Results 1 to 9 of 9
Thread: Auckland mechanics for steering head bearing replacement?
    17th May 2013 - 17:05
    2010 DRZ400SM, 2006 ZX10R
    Auckland Central
    WOF guy says I need my steering head bearings replaced as theres a bit of play in the head stock, who is the best person to contact about this and have it sorted? Sorry if this is a stupid question, newbie.
    25th March 2007 - 12:04
    SPEED TRIPLE
    LA LA LAND
    Everyone will have different opinion on "who is the best" so you may get alot of different answers.
    When I had my Hornet I took it to Spectrum Motorcycles on the Shore. Fan-farking-tastic service.
    http://www.spectrum-motorcycles.co.n...ContactUs.aspx
    13th December 2008 - 18:22
    Your mom
    The bearings may not actually need replacement. Sometimes it just needs to be tightened and it's all good. I know this because I was in exactly the same position with my CBR250 and GSXR600 for steering head WOF fails.
    Auckland Central
    Thanks for that, what should I expect to pay also?
    I dont think its something Id be able to do myself, and needs to be done on the day as its my only transport.
    31st March 2005 - 02:18
    CB919, 1090R, R1200GSA
    East Aucks
    Most shops are going to be busy as it's the summer period. You can certainly book in and then get it done.
    I'd suggest a Honda shop, as they would deal with them constantly, so know what they're looking at. I use Botany Honda for my CB900.
    13th October 2007 - 19:54
    RSV
    band camp
    Quote Originally Posted by hornetakl View Post
    Since you're "central" Auckland I'd suggest AJ at MotoHaus (underneath Motomail - down the ramp).
    As has been said, he is busy but if they do only require tightening not replacing he may be able to get it in.
    Shoulda gone there for the WoF too... just saying...
    Quote Originally Posted by Soul Daddy
    I got a good half hour with him in the Yamaha tent at Laguna in 2005. No one knew who he was until someone in the tent yelled "who here has the most wins?" and everyone pointed at Rossi, and Rossi pointed at Ago standing next to me.
    Auckland Central
    Do the forks need to come off regardless?
    Sent from my GT-I9505 using Tapatalk
    13th September 2012 - 20:50
    2014 BMW G650GS
    Toby Beadle at Auckland Motorcycle Services has just done the head bearings on my BMW R80RT and all good.
    http://www.stuff.co.nz/auckland/clas...cycle-Services
    1st June 2012 - 04:32
    Depends on the ride.
    New Zealand
    To check/adjust the stem bearings you do not have to remove the forks.
    You can undo the nuts and re-grease and/ or inspect the races by removing the upper triple tee and letting it slide down a few inches.
    There are two bearings upper and lower that fit into the tees.
    Look up the torque values and re-assemble as per the specs.
    You will need some skill, a torque wrench and sockets and grease, and a method of raising the bike so the front wheel is off the ground.
    There are numerous u-tube videos on how to..
    If the bearings need to be replaced the whole front end needs to come off and the bearings removed and re-fitted to the tees.
    Have a look and see if its for you.
