the old bike has been dragged out of the shed, given some new oil, fresh petrol and a new chain and clutch cable. and it idles nicely and when not under load, will rev freely through the entire range.
i have not fitted a new battery yet (old one poked). Its a 1984/ 5 RG250.
the problem is when taking it for ride, it won't go past about 4k without bogging down. If i feather it on the choke, i can get it too pull through, and when it does, it will run through to red line. more often though it bogs down, like it's only running on one cylinder (but its not - though maybe intermittently).
we adjusted the mix, and made it richer by 1/2 turn - made a difference, but still the same issue. seems to be more of a left hand cylinder issue.
it's got platinum plugs, old - but they seem fine; probably next on the list to replace and see if any improvements.
Any ideas? i don;t think it has power valves or anything? not sure though.
