Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 75
Thread: What engine to power a Featherbed frame?
  1. #46
    30th November 2007 - 19:00
    Sprint 1050, plus others
    Invercargill
    I like the new Triumph idea, must be a Bonnie engine available somewhere.
    Can still call it a Triton, and be associated with the history associated with this matchup, but have the advantages of an oil-tight powerplant that has ample spares available...?
    Or, see if you can find a new Thunderbird engine...
    Where's that fucking spanner...
  2. #47
    10th June 2004 - 23:57
    Italian ones!
    Northland
    What about a GB500? You could tune it with a 600cc kit and get at least as much hp as a Manx with the same sound (ish) but with reliability.
    Yeah a 650 Honda single would work well power wise, but I am not sure you would get the charatcter from the engine that would make it fun... a full fairing with enough ventelation would hid the engine!
    Getting back to my earlier idea... a Guzzi engine would not fit if turned like a Vincent, 950 length needed less than 600 in their....
    But what about the right way around with the swing arm using the sfaft?
    That might be cool.... but would the Featherbed frame take the twisting of a Guzzi engine???
    Later
    Gavin
    Imperfect action beats perfect inaction every time.
  3. #48
    20th August 2006 - 20:32
    CB1300 black and naked mmmmmmmmmm
    coming or going
    Go feral..........H1 or H2, they had power and no frame.....CB750 or 550? get really odd GT550 suzuki, or RE5 that would screw with people?
    ER6 ?
    Hey It's Mr Nice Guy
  4. #49
    3rd December 2007 - 14:59
    1980 GS1000ET
    Dunedin
    How about a 700cc V twin Enfield?
    Bought For The Parts.......
  5. #50
    1st March 2005 - 14:45
    Assorted dinosaurs
    Yes yes yes o god yes!!!
    Similar to the Cranberry V Twin Enfield [google it]
    Ive been down this road before, cost was prohibitive which is mostly why I used a Kohler 726cc donk with Triumph 'box instead [see my sig. link]
    I still reckon you need something a bit 'left field' motor wise.....
    ITS NOT GETTING WHAT YOU WANT,BUT WANTING WHAT YOUVE GOT
    https://hondacx500custombuild.blogspot.com/?m=1
  6. #51
    4th November 2003 - 13:00
    BSA A10
    Quote Originally Posted by Eurodave View Post
    A Daihatsu Charade 3 cylinder turbo then
    edit: or a couple of Aixro XR50 Wankel Kart Engines bolted together
  7. #52
    Assorted dinosaurs
    Theres a Subaru Justy 3 cyl 1000 motor in my garage @ the moment, it may well end up in my R65, given the fullness of time......
  8. #53
    30th March 2009 - 12:36
    japper
    timbuctoo
    Graeme Cole in Hamilton raced a featherbed frame in the 80's with a Matchless motor, he then built a Dunstal replica and raced the Matchless in that before changing to a Matchless sidecar and now the Team of red triumphs that you see at Pukekohe.
  9. #54
    16th September 2004 - 16:48
    PopTart Katoona
    CT, USA
    Me me me - pick my one
    I always wanted to put something like this in a featherbed.......but thats my personal preference.
    Would look cool in a mini too!
  10. #55
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    Does it even need to be spoken
    Royal ( as in the Queen approves ) ENFIELD
    Stephen
  11. #56
    21st November 2007 - 16:42
    Honda Pan European ST1100
    Quote Originally Posted by avgas View Post
    Hello Kim Newcombe.
    Atheism and Religion are but two sides of the same coin.
    One prefers to use its head, while the other relies on tales.
  12. #57
    Enfield cr250r
    Tokyo
    I've seen a Hillman Imp in one (on Waiheke Island)...if you don't like a Hillman Imp engine,you could try a Coventry Climax instead.Maybe even a fire pump engine if you could find one.
    I did one back in the day ,,used a wide line .... nearly finished it but had to sell it due to moving
    Stephen
  13. #58
    PopTart Katoona
    CT, USA
    Quote Originally Posted by Hinny View Post
    Hello Kim Newcombe.
    Yeah but you can always push the limit pass there and put the 300hp V6
    Munch munch Rockets for lunch
  14. #59
    11th September 2008 - 22:59
    1994 MotoGuzzi California 111 LAPD
    Alexandra, Central Otago
    Nobody seems to have suggested one of my favourite engines - Yamaha XS650 - 55hp, torquey, don't need oil tank, electric start, 5 speed - what more do you want ???? - can also use Amal carbs if wanted, and retro fit electronic ignition.
  15. #60
    The XS650 is a very,very tight fit - I've seen someone try to fit an XS650 onto a featherbed....bare frame (mine) and engine on floor,it's just too tall.There is one on 650.com,the head is almost touching the top rails,and I suspect he has tweaked the lower rails to get it in.Nice though.
    http://www.650motorcycles.com/MikesImages.html
    Waging war with society
