Results 31 to 45 of 47
Thread: 2010 ZX10 battery issues - Please help
  1. #31
    4th April 2011 - 18:44
    A fast one
    Quote Originally Posted by jafa21 View Post
    So he is thinking for some reason the bike is not getting any fuel. I am thinking Glenn from Just fairings unhooked some fuel connection to the bike. It has been behaving like this only after Just fairings worked on it. It pushed started before I took it just fairings.
    Any thoughts now?
    Take off the fairings and investigate the fuel connection(s) then. Even if you find a leaky or unplugged fuel connection it still sounds as though you need a new battery.
  2. #32
    14th March 2010 - 08:28
    2008 ZX10R
    Quote Originally Posted by The End View Post
    I checked. I couldnt find anything that is disconnected. I am hoping its just a loose connection. I will probably take it to spectrum tomorrow if George from motorcycle doctors cant come over tomorrow.
  3. #33
    9th October 2008 - 15:52
    RSV4RR, M109R, ZX10R
    wellington
    I think your bike has a tilt sensor that cuts the fuel pump. If you don't have a battery that's good then it wont reset.
    With correct voltage and cycling the ignition on and off a few times this sensor resets.
    Was the bike on it side at any stage lately?
    Your going to need tell us what electrics you have connected from the harness if its anything more than the indicators.
  4. #34
    2008 ZX10R
    2010 ZX10 Battery issues - Please help
    Quote Originally Posted by mossy1200 View Post
    Nothing is connected. Indicators and lights have been removed. Everything was disconnected except for the dash. Dash/speedo still works.
  5. #35
    wellington
    What did you do with the stand switch?
    If it wont bump start in gear it could be the stand switch is preventing it starting.
    Is the stand switch normally open circuit or closed circuit.
    Does the fuel pump prime up when you have battery power?
    Have you had enough battery to cycle the ignition on and off a few times.
    I cant find a wiring diagram online for your bike that's free. Do you have one?
  6. #36
    2008 ZX10R
    I am not sure what was done to the stand switch. The stand switch used to work so that i couldn't start the bike if the stand was down.
    Not sure about the other questions of yours.
    Dont have a wiring diagram.
    I think someone like spectrum will know what to fix straight away. I am gonna take it in tomorrow. Thanks for your help. Dont waste anymore of your time trying to figure out the problem. Your help is much appreciated.
  7. #37
    wellington
    Assuming your racing this bike im assuming the stand has been removed that's why I asked about the stand switch. Trying to bump start it involves being in gear so if you removed the stand but didn't do anything with the switch the bike wont run.
  8. #38
    2008 ZX10R
    Sorry forgot to mention. The stand hasnt been removed. Its same as before.
  9. #39
    wellington
    Cool. Its most likely a good battery and cycling the key on and off will reset any errors the ecu has which could be preventing fuel pump from starting up or if the fuel pump unit is in the base of the tank it hasn't been plugged back in again.
  10. #40
    29th October 2005 - 16:12
    Orewa
    Spectrum has a great rep. Ask them about Shorai batteries too...
  11. #41
    20th June 2011 - 20:27
    Dog Rooter, 1290 SDR
    Marton
    Quote Originally Posted by Edbear View Post
    Yeah my dealings with them has been very good.
  12. #42
    does the bike have a "reserve " or "prime" fuel tap position?.Try that just for kicks.May be a neighbour has a proper battery charger.Both of those ones you linked to earlier at 20 and 30 amp hour would be marginal for a big bike battery system
  13. #43
    wellington
    My zx14r only has a 14amp hr battery. Its most likely his zx10r has a similar size battery.
    The 30amp hour charger I linked seems to handle mine and the 18amp hr battery I have in café racer ok.
    It doesn't seem to take very long to bring the battery up to 90% then it seems to change function and slow down.
  14. #44
    2008 ZX10R
    I could be wrong but I cant see it charging a flat vehicle battery
    Contacting the tech advise would confirm this.
    Tech support replied:
    "The powerall deluxe model is sufficient to jumpstart a 12 volt battery for you motorcycle. The unit itself is meant to jumpstart the vehicle and not meant to charge a vehicle battery. "
  15. #45
    2008 ZX10R
    Problem solved
    Alright guys, turns out the tilt sensor was removed at the time of removal of stock fairings.
    It is mounted on a big bracket which bolts to the bike.
    The battery was also buggered. Couldnt hold the charge.
    Gotta new battery and tilt sensor plugged and it all works.
    Thanks a lot for your time and effort.
    Never doubted your ability
    Mossy mentioned it could be the tilt sensor...
