Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 1990 rmx250l engine parts questions
    5th September 2013 - 19:13
    2014 Uuki gw250 with yoshi exhaust :)
    Hi Guys, my 1990 RMX250L Flywheel and crank have been through a war when i tried to replace my stator and are now not in a very serviceable state( the flywheel seized on , stripped the puller threads and then the end of the crank shaft was also mushroomed by the sheer force of the splitter as well), does anyone know if a later model crank shaft fit the engine? I believe the flywheel all the way up to 08 fits the bike no problems??
    any Help would be appreciated!
    Quote Originally Posted by matrox02 View Post
    Have a look i the Hot rods crank cattledog or the Wiesco one they will show you what fts where.
    There is also a site i will link it if i can find it.
    oh i did lol
    http://www.oem-cycle.com/SUZUKIRMX250BIKEID.shtml
    oh i did lol
    Yeah sadly the 05d20 crank shaft listed is obsolete with no superceeded parts listed suzuki havnt been able to help so far either
    Yeah sadly the 0d520 crank shaft listed is obsolete with no superceeded parts listed suzuki havnt been able to help so far either
    on the list the Flywheel fits RMX250 89-98
    Crankshaft is 89-92 only.
    Ebay will be your best bet
    Oh and looking over wiesco and hotrods they only supply from 96ish upwards
    Yeah been looking.. either incomplete overly expencive engines there or nothing haha
    24th May 2008 - 21:24
    some honda bits in a kx chassis
    Waiuku City
    You can use the mrcycles.com website to look at the parts diagrams of the different years.
    From the link to OEM cycle, theres the earlier 89-92 05D20 crank assembly, and the newer 93-98 29E10 assembly.
    From the mrcycles links for the 92' N model http://www.mrcycles.com/oemparts/a/s...ft-model-l-m-n and the 93' P model http://www.mrcycles.com/oemparts/a/s...haft-model-p-r
    the cases are the same, as are the crank bearing and seal dimensions. Suggesting that they would in fact crossover and a much newer crank can be used in the older models.
    we may just go where no ones been
    Quote Originally Posted by noobi View Post
    I would sure hope so, problem is that im not willing to sink 500+ into a "maybe at best" part not that i wouldnt be able to get bearings to suit readily enough, the problem would be the seals...
    Im also on thumper talk, and have a guy looking into the differences on the cranks as he has a few apparently from what he knows the case bearing inner Diameter can range from 17-25mm and the outer also can range from 24-25.. or something along those lines. Im going to have to pull my crank anyways so im be measuring it up but cant do so till at leased next week
    HOWEVER... Looking at just the bearing for the LH side of the crank.. it seams to go right from 1970's to 1996 for the RMX250's so the crank itself may not be all too differant... Ill be doing more research anyways
    Waiuku City
    I think the main difference between the D and E series cranks is the type of rod assembly. The washer arrangement is different between them. The crank lobes look different, but like I said before, the cases, bearings and seals are the same, so how different can it really be.
    Wheres your sense of adventure.
    I like that attitude for adventure, but i dont think my wallet will haha, and looking over the images of the differant cranks other than the webbing lobes looking differant it looks like the drive spline on the right side end of the crank can be vastly differant, maybe thats the ticket really to finding a 2nd hand replacement, pull out the crank and look at the drive splines to find a replacement that fits
    It looks like though there are slight differances... the L M N P and R model crank shafts should fit, all the same bearings and final drives only the K model wont fit... in the years 1989-92 sooo hmmm may have to look over Ebay a bit harder for the look of these cranks.
    6th December 2013 - 22:36
    1977 suzuki fr50
    whakatane
    theirs one for sale on here for a measly grand-buy it and use yrs as spares?
    16th December 2007 - 16:40
    2013 xc 250f
    This was my one brand spanking new in 1990
    Quote Originally Posted by Slorider View Post
    Same bike! Was hard starting just finished overhauling the brakes then lost all spark sadly
