Results 16 to 30 of 32
Thread: Front Brake Problems
  1. #16
    Gee I’m confused. Is Motu on your ignore list? It is 90% likely to be free to fix.
    Type in bigger font Motu, people can’t read your sage advice.
    Ride the bike until the brakes lock up. Remove brake lever. Marvel at how this fixes the problem. Adjust or replace lever with genuine article so there is some freeplay.
    Seen it again & again.
    PS: saw a sign saying ‘Motu Enterprises’ when I was in Motuaka, almost took a pic to post but didn’t have the digital with me.
  2. #17
    22nd April 2004 - 15:31
    GSX-R600K3
    lower hutt
    Quote Originally Posted by F5 Dave
    Like I said earlier I don't have time at the moment to do this, I might have a go at playing around with it next time I'm out at my uncles as I don't have a tig welder either.
    Life is difficult because it is non-linear.
  3. #18
    20th November 2002 - 11:00
    Big Orange KTM
    Very Hot Place Out West
    Take your calipers off and clean the pistons, takes about 10minutes & you dont have the time?? Think about it next time you go for a ride!
    Motu & F5 Dave have both given sound advice, stop complaining and do something about it.
  4. #19
    Ha - you make me laugh...fair dinkum,years ago I used to answer the phone on sundays with (insert my real name)'' Motu's free mechanical advisory service''...my mates wouldn't blink an eye and go right on - 'hey I've just pulled the head off,what's the head torque and tappet setting?'
    It's an easy,and I think fun thing to do - go for a blast,using the brake hard till you feel it come on,back off the bleed screw,or remove the lever,go home and file some more off.Now I've got a tool on my belt that can solve the worlds problems,I'd rip it out and file away on the spot.
    Waging war with society
  5. #20
    GSX-R600K3
    lower hutt
    Quote Originally Posted by doug green
    Well I might give it go on the weekend then If I'm not busy, I'll have to go get some brake fluid sometime then.
    Thanks guys for all your advice.
  6. #21
    23rd November 2003 - 21:16
    big red one, rgv's, kdx's
    I put an RF900 front on my GSXR750 and had the exact same problem with the brake locking up. with mine it was due to the brake lever being bent in such a way that it put just a tiny bit of pressure on the booster and as you rode it pumped the brakes up. Gave me the shits the first few times until it was worked out. GSX and GSXR brakes can be a pain in the ass.
  7. #22
    Quote Originally Posted by dhunt
    . . . next time I'm out at my uncles as I don't have a tig welder either.
    That’s funny I don’t have a tig welder either.
    I was going to mow the lawn, but I don’t have a Brazilian fishing licence.
    What the???
  8. #23
    GSX-R600K3
    lower hutt
    What the???
    Need the tig welder to build up the weld so I don't have to pull my leaver in so far. I thought that's what you were on about me doing???
    Why I'm at it, if you pull your calipiers apart do you have to replace the o ring seals or can you normally get away with using the old ones.
  9. #24
    Um, no, the exact opposite, if the lever is slightly pushing in the master cylinder piston then you need to file it. Or you could file the stop so the lever opens more which is preferable if your hands are big enough to grab a lever that is a little further away.
    Usually the seals are good, but be prepared to by new ones if any doubt.
    Really I’d try the lever first.
  10. #25
    GSX-R600K3
    lower hutt
    Ok now I understand what you're trying to say. I've already filed it down so it doesn't lock up anymore, So I was thinking you ment put more weld on and then slowly file that away, hence the need for a welder. Also filed it so the leaver is slightly further away.
    Yeah that's what I'm a little worried about pulling the calipiers apart but I guess if it has to be done it has to be done.
  11. #26
    On my XLV750 I changed the lever to bring the lever in closer for my dainty girl like hands...but I filed a bit too much on the last attempt.As a temp fix I folded a peice of stainless cut from an old hose clip and used it as a shim - it was still there 3 yrs later when I sold the bike,never did bother to modify another lever,if it works,it works
    Seals can often be used again,but I'd get some anyway - you don't want to be standing there with your calipers spread over the bench saying...''shit!,now I need some seals and they have to come from Japan!''
  12. #27
    GSX-R600K3
    lower hutt
    Quote Originally Posted by Motu
    Yeah that's what I'm afraid of. So I might leave playing round with them until I can afford to buy some new seals.
  13. #28
    17th February 2005 - 11:36
    Bikes!
