Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Engine oil level.
  1. #16
    16th September 2004 - 16:48
    PopTart Katoona
    CT, USA
    Oil good 101
    Rule 1 - Oil gauge only reads from oil sensor - not whole bike, trust it as a last resort (long story). If you are unsure - keep an eye on the temp gauge, if it spikes or fluctuates, your in trouble.
    Rule 2 - You also can hear when oil isnt where it should be (if you use a good oil), as the motor becomes quite noisy and ratt-like. Grinding noises, cam rattles....etc get worse with limited oil.
    I only know the basics (others on here know way more than me), but these two rules have saved a total of 3 of my bikes so far.
    Hope this limited intelligence saves another bike
  2. #17
    12th July 2003 - 01:10
    The Riviera of the South
    Quote Originally Posted by Dr Bob
    I'm assuming the fork seal material is plumbers tape.
    Roofing RTV, the screwdriver is only to scoop the congealed goop out of the nozzle so you can smear the fresh stuff around the leaky seal.
  3. #18
    13th January 2004 - 11:00
    Honda PC800
    Henderson -auckland
    Quote Originally Posted by Kickaha
    I would have thought Yamaha would have a safety margin built in so the light comes on before you're sucking thin air,whats the point of a warning light coming on when it's just to tell you "sorry you've just rooted your motor"
    my bad matey--check post time--anyhoo i meant to put--on your honda -if the oil light comes on.....
  4. #19
    Quote Originally Posted by TonyB
    The oil light in my FZR and my mates XV come on when the thing is full to the top. Fuggen annoying really. The sensor for mine must be on the LHS somewhere as it usually comes on after taking a right hander at speed...or is it the other way around? Anyway, you get the idea.
    Yeah FZRs are known for it, The YZF doesn’t seem to give false readings but I seem to remember one of the early 1000 tests they had the issue. Scared a few FZR riders for no reason. Hard to make a level indicator in such a harsh environment I guess.
  5. #20
    12th May 2004 - 23:54
    Honda Jade 250 + CBR600RR
    Wgtn
    Quote Originally Posted by Andyadams
    You are a bad bad girl for not keeping up with this vital maintenance ritual. Nuff said.
    Quote Originally Posted by flyin
    She was told by all on the welly cruise last week bout regular maintenance..... probly did it this week so we couldnt giv her shite tonite.......
    Velox - you shouldnt have done anything serious yet, and it'll like you for a while now uve changed it. theres usually around a half litre variation on the scale on the oil level gauge so you dont wanna have to put more than that in............... ..
    Oi you lot! Every other time I've done my oil change pretty much on the dot so enough of that nonsence thanks! Straight to your rooms.
    The bike's fine - I know I haven't hurt it (yet) but I didn't realise it was an oil pressure gauge rather than oil level. So I take it that the light is basically just to tell you "Sorry - too late. Your bike is stuffed. Go away". Not so useful.
    Cheers for the advice guys!
    PS: It takes 2.2L (when changing the filter too) and is a very happy bike at the mo with new oil. Although I haven't noticed much of a difference (except it won't use up nearly as much oil now).
  6. #21
    30th March 2004 - 11:00
    2001 RC46
    Norfshaw
    Quote Originally Posted by F5 Dave
    When the engine's running, yes, then an idiot light for pressure is better.
    Our car has an oil level gauge - comes on when you turn the key on, and stays on for the first 15 seconds after the engine's running. And the other car has two gauges for the cooling system (probably because it has a very thin, lightweight aluminium radiator, like a bike) - one gauge for temperature, the other for the level in the coolant reservoir / expansion tank.
    ... and that's what I think.
    Or summat.
    Or maybe not...
    Dunno really....
  7. #22
    12th January 2004 - 12:00
    '87 CR500, '10 RM144
    'Kura, Auckland, Kiwiland
    Quote Originally Posted by ManDownUnder
    You gotta do WHAT?!?!?
    Jees...
    Step 1 Run the engine till the oil's hot enough to burn your hands
    2) put bsomething under your bike to catch said oil
    3) burn your hands while taking out sump plug
    4) burn your hands with gush of oil pouring out
    5) burn your hands recovering sump plug from oil in container
    6) remember to remove oil filler thingy
    7) clean side of bike coz oil all over it from oily hands (refer 4 above)
    8) burn your hands putting sump plug back in
    9) fill with oil till it shows up in the little window thingy (you can use this new oil to soth your burned hands too)
    10) put filler thingy back on
    11) wipe hands clean(ish) and side of bike
    12) head into burns unit
    13) upon return, check oil level and return to step two above as needed
    How do you guys do it?
    MDU
    That's pretty much it,cept after step 4 you retreive the drain container that you sent flying pulling your hands away from the hot oil and look for something(like the mrs sweater...)to soak up the 3 litres of oil thats now flooding the gargre....
    Drew for Prime Minister!
    www.oldskoolperformance.com
    www.prospeedmc.com for parts ex U.S.A ( He's a Kiwi! )
  8. #23
    28th November 2004 - 10:28
    Sniff... None
    Quote Originally Posted by Velox
    How bout before next Thur you remove the oil completely so I don't have so much trouble keeping up?
    "You, Madboy, are the Uncooked Pork Sausage of Sausage Beasts. With extra herbs."
    - Jim2 c2006
  9. #24
    29th August 2004 - 20:31
    Nothing At the Moment
    Jville, Wellington
    I guess im a shocker. Ive done 6000kms on the wee beastie and i havent changed the oil yet. im just reading up on a website how to do it for the GPX and i dont get this oil changing thingie. filter: where do i get that? tighten to 14.5 lb/fts: i dont have a speciallydesignedcompressionomater to do that so i might bung up.
    it also mentions types of oils but its amercaaan so i dont know how that converts to with the purity etc of the oil in nz. dont know about synthetics and stuff either.
    Im a newbie to all this stuff i confess. some help?
    DN
    Every Day Is A Good Day With Two Scoops Of Raisins Peter
    ~Family Guy~
  10. #25
    26th August 2004 - 17:13
    None :(
    Dunedin
    I changed my oil just over a week ago. Drained out ~13 litres of crap. I had intended on changing the oil at 3,300km, but the bike waspretty insistent that it happen at 2500km. So it stuck float valve in carb one open a tiny amount, and the entire tank drained through carb, inlet valve, cylinder, past piston into the sump, past outlet valve into exhaust, back up the carb and into the air box and into the carb 2 just for good measure. and this happened in Tekapo while sitting for a few days after it wouldn't start post tank fill. Took me six hours of work to dissassemble, drain the sump, clean the carbs, de-hydro lock piston 1, put fresh oil in and reassemble the beast. Runs like an absolute dream now though. I highly recommend a carb clean!
