Page 995 of 2776 FirstFirst ... 49589594598599399499599699710051045109514951995 ... LastLast
Results 14,911 to 14,925 of 41631
  1. #14911
    25th March 2009 - 23:55
    Honda Cub
    Mars
    TZ's ran backwards way before 82..think BIG TZ's. Running the piston with the offset the wrong way won't make a blind bit of difference, in practical terms..BTDT.
  2. #14912
    Most have an offset gudgeon pin, and mostly it is offset about 2% of bore toward the inlet side, but I have two pistons with offset of more than 4% toward the exhaust. If I use one of these, is it going to cause me grief? Actually they always cause grief, but will these be worse?
    Piston pin offset theory and Engine noise reduction.
    Below is a Thesis on the phenomenon of Piston Slap.
Name:	Piston Slap Background.jpg
    http://dspace.mit.edu/bitstream/hand...6/30012843.pdf
  3. #14913
    New Head
    Just for you Mr Wobbly.
    After you bagged my first attempt head, it has been eating me up inside ever since I installed it ( not really ).
    Here is the second attempt. 16:1 48% squish band .77 squish. Plug tip 5.8mm from piston top.
    It will be interesting to see what happens on the dyno. The other heads seamed to be working very well. No sign of det.
Name:	new head_photo.jpg
  4. #14914
    Quote Originally Posted by fatbastd View Post
    This is true.
  5. #14915
    31st July 2005 - 11:15
    a shed full of crazy shit
    They have come up well, looking forward to running those up next week.
    Now have your plugs arrived so we can do TPS maps???
  6. #14916
    29th March 2013 - 14:57
    Honda NS-1 / Gas Gas EC-125
    Portugal
    I was also intrigued about the desaxe layout, to apply in a 54mm x 44mm engine configuration, thinking that having the piston in the PMS after the crank as passed the 90º mark would improve the torque delivery, but to even see a difference with eng-mod I need to go crazy and put 5mm off-set in the piston.
    Is it a bug, or is the "advantages" of the off-set pin something so reduced/limited?
  7. #14917
    Frits covered it further back........ Yamaha achieve it via offsetting the crankshaft and cylinder on quite a few modern bikes. ie YZF450
    The port timing can be made asymmetric on a two stroke.
    I think TZ ran the sim up to 12mm?
  8. #14918
    Portugal
    Up to 4mm would be easy to do, just mill the crankcase off-set and add some guide pins, more than that would need welding, but given the over-squareness of 54x44mm its a strange layout to work with, the exhaust pipes need much different sizes when compared to a more conventional square or almost square engine, the combustion chamber is also stranger and more difficult to react to some changes talked here.
  9. #14919
    Portugal
    And then there is the strange W shapped exhaust port, here with already a couple hours of work into it to gain the much needed blow-down to get this cylinder to really shine.
  10. #14920
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    There to hold the ring in its gove perhaps?
  11. #14921
    Portugal
    Yes, without the "teeth" the exhaust port even with original specs/size would be over the safe 75% width, but they steal a lot of usable area.
  12. #14922
    Senso, is that a Gilardoni cylinder?
  13. #14923
    Portugal
    Yes, gillardoni italkit for yamaha dt 80 lc, used a lot in the dt 50 lc in Portugal, with strokes from 40mm to 48mm, there is a dozen brands and home shops doing cranks for them.
  14. #14924
    So tell me whats the advantage of having 3 overheating ' teeth ' hanging down ( up ) in the Ex port over a simple 68% main port and huge Aux
    to generate the needed blowdown STA.
    Unless you were intent on buggering the ports Cd numbers as well as heating up the returning plugging pulse - I really dont see it.
  15. #14925
    Hey Rich that head looks alot like Mr Thiels for his Aprilia, hope it works as well.
    Personally I would have done a toroid, but you have the plug plent close enough to the combustion burn space
    so probably no free lunch to be had.
