Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: No power to fuel pump
  1. #16
    3rd June 2008 - 11:58
    hondarr
    portauckland
    got the GTIR turbo lying round? slap that on too .. but seriously 4age fuel pump probably would work,
  2. #17
    19th October 2008 - 21:54
    88 gpx 250 mess
    Seriously the the 4age fuel pump would not work.
    The cbr fuel pump is just a lift pump with no real pressure.
    The 4age fuel pump is high pressure for efi and has enough pressure to push the needles out of the way in your carbs and simply flood the engine.
    I am curious to know whether it would move enough fuel to hydro lock the engine though so if you do try it please come back with the results
  3. #18
    17th February 2005 - 11:36
    Bikes!
    Awww man, you could've waited till after the weekend to post that.
  4. #19
    hondarr
    portauckland
    Quote Originally Posted by ScreaminGherkin View Post
    just done read up , and guys have replaced them with car fuel pumps and work %100 fine on ther CBR250R MC19's, goto repco aparently "Fuel Flo universal electric pump will work,
    should cost you 130-160 bucks.
    along with small suzuki and mazda ones will work too, try not use anything for 1600cc or above,
  5. #20
    13th December 2008 - 18:22
    Your mom
    Quote Originally Posted by Rodney007 View Post
    I've got a nice Garrett, it's mounted on the car though, although the turbo off a Honda City would be cool...
  6. #21
    Your mom
    I took my bike to a mechanic and he said I need a new fuel pump. I took my fuel pump to Supercheap and Repco and they have never seen anything like it. I went to Japrace and 6 automotive dismantlers and none of them have anything like it. The only place that I could find that could get hold of a fuel pump for me is Honda, and they want over $300 for it. I'd rather stick to my push bike than pay over $300 for a fuel pump.
  7. #22
    hondarr
    portauckland
    thats because its a motorbike fuel pump mate,
    go in without it, and say whats the smallest fuel pump you got, ...
    or goto a pickapart and try find a little car with a pump, hope fuly u get one thats external
  8. #23
    Your mom
    No places I've been to have a fuel pump that is similar to the one I have. They're all too big and the inlets and outlets are on different sides of the pumps that I could find.
  9. #24
    hondarr
    portauckland
    okay go pay 300 bucks then... fitting a different pump is too hard for you,. good luck
  10. #25
    Quote Originally Posted by SMOKEU View Post
    a lot of guys use facet pumps for africa twins etc...perhaps they are the same.There must be a forum for those bikes,see what they use.I am sure you aren the only one to have this issue and is releuctant to part with that sorta dosh.
  11. #26
    Bikes!
    Ok, you want a self priming, lower pressure, fuel pump, that stops pumping when it sees too much pressure build up on the delivery side. An FZR400 had one IIRC, and if you can't find one of those, then go try a Kart storre.
    Before you do that, try giving the existing pump 12 volts yourself, make sure it's actually non functional, don't trust somebody elses opinion. It's more likely that the bike has an electrical fault that will be fairly simple to fix.
  12. #27
    4th November 2003 - 13:00
    BSA A10
    Quote Originally Posted by imdying View Post
    Ok, you want a self priming, lower pressure, fuel pump, that stops pumping when it sees too much pressure build up on the delivery side. An FZR400 had one IIRC, and if you can't find one of those, then go try a Kart store.
    Karts normally run pulse pumps, we ran a FZR pump ( not sure if it was a 400) for the reasons you've listed
  13. #28
    Bikes!
    Ghey... that was my best guess for who in Christchurch would have a low volume pump (only needs to support 45hp yeah?) with those properties
    I ran a car on an FZR400 pump once
  14. #29
    BSA A10
    I ran a 70+hp TZ250 off one of the pulse pumps and even then I needed a fuel regulator to drop the pressure
  15. #30
    Your mom
    Problem solved. I bought a fuel pump for an old Mini and it works fine.
