Results 1 to 4 of 4
Thread: Will gn400 motor fit gn250 frame?
    7th February 2010 - 00:31
    suzuki gn250
    victoria
    hey guys,
    i was recently handed a gn250 which was in pretty rough condition.
    wanted to turn it into an old bobber but would like more power and a simple kick start, so i was just wondering if a gn400 motor would fit the gn250 frame?
    thanks.
    23rd April 2004 - 19:16
    2010 DC Skate Shoes
    Roxby Downs, SA
    I'm sure you could make it fit if you really wanted to.
    KiwiBitcher
    where opinion holds more weight than fact.
    It's better to not pass and know that you could have than to pass and find out that you can't. Wait for the straight.
    16th February 2007 - 08:25
    vf1000,mz500,xz400,kh125,bridgestone60
    new plymouth
    probably, its a slightly longer stoke engine, so might be a bit taller,
    but the engine is only a couple of horseys up on the 250, having a 2 valve head doesnt help
    you'd be better off with the dr350 engine
    25th January 2010 - 16:26
    dr 370 1978
    carterton
    could do
    i just put a dr 370 motor in to a dr 250 ( which has the same engine as a gn 250. only drama taller 370 carb wont go on.
    so drilled out some jet holes on the 250 carb and all goood!!!, sort of
    W
