I'll have a look in the manual once I get home.
thanks, the manual I have doesn't say sizes.
My problem is that my brakes have no obvious problems left to fix and I still have a soft lever with huge travel. My master cylinder has 1/2" stamped in the front it, would be an easy check if someone could please
I have an acrobat reader copy of the GPX manual but cvouldn't get it to upload to KB![]()
My manual gives no sizes either, My gpx Brakes (apart from worn pads) always felt good except for when a piece of grit made its way into the brake line and would lock the brakes on hard if i merely touched the lever (this happened when i was on my way to dit my restricted test)
i assume you've renewed the brake fluid, and sufficiently bled the lines? did you do this with the caliper/master cylinder on or off the bike?
either size issue with KB or my internet being too slow, even though it's broadband... PM me your e-mail address and i'll try that way for you
Its all over the internet if you want to find it.
fair enough...
found it here
http://pdftown.com/Kawasaki-GPX250-Service-Manual.html
(direct link http://pdftown.com/u/gpx250/ )
