Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Power problem?
    29th December 2008 - 11:50
    1989 Honda CBR250R
    Power problem?
    Hi guys,
    Just bought a CBR250R and it seems to have a power problem. Can't seem to rev it pass 11k rpm. Any suggestions or places to go get it fixed in Auckland.
    4th November 2007 - 13:39
    a fucking hornet
    dunedin
    Quote Originally Posted by ngy View Post
    Hi guys,
    ummmmmmmmmmmmmmmmmmmmmmmmmmm donno
    plastic fabricator/welder here if you need a hand ! will work for beer/bourbon/booze
    come ride the southern roads www.southernrider.co.nz
    27th November 2003 - 12:00
    None any more
    Ngaio, Wellington
    If wanting to rev a CBR250 kitchen whizz beyond 11,000rpm is the answer, what's the question?
    10th September 2008 - 17:54
    2010 Predator
    Coro
    Hi guys,
    Could be it's not getting enough gas,fuel filter partially blocked...
    Or same with air filter,could do with a blow out with an air gun....
    But it's a Honda.....it'll be something simple.
    3rd October 2004 - 17:35
    where abouts in auckland are you? I could have a look for you.
    14th July 2006 - 21:39
    2015, Ducati Streetfighter
    PAst 11k - what do they redline at?
    5th November 2006 - 15:14
    VFR400 & CBR250R
    its an MC19 CBR so i think they are 19,000RPM redline.
    i'd take a look at the following things.
    Airfilter could well be old and gunked up
    Fuel filter, make sure there is fuel getting past properly
    sparkplugs may well be shot too, take a look at those make sure there is good spark coming from all 4
    VFR400 & CBR250R
    sorry its redline at 18k but goes around to 20k
    Nearest Yamaha dealer...
    1989 Honda CBR250R
    Quote Originally Posted by renegade master View Post
    I'm in newton, the bike is off the road at the moment. Got to find a gear lever, broke it in an accident just before Christmas.
    Quote Originally Posted by aer0 View Post
    Correct it's MC19. Kinda annoying when your riding and you know the bike can do more. I'll pull off the tank in the weekend and check out the filters and spark plugs.
    The bike has done 9,000 km, I suspect it's been sitting around for some time in japan.
    VFR400 & CBR250R
    9000 kms in 20 years of life is fuck all!
    sounds like its been sitting for a long time. i would do those checks and see how it is, maybe look at your battery too? that may not be supplying enough voltage. ill measure the voltage on mine tomorrow when the engine is running to double check but it should be 13.8v or thereabouts when its running...
    13th September 2005 - 18:20
    Crashed it.
    Fresh import, just complied & registered? Quite possibly just water down the plug holes.
    If it wasn't for a concise set of rules, we might have to resort to common sense!
    1989 Honda CBR250R
    I should have just taken the tank off earlier, I just wasn't confident enough to do it. The filter looked a little dirty and I can't figure out how to get the spark plugs yet.
    I think i found the problem. A hose clamp on a fuel line was left off, hopefully that should have fixed it. No wonder I could smell petrol. I also found a few other problems with my bike while I was taking it apart. Obviously the previous owner have been screwing around with the bike.
    Any way I went to put the fuel line back on the the tank and managed to put a split in it. .Once I go for a shop and get it running again I'll post back with an update.
    Need to find a gear shifter as well.
    1989 Honda CBR250R
    Quote Originally Posted by Max Preload View Post
    Brought it off a guy on his learner that had it for 6 month. Will look at the plugs once I can figure out on to get the wrench down there.
    Crashed it.
    First time you've mentioned that. You should have said something - I'm the fuel leak master... just ask the guys on the SATNR!
    For hose just get some from Supercheap or Repco (they have 5/16" and above) or given it's a bike and so possibly an uncommon size (like the 5/32" oil hose I recently replaced on my boat's outboard) go somewhere like Enzed or Hydraulink. Just make sure it's oil & petrol resistant, not just windscreen washer hose. It'll be marked with SAE 30R7.
