Results 1 to 9 of 9
Thread: Help removing YZ450f 2007 engine
    17th January 2005 - 12:14
    2011 yz450f
    Featherston
    Hi as the title says are they any special tricks to this I am trying to remove my engine but have undone everything and the motor is loose but just cant get it out frame at all
    Blindspott are back as Blacklist check them out
    www.blacklistmusicnz.co.nz
    7th September 2008 - 18:48
    2008 Yamaha YZ250
    whats stopping you getting it out? if its jammed you could lever it out with something in between the engine and the bottom of the frame? never done it with a 450 but even for 250s you have to rotate the engine before you can pull it out of the side of the frame
    2nd October 2005 - 00:47
    CR250
    Papamoa
    swing arm bolt?
    2nd August 2006 - 22:17
    hopefully bringing something back to NZ
    Hartford Connecticut USA
    roll if back at the top and forwards at the bottom given you have removed the swing arm bolt (pull the whole swing arm back sometimes easyer if wheel is remove it will them hang down ) you'll also proberly need to sort a roll it over as it comes out.
    [SIGPIC][/SIG
    28th May 2009 - 20:00
    2003 Honda CRF450R
    i'd just cut it out with a cut off disc ay - i'd probably cut the top of the frame open because the engine bolts back onto the bottom and you wouldnt want to make it so you couldnt get it back in ay?
    2011 yz450f
    Featherston
    took morg's advice
    Nah sussed it what a pain in the rear end of a engine to get out has to come out from the right hand side dont ask me how I got pissed off shook it violently and it came out
    17th August 2005 - 11:00
    22"Z900rsSE, Z1R, FZR1000, KTM 2 smoker
    East Auckland
    Quote Originally Posted by Ivan View Post
    Ha ah I feel for ya been there!! Trouble is they don't bloody well go back in that way LOL!!!
    On a Motorcycle you're penetrating distance, right along with the machine!! In a car you're just a spectator, the windshields like a TV!!
    'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out! Shouting, ' Holy sh!t... What a Ride!! '
    Quote Originally Posted by Reckless View Post
    Yeh they do thats what the sledge hammer was invented for lol
    [SIGPIC][/SIG
    2011 yz450f
    Featherston
    hahahha i cant wait to put it back in im gonna go mental
