Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Help, problems with my CBR
    9th April 2005 - 20:37
    1988 Honda CBR 250R
    Howick, Auckland
    Unhappy Help, problems with my CBR
    Hey guys, i just got the bike on saturday and after a few days driving i've noticed a few problems... i find that sometimes while waiting at the traffic lights or intersections i have my bike in gear with the clutch pulled right back but it sometimes dies so i have to rev the bike... am i spose to rev the bike when i'm not moving? or is there a problem with the bike itself?
    also... the bike gets hot very easily... especially when i'm in traffic (having to stop and go all the time)
    i'm new with bikes so i have no idea if its me thats causing the problem or is it the bike?
    thanks in advance guys
    8th August 2004 - 17:16
    1999 GSXR1100W, 1975 CT90
    Upper Hutt
    Does the bike lose revs then stops?
    13th January 2005 - 11:00
    fire breathin ginja ninja
    Taka, Aucka
    has the idle been adjusted too low? There's a * shaped black plastic knob near where your left knee would be, which adjusts the idle speed. Can't remember which way is which, but it'll be obvious when you twist it. Turning it one way will raise the idle speed, the other will lower it. Try that and see what happens. If that still doesn't solve your problem, then might be a bit more than that. Post back and we'll see I guess..
    As for the heat problem, CBR250s are known for their toasty ways. Just have to be sure that the bike has had a recent radiator flush and is clean in there, and that the fan works too. can check that by letting it stand and idle by itself (when you sort the idle out!), and the fan should start spinning up when the temp goes up. I think it kicks in about 3/4s up the temp gauge, or check it when sat in traffic..
    1988 Honda CBR 250R
    Howick, Auckland
    Quote Originally Posted by alarumba
    yes
    Quote Originally Posted by bugjuice
    i just went and check that knob ur talking about... i couldnt see any knob on either side of the bike except for the fuel knob (on, res, off) other than that... no other visible knobs.
    i bought the bike from Red Baron and they service every bike that they're about to sell... maybe they didnt service it that well... damn it.
    The bike is an 1988 model but its only done 15K
    Upper Hutt
    Thats what I was going to say
    NEVER UNSCREW IT ALL THE WAY!!!!!!!!!!!!!!!! IT IS A REAL SHIT TO SCREW IT BACK ONTO THE CARBS!!!!!!!!!!!!!
    Can't stress that enough!
    BTW, the attached picture shows what the thing looks like, at least on the RR
Name:	CBR250RR Carbs.jpg
    Taka, Aucka
    Quote Originally Posted by ricksta
    The knob might be tucked a little under the frame. It's on the same side as the fuel tap, but a bit further forward, should be mounted on the engine left side (as you sit on the bike).
    If the bike was bought not too long ago from RB, then I'd bet a ball that it's been well serviced, so I wouldn't worry too much about that then, and just have to get used to warm legs in traffic. That's what they do, cos they perfer the open roads to the city. Still awesome little bikes tho, I used to have one..
    15k is increadably low for an '88 too, good find if that's the case!!
    Taka, Aucka
    what was that? didn't quite hear you.. Nice one on the pic
    yeah, forgot to mention that too. Was in my head, but forgot to type. It's very *very* easy to unscrew it accidently. So just twist slowly and listen carefully to what the engine is doing. If it goes down a little, leave it a sec and see if it stays or picks up. If it rises, then you're on the right track..
    1988 Honda CBR 250R
    Howick, Auckland
    went for a second look and found it ... the knob was a little loose.. i could twist it both ways very easily but then i got a bit hard to twist...
    umm i had a little play with it and it was a bit hard to tell the difference.... but the rev pointer stays at 1K rpm (out of 20K) this time and the engine didnt die at all... i think i have it on the right setting... but we'll see tommorow wether it works on not when i take it to work.
    thanks for the help guys... i might take it back to RB and have it checked on saturday or sunday if the problem doesnt stop.
    25th February 2005 - 09:52
    05 R6 & 89 GSXR250
    Try pulling upto the lights in neutral. If it doesnt die like it has been, then more than likely the clutch needs adjusting out slightly.
    1988 Honda CBR 250R
    Howick, Auckland
    Quote Originally Posted by GROOMER
    good point there! thanks.
    29th September 2003 - 20:48
    2008 DRZ400E & 1983 CB152T
    Alexandra
    Turn it clockwise to increase the idle. The idle for CBR250's is 2200rpm +/-500 so if its at 1000 its way too low. Just turn your bike on and keep turning it clockwise till you notice the idle going high, like up to 5000rpm then slowly turn the knob the other way till it is around 2000rpm.
    Mine sometimes dies when it is cold just after starting it. Are you using the choke to start it??
    Taka, Aucka
    18th February 2005 - 21:14
    Bikeless
    Across the bridge
    Quote Originally Posted by k14
    Wow, my CBR idles at 1000rpm as well and it doesn't stall. I didn't know they were suppose to idle at 2200 +/- 500rpm...
    28th February 2005 - 09:50
    Honda CBR400RR
    In a cold hole
    Quote Originally Posted by FEINT
    Boredom, the root of all evil!
    Taka, Aucka
    if it ain't broke, don't fix