    Didn't read the whole thread, so hope I'm not repeating too much. What you did by adding the weld, was take the free play out of the master cylinder, which means the brakes were essentially on all the time (which you probably gathered). Because your brakes are ineffective till about half pull, you wouldn't have noticed initially. No foul though, seen plenty of people (even mechanics) do it.
    If the bike is getting on, it's probably a combination of things causing the 'squish'.
    - Hoses are buggered (either new ones from the manufacturer, or Safe R Brakes in Chch can make new ones with low expansion hose).
    - Calipers are gummed up, and the caliper seals are worn. The caliper seals are a square section that skews under brakes, so they might be knackered and worn out. They're almost always an 1/8" section oring, availble from any brake specialists (I have a list of them if you're stuck, I'll even give you the part number if you measure the piston diameter)
    - Master cylinder seals are poked. Needs a new kit, probably from the manufacturer. Although if the bore is poked, it'll need resleeving. A few places in NZ do that, the better ones will rekit it as well as sleeving it, saving you the trouble (and probably the $100 a genuine kit costs, because they've had seals made to fit).
    - It isn't bled right, or the fluid is old. Air compresses, fluid won't. Master cylinders must be primed (get the air out) before hooking up the hoses. They're like oil pumps, they won't pump air. Bleeding bikes is a pain. The air has a long way to go down, and it wants to keep floating back up. You need someone who can do it, or the easiest way for someone who is new to bikes is to make the calipers higher than the master cylinder whilst they bleed. There's other tricks, but that's easiest for Mr I've No Tools.
    - Pads/discs are poked. Doesn't help when the brakes are taking up heaps of space where ridged/lipped discs and pads are meeting.
    A combination of these in small amounts is enough to turn good systems into poo. I hope something here helps.
    /edit: Can't think of a good reason to ever start modifying levers if the brakes are in good nick. Most levers have that sort of adjustment built in (sometimes a screw, sometimes a span adjuster, cause lets face it, the only thing you can really adjust there is the span.... And a good tip is always always clean your caliper pistons when you change pads. They're sticking out, and you're about to push them in. The dirt on the pistons is all bad news for the seals. Just use a tooth brush and hot soap water (or brakekleen if you've got it). Takes 5 extra minutes, and most bikes don't have the dust seals that cars do. Don't ever use anything petroleum based on brakes though (like CRC, kero, petrol etc), just hot soapy water will do it
  14. #29
    11th November 2002 - 13:00
    2001 Yamaha FAZER 600S
    Devonport,Plymouth,U.K.
    Well It looks like I'll leave them as is for the time being as I don't have the $$ or the time to spend on them at the moment. Maybe in the rainy season (winter) I'll spend some $$ on them and pull everything apart. Should be fun but I'm currently saving all my $$ to get me through my last year at uni.
    I hope your not going to ride it like that,never take any chances with brakes or tyres,could well cost a whole lot more further on down the road,you`ll be anacident waiting to happen.
  15. #30
    25th July 2004 - 12:00
    70's Superbikes
    Naike- Just Doin' It!
    Quote Originally Posted by Paul in NZ
    Usually, there will be a specified (and often adjustable) amount of free play before the lever starts to move the m/c piston. Never a good idead to remove this. (as you found out)
    Have a look at the fluid (should be changed regularly) and the hoses. They age and are better off replaced with braided lines. The original rubber ones were deliberately chosen to allow for some swell to give some feel at the lever. Over time, they degrade.....
    I'd really recommend a proper overhaul. Clean the calipers, new pads, new lines and a kit in the m/C. Should not cost too much... If it were a Guzzi
    Paul N
    btw - I damn near pissed myself. Thats a bloody great story.... I might steal that one day!
    Yeah, and if you do go to stainless- make sure they are DOT approved lines as next WOF you might get knocked back.
    Good advce about using new fluid, always crack a new bottle when doing the bike, use the leftover for the cage.
    Rubber hoses are OK for a reasonable lifespan, they will expand over time and hard leaver input.
    The M/cyl freeplay will be listed in the manual, and is vital you get it correct.
    For the price of a few cups and dust seals [ try to get general ones from a Brake and Clutch outlet before you go 'Factory' replacements] it would be worth pulling it down for an inspection. If only to check the movement of the pistons and if any lips have formed in the bores. Then at least you know it is all good afterwards, surgically clean, new fluid, blead up, and then see....
