Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: 2010 ZX10 battery issues - Please help
    14th March 2010 - 08:28
    2008 ZX10R
    Hi guys. I am having some issues with my ZX10 battery. Please provide some experienced help to rectify.
    Heres the background:
    -29 Nov 2014 - crashed road zx10 on trackday. (the bike hasnt been ridden since)
    -Sat in the workshop for a month or so getting fixed etc
    -i have turned the zx10 into a track bike. so all the lights, indicators have been taken off.
    -about 4 weeks ago i tried loading the bike to the trailer to practice. So i know the bike was starting and working then
    -2 weeks ago i tried turning the bike on again and it wouldnt work. So with the help of a friend i pushed started it and it started. I then left it on running for about 10 mins and turned it off. tried again after 10 mins and it didnt work. tried to push start again but with minimal effort and it didnt start. SO i thought its the battery drained out and i have a charger and i will charge it later.
    -yesterday i hooked the small battery charger that i have that can jump start cars and is supposed to be ok to use to the bike.
    - as soon as i hook it up the bike dash comes on but not enough juice to start the bike.
    -one hour later tried again. that time the bike tried to start but felt like there is no petrol (there is enough petrol in it)
    -left it overnight to charge. the battery charger and the bike is back to fully dead.
    What do you think the problem is and what i can do to fix it
    details of the charger i am using.
    Cpacity: 12000mAh
    outputs: 2X5V/2.1A, 1X12V/10A
    Jump start current - 200-400A
    http://tinyurl.com/m48j3n7
    I need to get it fixed urgently. Please help.
    maybe i cant read properly but it doesnt say it will recharge the 12v battery.?
    27th November 2012 - 11:25
    16' xtz125e super-adventure, Ninja 650
    sounds like the battery isnt holding charge anymore, get a new one.
    27th March 2006 - 10:29
    Burglary capital of Unzud
    Sounds like a dead battery. Disconnect the pos lead from the bike an charge it. When you've finished charging it (assuming lead acid batt) measure the voltage, should be some where between 12.3 and 12.6 volts.
    How do you know your charger is working OK?
    Quote Originally Posted by Albert
    Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
    9th October 2008 - 15:52
    RSV4RR, M109R, ZX10R
    wellington
    Its says it comes with life time tech support. Have you asked them what they think?
    Wide assortment of adapter plugs
    PowerAll PBJS12000-R Power pack with battery cables
    PowerAll PBJS12000-R Built-in LED flashlight
    PowerAll PBJS12000-R Jumper cable outlet
    PowerAll PBJS12000-R Powerful enough to jump start your car
    PowerAll PBJS12000-R Two USB ports
    PowerAll PBJS12000-R Wide assortment of adapter plugs
    Portable power pack and jump starter
    Item #: 860PDJS12K
    In Stock
    11 Reviews | 2 questions - 2 answers
    Your price: $129.99
    Earn up to 130 Rewards points
     Add to Cart  Free Shipping  Lifetime Tech Support <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    That's how I read it too.
    2008 ZX10R
    the reason i think it can charge the 12v or motorcycle battery is that there is a little symbol of motorcycle on the box and also one of the outputs is 12V/10A
    2008 ZX10R
    Quote Originally Posted by paturoa View Post
    I dont know if the charger is working ok. I can only assume because the dash lights up immediately after hooking it up and after an hour when i try starting the bike, it makes the noise as if it want to start the engine. like it normally does when you push the starter. but it keeps making the noise and the engine doesnt start.
    and then i left it overnight and the battery charger and the battery both were fully dead.
    2008 ZX10R
    Quote Originally Posted by mossy1200 View Post
    Item #: 860PDJS12K
    In Stock
    Your price: $129.99
    i am not sure that will help. I still need to charge my bike battery.
    20th June 2011 - 20:27
    Dog Rooter, 1290 SDR
    Marton
    Sounds like a stuffed battery. If its the original one to the bike its due for one.
    Manawatu
    Quote Originally Posted by jafa21 View Post
    12V 10A will not properly charge a motorcycle battery; the picture could be because it can jump start one though.
    2008 ZX10R
    Quote Originally Posted by nzspokes View Post
    can the battery just die? i thought i would find it loosing power overtime etc.
    2008 ZX10R
    ya thats probably what it means. but why cant it jump start it then?
    Marton
    Yup. Had that a couple of times and same on the car.
    But check out your charger first by the sounds.
    wellington
    So you contacted the tech support and they couldn't help?
