Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
Thread: 2010 ZX10 battery issues - Please help
  1. #16
    14th March 2010 - 08:28
    2008 ZX10R
    Quote Originally Posted by nzspokes View Post
    Yup. Had that a couple of times and same on the car.
    But check out your charger first by the sounds.
    what do you mean check out my charger?
    what can i do with the charger?
  2. #17
    2008 ZX10R
    Quote Originally Posted by mossy1200 View Post
    So you contacted the tech support and they couldn't help?
    no i havent. i am wondering what that will do? I am not even sure if they even have tech support here in NZ?
  3. #18
    12th September 2004 - 17:40
    09 GSX1400.
    Horowhenua NZ
    Same as the other posters, Is the charger charging and if so is the battery ok ? Either or ?
    I trickle charge my bike each week to keep it charged.I'm too old to fuck about, pushing fucking motorbikes.
    A good battery is important for these modern bikes.
  4. #19
    2008 ZX10R
    Quote Originally Posted by roogazza View Post
    I dont know the answers to these and not sure how to find these answers. I was hoping you guys can help me on that
    I will try getting the battery replaced. See what happens.
  5. #20
    09 GSX1400.
    Horowhenua NZ
    Quote Originally Posted by jafa21 View Post
    can someone,(a garage) put a meter on the battery for ya ?
    Might save buying a battery?
    Can the charger be checked at the same time ?
  6. #21
    9th October 2008 - 15:52
    RSV4RR, M109R, ZX10R
    wellington
    The reason I ask is after watching the you tube clips and reading several reviews it seems the units primary function is to provide cranking amp and voltage for starting a vehicle then leaving connected for up to next 30 secs lets the vehicle alternator take over.
    It seems the charging function is more aimed at laptops and phones where sustained current draw to charge is very low.
    I could be wrong but I cant see it charging a flat vehicle battery
    Contacting the tech advise would confirm this.
    Use a car battery disconnected from your car with jumper leads to start bike(or your unit if its still working). Once started disconnect jumpers and measure voltage at bike battery. Should be around 12.5 at idle and over 13volts at 3k revs. That will tell you if your alternator and regulator in the bike are working.
    If good remove battery and take it to battery shop or put it on a recovery charger unit to see if its good.
  7. #22
    2008 ZX10R
    will this product work to charge the battery?
    http://www.trademe.co.nz/motors/moto...-838586452.htm
    I dont have a spare car battery and i dont want to disconnect my car battery.
  8. #23
    2008 ZX10R
    I have sent tech support an email. will keep you posted when they reply. But i probably dont have enough time to wait for them to reply.
  9. #24
    2008 ZX10R
    http://www.trademe.co.nz/Browse/List...x?id=838586452
  10. #25
    wellington
    Your link is a menu page.
    http://www.trademe.co.nz/motors/moto...-840733721.htm
    That's what I have. Seems ok and shows you a bit of battery information as its charging. Comes with a plug unit you can install onto bike for easy connection. It wont jump start your bike when the battery is flat though its only functions are charging and maintaining battery.
  11. #26
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    Have you got a voltmeter? if so, push start the ike and check what voltage the battery is at when running; report back.
    If not, go find a voltmeter and see above.
  12. #27
    2008 ZX10R
    I tried push starting and it wont start. No i dont have a volt/multi meter
  13. #28
    27th March 2006 - 10:29
    Burglary capital of Unzud
    Where in dorkland do you live? Perhaps an inmate can visit with a meter.
    Quote Originally Posted by Albert
    Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
  14. #29
    2008 ZX10R
    Quote Originally Posted by paturoa View Post
    That would be great.
    Pah Road, royal oak.
    Call me please 021 04 83 789
  15. #30
    2008 ZX10R
    Called AA
    alright. so i called AA just to see what they think. I really am desperate and need to get it going by friday.
    The AA guy hooked his battery charger to the bike and the bike did the same thing. it turns the engine but no fire or no ignition. (same as when i charged with my little charger)
    Then he sprayed the air intake (by the air filter) with CRC engine strat (25% ether) and hooked the battery back on and it fired for a milli second or so. It was definetly going.
    So he is thinking for some reason the bike is not getting any fuel. I am thinking Glenn from Just fairings unhooked some fuel connection to the bike. It has been behaving like this only after Just fairings worked on it. It pushed started before I took it just fairings.
    Any thoughts now?
