Intake is not touched...
Greg had mentioned possibilities of toying with the intake manifold at the post-run-in check, but they left it as standard. Stock airbox is still on. Siple things like driling out the airbox is possible.
The rotary-dial FI controller looks like some easy adjustments are available should i decide to play with the intake sooner/later
Anyone got suggestions?
I was keen on leaving everything looking standard. But work required to keep the stock muffler shell was to be quite an expensive luxury.
So go the standard exhaust chopped off, and got a straight-through tapped on the end - gold body, and with the ONLY tip available coincidentally the same colour as my scoot! (not that it reaaaaally matters, but not a bad thing) =) and only $70, compared to $150+ on modding the stock unit.
Certainly like the straight-thru's off-throttle. semi-on throttle and cruising notes - nearly bike like
The hard throttle-on note begins to reveal its true nature of being just a raucous scooter :scoot:
All 25mm outlet piping pretty much.
if only there was more ENGLISH stuff i could read about! hey, can you suggest what there is available? from Google searches, there wasnt much on UZ125 or Address V125 =(
And i guess i feel the $2k is a bit of a small fortune already =)
