Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Opposed-piston, opposed-cylinder engine
  1. #16
    27th March 2006 - 10:29
    Burglary capital of Unzud
    Not a new idea, but I haven't seen that layout before.
    Over the years the triangular config would also be one of the more common layouts (referrerd to above) but I think also used in planes from memory.
    Quote Originally Posted by Albert
    Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
  2. #17
    20th October 2007 - 11:34
    BMW F650 Hoonda GB500 KTM525 sixdays
    Eating Pizza
    Years ago I bought a hillclimb special that in the past had a two litre johnson V4 outboard powerhead.
    I tried to re- engine it with a TS3 and Celica box. byt I lost it in a workshop fire that came through the wall.
  3. #18
    29th October 2005 - 16:12
    Orewa
    I think you will find all opposed piston engines are 2 stroke diesels...although with direct injection a 2 stroke petrol would work too.
    The TS3 was only 202cu in,same as an HQ Holden - and I have a picture in front of me of a TS3 powered Commer CB stock truck pulling a 2 axle trailer and a box over the cab loaded with sheep.I doubt if a 202 Holden could pulled that combo empty down hill,let alone loaded and pull it over the Kaimai's
    I grew up to the sound of TS3's and my father was a big fan of them,and once worked at a Commer dealer so he could work on them more.My uncle also had a TS3 stock truck.The TS3 was disapearing when I was working on trucks in the '70's,but I did get to do a bit on them.....and more importantly to drive them and revell in the glorious noise.
    "Glorious"? Last one I saw I think was in Warkworth, turning right up Hill Street from the main road. I can't recall whether it had it's muffler on, but it screamed like a banshee as the driver hurried it down through as many gears as he had to maintain momentum.
    Quote Originally Posted by cave weta View Post
    Ah, the old 2-stroke outboard trick! There were a lot of these homebuild's around and some of them seemed to work okay but ultimately weren't successful.
  4. #19
    29th January 2005 - 11:00
    2006 Suzuki GSX-R750 K6
    Te Puke
    The three cylinder assemblies on the TS3 phased at 120 degrees, Motu?
    Almost a shame there are bugger all of them around now... I have childhood memories of the distinctive sound
  5. #20
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Junkers or Dornier used the same design (but vertical) as a bomber engine in WWII.
    AFAIK the Napier Deltic was/is the only triangular layout. Originally a Motor torpedo boat motor, then used in locomotives, and then they ended up in the "Nasty" class boats in Vietnam ("Apocalypse Now", water skiing up the river)
    Nice model here http://craftsmanshipmuseum.com/tomlinson.htm
    and an animation of the engine here http://www.wis.co.uk/justin/deltic-engine.html
    Apparently there was a TS4 as well, but never got past protoype stage and then was axed to protect the deal between Chrysler and Cummins http://www.commer.org.nz/Commer_Conn...TS4_Motor.html
    And finally I think TS refers to Tilling Stevens rather than Two Stroke
    (PostalDave on ADVrider)
  6. #21
    9th October 2003 - 11:00
    2022 BMW RnineT Pure
    yes
  7. #22
    27th October 2008 - 11:28
    dannevirke
    Quote Originally Posted by Edbear View Post
    Like the one that managed second in the world GP
  8. #23
    1st January 2007 - 19:48
    Suzuki RG400 Yamaha ST125 Yamaha TDR250
    Singapura/Banks Peninsula
    one day,all engines will be that good.
    in the meantime,i have my collection......
    "more than two strokes is masturbation"
    www.motoparts-online.com
  9. #24
    Orewa
    Quote Originally Posted by wbks View Post
    Well, there'll always be a Kiwi who can make a success of something!
    Wasn't that Kim Newcomb?
  10. #25
    26th February 2005 - 11:00
    Two triples
    Bugtussle
    Quote Originally Posted by Slyer View Post
    http://engineeringtv.com/blogs/etv/a...er-engine.aspx
    Very interesting. Have people tried things like this before?
    Napier Deltic
    http://en.wikipedia.org/wiki/Napier_Deltic
