better than 30 hp with the single cylinder air cooled Suzuki GP/RGV125 half Beast.
Name:	RGV Heat Sink 2.JPG
ID:	300720Click image for larger version.
Name:	RGV Heat Sink 1.JPG
ID:	300721Click image for larger version.
Name:	RGV250 on Copper.JPG
  2. #14897
    Doing 30 RWHP means a crank power of around 35.
    Do that at 12500 rpm and we are looking at 10 bar bmep - easy enough, even if not everything is done right.
    At 10500 and that is 12 bar bmep, being aircooled and on a 24mm carb a 125 I believe would have to be so specifically designed and perfectly executed for that rpm
    it would be completely useless everywhere else - Im still sleeping safe in the knowledge there wont be any need for random knob gobbling on my part.
  3. #14898
    Doing 30 RWHP means a crank power of around 35. Do that at 12500 rpm and we are looking at 10 bar bmep - easy enough, even if not everything is done right.
    This is realistically where I expect to get to with some reliability and a decent spread of power.
  4. #14899
    Thank Christ for that, I can help no end with that endeavour as long as it doesnt involve shit I expect ( sorry - I would like ) my wife to be adept at - sucking the chrome off a tow ball.
  5. #14900
    Those ones come with strings attached
  6. #14901
    .... and on a 24mm carb ....
    TeeZee probably hasn't forgotten about his plenum idea for dealing with the handicap of having to use a 24mm carb.
  7. #14902
    Yep, have not forgotten. With a carb, fuel dropped out inside the plenum, fuel injection into the transfer ports was my attempt to fix the puddling in the plenum issue, if I can get the fuel injection sorted we will re visit the plenum idea.
  8. #14903
    In my quest for ultimate power, I have collected quite a few pistons from various 2T engines, and have carefully measured them all.
    Most have an offset gudgeon pin, and mostly it is offset about 2% of bore toward the inlet side, but I have two pistons with offset of more than 4% toward the exhaust.
    I've measured these two a dozen times to confirm this.
    If I use one of these, is it going to cause me grief? Actually they always cause grief, but will these be worse?
  9. #14904
    Not enough effect on power to make bugger all difference, it will just rattle more or less when cold.
  10. #14905
    Thanks Wobbly, that's reassuring.
    I thought the offset was always toward the inlet side. What do you think would be the reasoning behind offsetting the other way?
  11. #14906
    Like its owner
  12. #14907
    Depends on the direction of rotation if it has a jackshaft in its origonal home ie arround 82 tz's the engines ran backwards
    The effects of pin offset can be modeled in sims TZ did one a while back just to see the effect of a desaxel design.
  13. #14908
    Wobbly, A question.
    Can one ask you to make a calculation for a pipe(Friend will build pipe himself)?
    Ofcourse nothings for free, i understand that.
    If yes, can i pm you?
    Best regards
    Patrick
    Sweden.
  14. #14909
    Unhappy
    Like its owner
    That's cruel Dave, I roll rather than rattle. Then I pick up the bike and carry on
  15. #14910
    Thanks Husaberg, but the piston that is offset toward the exhaust is from a bike that rotates the usual way, i.e clockwise if looking from the right, with exhaust at the front.
    Seems like the consensus is that it would rattle a bit but not cause any damage.
