Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Help please New undertail Led problem
  1. #16
    20th February 2005 - 07:04
    2010 Thruxton & 2013 Think Ion
    Tawa
    If your LED's are two leg inputs only, something similar to the following diagram is probably whats being used.
    Thinking about it, I should have made R1 & R2 both 1200 ohm.
    If you don't understand the circuit operation, just ask.
Name:	LED Lights.JPG
  2. #17
    26th April 2004 - 18:48
    Girlz bikes rule :-)
    Tauranga
    Thumbs up
    Quote Originally Posted by allun
    My brain is running slow today, i have a cold...so forgive the silly questions - but did you buy LED bulbs that fit into standard bulb holders, or did you get an undertail assembly that has LED light built in and wires coming from them for you to connect.... ?
    Hi allun
    This one
    An undertail assembly that has LED light built in and wires coming from them for you to connect.
    Sounds easy, but I am starting to get the picture now
  3. #18
    Tauranga
    Thumbs up
    Quote Originally Posted by R1Aaron
    sory dude instructions went with it...ill email the guy i sold it to see if he can help.
    Great that would help
    Thanks
  4. #19
    Tauranga
    Blah
    Quote Originally Posted by kawa10
    So does that mean that the LED is a light only type bulb (no brake light capability) or does it mean that I am missing something?
    i would say yes and yes.
    I thought about ringing you mate now I know why I didn't
  5. #20
    Tauranga
    Thumbs up
    Quote Originally Posted by SpeedMedic
    The light emitted while on headlight mode is bright as... that is as bright as the LEDs are rated. When you activate the brake you cannot see any difference cause they cant get any "brighter" than they already are. So as was mentioned you need to put a resistor in the park light circuit to dim that one down a bit so when you brake the full brightness is acheived.
    Just read that .. bloody terrible, but you prolly get the picture.
    Thanks mate.
    Yep the picture is getting clearer thanks
  6. #21
    Tauranga
    Smile
    Quote Originally Posted by Dafe
    Thanks for your input Dafe and the diagram nice
    It is all starting to make sense.
    Thanks for your help everybody.
  7. #22
    Tauranga
    Quote Originally Posted by froggyfrenchman
    I would hook the park lights up to same as tail light, then hook brake up to what is currently park. Just my opinion
    Errr would this work? without endangering the LEDs
  8. #23
    23rd January 2005 - 11:00
    I would put the original back on and your problem would be solved
  9. #24
    Tauranga
    Thumbs up
    Quote Originally Posted by XTC
    Nice
    I am very close to solving the said problem :spudwave: and it is all looking very tidy indeed.
  10. #25
    19th March 2005 - 21:45
    Zeex12r & Er6rrr
    the shed
    Quote Originally Posted by saul
    you could have just texted.
    why do black tyres on a black road produce white smoke?????
  11. #26
    Tauranga
    Thumbs up
    All sorted, thanks for all the input
  12. #27
    Tauranga
    Smile Photos
    Here it is all installed and happy
    Go on have a look
    New detector
    Cheers every one
