Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Oil change, oil filter, air filter - When?
  1. #16
    7th April 2008 - 12:17
    2013 KTM200 & Kawasaki Ninja 300
    Quote Originally Posted by cs363 View Post
    Ah....that was my next question - whether you had the original Honda service manual that came with the bike. As it sounds like you do, just refer to pages 43 through 48 for your engine & gearbox oil change 9and coolant check). Also make sure you are running a mix of anti-freeze (most people tend to run 50/50 mix with water unless you are using a premixed coolant) to keep the boiling point down and corrosion at bay. Usually the coolant should be a bright green colour (though some are red or blue) if it looks dirty or cloudy it would pay to flush the coolant system and change the coolant. (page 48-51)
    Pay attention to the manuals procedure for checking the oil levels as it's easy to overfill if you're not careful.
    You can buy specific oil for the gearbox otherwise just use the same 10w/40 oil (high quality) in engine and g/box.
    Good luck with your service!
    OH SHIT!!!!!
  2. #17
    Quote Originally Posted by Midget250X View Post
    OH SHIT!!!!!
    ?? Didn't scare ya did I?
  3. #18
    17th July 2006 - 13:53
    2006 CR250R
    Gisborne
    Quote Originally Posted by BBikeRR View Post
    I change my oil every 3,000 kms
    in dirt bike terms, thats about 50-100 hours.
    if we changed our oil after 100 hours id hate to see what would happen
    should we keep posting irrelvant things? or maybe stick to areas where we have something useful to offer
  4. #19
    21st May 2007 - 18:03
    kx250f
    shore
    Quote Originally Posted by SpikedPunch View Post
    You've got the oil that goes on the air filter (spray on stuff is the easiest) usually blue or red and hellishly sticky, and gearbox oil that keeps your clutch all nice and wet - goopy gold coloured stuff If it's milky or has bits of clutch in it it's probably time for a change
    I do my air filter about every three rides or more often if it's really dirty. Bit slack And do the oil when it looks like it needs doing It's real basic once you've done it once. Just don't strip any bolts and you're sweet.
    Air filter is every ride mate, don't be slack it will cost you in the long run.
    ATF is a cheaper option for 2stroke trans fluid, then change every third ride rather than wait for milky colour (thats not good).
  5. #20
    Quote Originally Posted by rupecopp View Post
    Yeah thanks for all the information, it's all good! I will be doing the operation tomorrow! Oh buggar, it's the City Scramble! After the City Scramble. Have the rubber gloves ready! Geez men are good for something! Where is one when you really need them!!!!!
  6. #21
    10th May 2006 - 16:37
    2008 YZ125 & 2006 KDX200 & 1983 XL250R
    Auckland - Botany
    Hahah, how did it go?
  7. #22
    Quote Originally Posted by krad_nz View Post
    OH buggar! Went to Fells Farm to watch and haven't done the oil change as yet! My bike will just fall apart! I have the manual! I will do it before my next ride! I think it would be easier to pay someone!!!!
  8. #23
    17th May 2007 - 14:41
    L0 GSXR-R 1000 #87
    Taranaki
    Zomg I've been changing my gearbox oil on my little 2 smoker every ride, until someone said I didnt need to ... now its every 3 rides.... air filer gets cleaned every ride religiously. Is it weird that my dirt bike looks as clean as my road bike. We've got 3 dirt bikes in the garage and my one is shiney even the rims and spokes hehe.
    Firestarter Racing on facebook http://www.facebook.com/FirestarterRacing
    Racing thanks to:
    www.fluidcoatings.co.nz
    www.motostyle.co.nz
    MAXIMA racing Oils
    www.projectdigital.co.nz
    METZELER Tires
    New Plymouth Motorcycle Center
    www.topstitch.co.nz/
