Ive run out of fucks to give
I have often run detergent oil intended for turbo diesel engines in motorcycle engines. It does have a cleaning effect on the internals of the engine.
If you love it, let it go. If it comes back to you, you've just high-sided!
مافي مشكلة
All motor oils since the 1960's have detergents of one type or another. Light diesel oils have a good strong detergent package. Yes they will clean your motor, but so will any modern motor oil.
I only just remember the days in the early 60s when dad used to take the tappet cover of our Morrie 8 and clean off all the grime from the inside. You dont see this now days, the oils dont let this sludge form.
From memory the only supplier of a non detergent oil is Penrite and they make these oils espcially for vintage vehicles with leather of felt oil seals. The API rating SC was the first of the detergent oils (Cutting technology in the 60's). From SC to SG the oils all contain detergents and from SH to what ever the oils are up to now they went to low metal detergents because the metals were poluting the latest euro spec cats.
seems to work well enough when it's absolutely necessary
"Wow, Great advise there DB."
Bike magazine ran an kawasaki 600,on the rev limiter,with no oil or coolant in it to see how long it would last.
It ran till the carbon can caught fire and they had to stop it.It didn't actually seize.
I think putting anything in the engine is not going to kill the engine instantly.
Why don't you use Caltex Delo 400 multigrade as your regular oil? lots of people do this.
OMG.........Why do people think they know it all to the point of discarding manufacturer recommendations and Oil companies advise.
If you read back like I suggested, you would see that I had never done it on a road bike. I don't think you are interested in what was said at all - I think you are only interested in an opportunity to be a derogatory dickhead. You would be far better served to take note from people who had done things rather to show off your foolish mouth.
Steve
As usual, KB idiots ignore any actual posted experiences by others, focus on adding weight to their own opinion in the quest of purporting it as fact, and take any opportunity to take rational discussion and turn it into derogatory remarks. It's your character on display, or rather lack of it. Get a clue.
Steve
